Lscott
    106
Everything posted by Lscott
  1. I would recommend the Slim-Jim. It doesn't require a ground plane like a 5/8 wave antenna would. It's also good for portable operation like camp sites etc. When not needed it's easy to roll up and stick in a drawer. If you get the dual band version it works on VHF MURS and the UHF GMRS channels. https://n9taxlabs.com/shop/ols/products/dual-band-murs-gmrs-standard-antenna
  2. This should get some interesting responses. People talk about their first radio or their favorite one. In this case which one you disliked the most you wasted money buying? This could be more useful for newbies.
  3. It's 2.6:1 on GMRS? That's high. I'm guessing you mean 1.6:1. The antenna is a good wide band design, but it's a bit sensitive to the mounting location. Being a 5/8 wave it needs a good ground plane.
  4. As @BoxCar mentioned it's yes and no. Some antennas might work just fine even if the manufacture's specifications don't cover the frequency range. You'll need to test it. I have an old, like 20 years, dual band Comet antenna that works great on both Ham bands, MURS and GMRS. Unfortunately they don't make it any more. I had purchased two at the time. One I used strictly indoors, never saw the outside and looks like new. If the one I have on the vehicle ever fails completely or gets destroyed I have a back up. I did an SWR scan using a RigExpert AA-1000 antenna analyzer. https://rigexpert.com/products/antenna-analyzers/aa-1000/ I was curious to see how it performed verses the manufacturer's spec's. See the attached files. The scans are the antenna as mounted on my old Jeep's roof rack cross bar. CA-2x4MB Manual.pdf
  5. From the album: Misc. Radio Gear
    One of the annoying things with buying a used radio is the case may not be in very good condition. The worse is the display cover "glass", really just plastic. I found a good way to clean some of them up by using tooth paste and a damp cloth/paper towel to polish the screen. It works but takes a lot of time and effort. If done well the results are very good. In the photo is an example of a TK-370 radio with the cover glass showing a very noticeable scratch and cloudy complexion. After the polishing it looks almost new.
  6. That makes more sense. ?
  7. The continuous carrier bit is confusing. One could interpret that as 100 percent duty cycle or would that be CW type communications using Morse code? I'm guessing it's the 100 percent duty cycle one. The interference part seems to be ignored. I can't see how how a remote doorbell- pager will monitor for channel activity without the incorporation of a BCL, busy channel lockout, function. Same with telemetry systems etc. I think these applications just TX in the blind and screw any other traffic that happens to be there. Anyway MURS, Multi Use Radio Service, is the garbage band for stuff nobody wants elsewhere on VHF.
  8. The FCC rules allows all matter of stuff that's prohibited on GMRS. I don't doubt that some areas may see little use, but that doesn't alter what is authorized. https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-J/section-95.2731 What is notable is I don't see any limitation on the duration of those permitted uses. That would imply they can be used at high duty cycles.
  9. Yes, DMR might make sense for MURS. It's already sort of a catch-all garbage service as it is with people using remote doorbells, wireless data logging devices etc. I doubt DMR would do much more to mess it up than all the other crap that's there now.
  10. Lscott
    CA-2x4SR
    This is a Comet CA-2X4SR wide band antenna. I have it mounted on a sawed off metal stand with 4 ground radials. It worked well for Ham/GMRS/MURS. I used this setup when I lived for years in an apartment where outdoor antennas were prohibited. https://cometantenna.com/wp-content/uploads/2013/09/CA-2x4SR.pdf The antenna is a bit sensitive to the type of ground plane used, flat sheet metal - magnet mount - ground radials etc. I would recommend anyone using the antenna to test it in various locations and use the one that results in the best match over the frequency range of interest.
