piggin
piggin's Achievements
I am high where I am. 20 feet of Bolton 600 and a Laird 4607 works for me. Sweet setup. Mouser has the best prices on the TE connectivity antennas. The Bolton LMR600 equivalent is inexpensive and durable. Install and enjoy.
Feedline and antenna then radio. If you need a high antenna then mast/tower height enters the equation. Lowest loss feedline and a high antenna = great results. A great radio is icing on the cake.
piggin reacted to an answer to a question: LMR400 vs RG8X
Seapup reacted to a post in a topic: Base station radio
WRUU653 reacted to a post in a topic: Propper radio etiquette
WSDA629 reacted to a post in a topic: Propper radio etiquette
Just talk. You will be fine!
Exactly. YMMV but it's usually hilarious!
If you want to talk on repeaters listen for awhile and you will learn what is ok for that repeater. Otherwise just talk normally and you will be fine. GMRS is designed for normal people so radio etiquette does not really apply. Remember that FRS (Family Radio Service) shares our channels so vulgar language is a no no. Kids playing in their yard don't need to hear that! I hope this helps. I am a ham and etiquette is a big deal in that service and even so it varies depending on who you are talking to. Using NATO phonetics and pro signs on GMRS will elicit various responses...most of them hilarious and filled with LOL and FAIL. FWIW
gortex2 reacted to a post in a topic: Midland MXT500 Review
piggin reacted to a post in a topic: Midland MXT500 Review
As a confirmed TARD ( Total amateur radio dork) I can confirm. The Midland 500 is an excellent radio but not great for long winded blathering. Fortunately I found a fan on amazon that moves about 25CFM that when positioned about 1/2 inch or 3/4 behind the heatsink on the back of the radio transforms the radio into a long winded beast. It is an excellent performing radio on receive as well as transmit. Out of the box, not ready for a TARD. But a cheap amazon fan fixes that. The entire case is a heatsink and for a low duty cycle is fine on 50W. But if you need to pontificate for long periods forced air cooling does the trick. The top cover might look like sheet metal in pictures but it isn't. It's an aluminum casting like the bottom. Addition of a fan makes it completely dorktastical and you too can enjoy great performance and be the bane of all repeaters by getting one. Highly recommended radio. It's easy to program from the front panel and has power to get the job done. The only downside is that it does not have tone scan built in. FAIL. Fortunately as a TARD I have equipment that scans very fast so no sweat. And a notebook and a pen to write frequencies and tones down is ideal for grid down situations. https://acinfinity.com/equipment-cooling/axial-8038-muffin-120v-ac-cooling-fan-80mm-x-80mm-x-38mm-low-speed/ Don't use the included grill..it increases the noise.
Repeater 2.3 miles away, can hear clearly, can't hit it.
piggin replied to WSCB609's question in Technical Discussion
It is because the repeater has an antenna that has a different pattern than yours...and also probably more ERP than your setup. Its a normal occurrence on UHF. If you use 50 watts that might do it. In the absence of direct LOS you are using diffraction to get into the repeater. To use an analogy...car headlights approaching you at night beyond a hill between you are brighter to you if they have a tight spot aimed at the hill apex and are really powerful. If you are running low beams and weak lights the other driver won't even know you are there. Distance isn't the limiting factor. LOS occlusion and pattern combined with power are. I hope this helps. -
piggin reacted to an answer to a question: Antenna for GMRS repeater?
piggin reacted to a post in a topic: I don’t think Midland radios are very good.
piggin reacted to a post in a topic: Location, location, location
piggin reacted to a post in a topic: Unbelievable GMRS distance
piggin reacted to an answer to a question: Midland GXT67 PRO have as superhet receiver?
brasda91 reacted to a post in a topic: Base station radio
Magnetic antenna mount, on an aluminum pool cage for ground plane?
piggin replied to WSFY419's question in Technical Discussion
It should work fine. My first contacts were made with a magnet mount on the center of a piece of metal from the side of a dryer on the roof of the dormer of my house. The only problem is aluminum is non magnetic, so adhesion is a problem without help. -
WRAX515 reacted to a post in a topic: New Charlotte, NC area GMRS Net
piggin reacted to an answer to a question: Indoor antennas?!
Excellent!!!
You are welcome! I bet the price goes up when they are in stock again. You scored!
I bought my Laird/ TE connectivity FG4607 from Mouser. 249 ish dollars. Shipping was 9.95! I apparently bought the last one in stock and it got here the day before the hurricane arrived. It is an excellent antenna...that varies wildly in price!
marcspaz reacted to a post in a topic: Antenna Choice / SWR: Do They Matter?
I have a magnet mount that came with the midland 500. 6.6 to 1 with no antenna. 12 feet of lossy rg178 with nothing attached was 3.3 to 1. Some mobile magnet mounts have fairly high loss in the long provided coax. Measure yours with a active swr device and you might be surprised! I don't have any idea what the power amp is in my midland but if it is like other radios it probably has an rf power module in it. The ones in my Icom 2730A are rated for 60 or 65 watts max but run at 50 watts. I mention this because the modules are rated for 20 to 1 swr no damage at over 60 watts!!!! Very rugged. Good practice also will reduce drive if high SWR is detected. I know nothing about how the midland is built or any other GMRS radio is made but...I would be surprised if the makers reinvented the wheel to make mobile radios. The modules are economical and reduce parts count. They are probably pretty robust! And lossy cable will radiate some...which is why you could use it at all. Great story!
SteveShannon reacted to a post in a topic: Base station radio
Yes! Try to get one with a regulated output to ensure proper performance of the radio. Set it up where you plan to use it and test it. Make sure it performs to your expectations. Do that more than a couple times to get an accurate idea of the performance your getting and to sort out any weak links! For my use my good outside antenna is more than enough. I saved the battery power for charging the flashlights and the ladies cell phones. My lights never needed charging! On the last day without power the battery reached full charge so I connected my digital scanners and charged them up and the bank was still 100 percent full. I need a bigger battery and panels to go nuts with much power. My powerbank is small and has a 330 watt ac outlet which easily will run LED lights and small fans as well as ac chargers for all kinds of cells including my power tools. I found 5 watts from the KG-905G very adequate. With my antenna gain and low loss line ERP from the antenna is 20 watts+ with 4.5 watts into the feedline. Plenty enough for what I needed.
WRYZ926 reacted to a post in a topic: Base station radio
My first priority is getting some large LIP04 batteries, big RF-quiet inverters and charge controllers. And more solar panels and the wiring to make it all work together. Something big enough to run the refrigerator. Gas powered generators are cool but you need a lot of gas on hand. And oil. and maintenance. My system was designed for winter storm related problems, when you can put food in a cooler and throw it outside to keep it cool. I lost a lot of meat in 7 days of high temperatures. I could not cook it all. We ate very well at first. By the time we understood how bad it was, it was too late. Fail. In the first days information was impossible to find about how bad it was. This was not helpful to say the least. The isolation caused by roads closed by trees and the sudden absence of bridges cut people off into small pockets. Most repeaters went down...people who relied on them were out of luck. And it became obvious right away that very few had equipment to talk far away with power backup too. My wire antenna for HF was buried under maple limbs 6 inches thick in the backyard. Even the authorities had trouble because the state linked system lost so many links from landslides and river crossings of the fiber backbone. The digital P25 system was so solid with traffic some departments had to use local comms and stay off the main state system. No one planned for complete infrastructure failure. Plan accordingly. A seriously SHTF situation.
JBRPong reacted to a post in a topic: Base station radio
I live in West Asheville. Got internet back some hours ago. Things that worked great during the aftermath which featured zero cell phone service, no power, no water, no internet. Power was out 1 week. Water out for 2 weeks. Wouxun KG-905G with Nagoya 771G or Diamond RH77CA. I bought 3200mah packs for both HT's and they were charged fully as well as the original 2800mah batteries. I never had to charge them during 4 days of no cell service. I never had to swap out batteries either. I used one to scan to listen to work crews with a Laird FG-4503 antenna on the roof. It and the Bolton600 feed line went through the storm no problems at all. Wind rated to 125mph. A few days later I replaced the 4503 with a TE connectivity FG-4607...also 125mph wind rated. Giant improvement for listening close as well as far away! I only have the 2 Wouxuns so I gave my daughter a Quansheng K5-(8) Programmed with all gmrs and frs channels. We stayed in the first 7 channels and that radio performed flawlessly with it's stock antenna. It just sipped the battery and still showed full charge after 4 days of being used. Daughter much preferred the smaller "cute" radio. A solar power bank kept the cell phones charged as both ladies ran the batteries in them down as they fruitlessly searched for service. The electric chainsaw and other Dewalt XR power tools did all I needed and also did not need charging for the week with no power. Whatever base radio you get, make sure you can power it. Overkill on the antenna windspeed rating is also recommended! Both GMRS antennas I have used have one piece radomes. And a 5 year warranty. I bought a Midland MTX-500 because I wanted to test it and figured if it works ok it can be used as a mobile or base. It arrived on the Wednesday before the storm. On Thursday the antenna arrived...and I took a break from pumping out the basement to unbox it. Friday all services disappeared. The midland is extremely easy to program repeaters into without a computer and it has enough power into repeaters to work well. I never needed it during the blackout. The HT's were more than enough. Power output seems fine as it draws very close to 9 amps@13.9 volts into the 4607 on repeater inputs. It has 128 channels too. No tone scan, a major omission. Audio recovery is excellent on weak signals. I was going to buy a part 95 kenwood but it will have to wait for my finances to recover. The Midland is way overpriced...it cost more than my Icom 2730A which is dual band and has crossband repeat built in. And tone scan and so many other features its nuts. But it's legal and works well. The ANL is obviously a DSP noise reduction scheme that rapidly nukes intelligibility as you go past the lowest setting. The radio gets hot if you transmit a lot on high power. A small nearly noiseless fan I have on hand blowing air under the radio makes it stay nice and cool. The Midland never exhibited intermod or signs of overloading here before the storm when used with a high Comet GP-3. After the storm I heard some weird stuff that sounded like intermod but my SDR showed "someone" was using equipment that was a wide pulsed signal that moved around the band occasionally. It was heard on the Wouxun on the other antenna at the same time...as well as a Icom 8500. Not intermod. A strange out of place transmission. Only noted during heavy military air traffic. Its gone now...air traffic is much much lower. The midland is great for scanning as the audio is good and it is much less noisy than the Wouxun. It performs on par with the Icom 2730 as far as sensitivity. It actually has a useful signal meter that only goes all the way up for really close or ultra strong signals. The wouxun pegs its scale so early it is useless for determining when someone is very close. I like the Midland, even though it is overpriced. The Wouxun KG-905G and the Nagoya 771G are both very highly recommended...as is the TE Connectivity FG4607 and the Bolton600 feedline. Sorry if this post is a bit chaotic or unclear. I am still a bit disoriented. I used ham radio, GMRS, and the scanners heavily for information. I won't post some of the things I heard. Really horrible stuff. Much worse than the media coverage conveys. I fared very well actually. But others lost everything. Many others.