  11. You have some valid points. I think the issue with going digital has more to do with improved voice quality than anything else. There is some possible range improvements, likely due to digital voice modes to maintain clear communications until you reach the range limit. As you pointed out the signals propagate the same regardless of mode. I suspect the attraction of digital voice for the average non-technical GMRS user is clarity of the audio signal under conditions where analog FM will sound like crap. It's a better user experience. The issue with how to configure the radio for digital mode(s) can be addressed by restricting the options. For example all compatible radios must use the same time slot, or likely both, the group ID can be fixed (All Call), leaving leaving just the color code as an option. Remember the EU has the dPMR446 license free service. The use of DMR isn't really the only choice. I wish people would get that out of their head and consider the other modes that might be much better, simpler, from a user's view point. There are other digital voice modes requiring less setup, such as the one I just mentioned. I have the programming software for the Kenwood TK-3701D, which is an EU license free analog/PMR446 radio, just to see what it looks like. See attached file for an example of the digital half of the radio memory setup. It's really not that complex, on a par with analog FM. Part of the issue with getting the FCC to consider digital voice mode(s) will be how to fit it into the existing GMRS service given it's current limitations. DMR might not be the best idea regardless of how "popular" it is. People are using it simply because it's readily available with somewhat affordable radios. As some others have pointed out it's already causing problems. Using a different digital voice mode with some sane rule changes that can be fixed IMHO.
  12. The rationale for pushing for digital voice modes has nothing to do with making GMRS an “Amateur Radio Lite” service. In fringe areas FM doesn’t result in clear reliable communications. Having the option to use digital voice, and the documented better received audio signal quality in conditions where FM signal quality is poor, is the point.
  13. Hypothetically if one didn’t use the amplifier there wouldn’t be the necessity of asking the question.
  14. You might like this idea. GMRS Digital Voice - 20220803.pdf
  15. An in-band repeater you likely need a good cavity duplexer. Tuning one isn't so easy with the inexpensive VNA's since they lack a high dynamic range. The attached files are from my on-line library I keep on the computers and smartphone for quick easy reference. For duplexers this might prove useful. Calculating Required Isolation.pdf 468523097_RepeaterAntennaSystems.pdf Understanding Maintaining and Re-Tuning Antenna Duplexers.pdf
  16. The next thing you're going to want is a good antenna analyzer. There are lots to choose from. Seems the favorite is a VNA, vector network analyzer. Be careful which one you buy. Some are using crappy components, poor PCB layouts and generate poor results. https://nanorfe.com/nanovna-v2.html
  17. This is why the FCC will have to address allowing digital voice on GMRS sooner or later. It's happening with, or without, their official blessing. I would rather see digital voice incorporated officially in the rules, which hopefully will eliminate the chaos that currently exists. It also has to be coupled with some meaningful enforcement actions, at least directed towards the more frequent and flagrant violators. Right now the complaints stem from DMR operation on GMRS. However I'll bet that's not the only digital voice mode you'll find in use on the service. There are plenty of commercial radios very capable of FM and digital modes such as NXDN and P25. I have several of those and some are Part 95 certified. Just can't use the digital half of the radio. Then you have some of the modified Ham gear, MARS/CAP mod's, running D-Star and YSF. A real smorgasbord to sort out. I started a thread a while back about possible Part 95E rule changes to allow digital voice on GMRS. Seems like people don't care since the thread just died from lack of interest. Also it got derailed early on over lecturing about FHSS, which wasn't the point of the thread anyway. Oh well.
  18. Try reading this book. It's written for the average Ham Radio operator so it doesn't get crazy with the math etc. http://www.w3pga.org/Antenna Books/Reflections III.pdf
  19. There is a lot of misinformation and myths surrounding SWR and coax cables. I would recommend reading the book at the following link. http://www.w3pga.org/Antenna Books/Reflections III.pdf
  20. Yup.
  21. The chances of getting the FCC to grant more exclusive frequencies for GMRS are next to zero. We’re lucky they don’t take some away to use for Part 90 users. We’re far better off petitioning the FCC to allow digital voice modes on GMRS. The cheap FRS radios would stay the same, limited power, no repeater access and narrow band FM only. There is a thread I started on the topic 1 or 2 months back. In one of my posts there is an attached file outlining the idea.
  22. Yes. That’s one of the major differences. It’s also the “carrot” hanging off the stick in front of the donkey to get people to pony up and pay for a GMRS license.
  23. I wish you the best as well. My sister and her husband both went through radiation treatments. Sister was breast cancer and her husband had prostate cancer. Both are doing good fortunately. I hope you're results a in positive outcome.
  24. You can look here at this site. Has a load of useful info on the D878 and its derivatives. http://members.optuszoo.com.au/jason.reilly1/868mods.htm
  25. Well at least normal FM. There are some trunking systems, with distributed repeaters, where the radios will look for a repeater that has the strongest signal, or above a threshold level, and use it. The radios are programmed with the minimum signal levels which the repeater has to meet or exceed to connect.
