31
Everything posted by BoxCar
Welcome to the group. You will find a lot of information regarding your radios and their programming.
Coax is easy to find and most of the sites selling radio gear are competitive. Places like The Antenna Farm, DXEngineering, Gigaparts, Ham Radio Outlet and many others are all on the 'net. All you have to do is press a few buttons and shopwith the coax being delivered in a few days.
Hints, suggestions, ideas, when programming a Wouxon KG905G
BoxCar replied to Bugkiller's topic in General Discussion
1. Load C 2. Connect programming cable 3. Start CPS program 4. Turn radio on 5. Set program so it connects to radio. 6. Read factory settings from radio 7. SAVE FACTORY CONFIGURATION 8. Create new code plug 9. Write to radio. 10. Turn radio off 11. Unplug programming cable 12. Enjoy -
Buried within CFR 47 are several statements stating it is permissible to use any frequency when there is an immediate danger that would or could result in the loss of life. I don't recall the exact section but I know the exemption is in part 90 and other parts. A few years ago (more like 10) an amateur operator was fined for contacting a public safety agency and reporting an emergency. That was acceptable but, what was not was he stayed on the frequency and continued to transmit after being told to leave.
The Commission has stated if Life, Health or property is in immediate danger one may use any frequency to summon aid. They have also ruled in the past that once the aid is summoned the emergency use exemption has been met and further transmissions are not allowed unless authorization is specifically granted by the responding agency. Once you contact an agency and relay the situation, the emergency is over as far as you are concerned and further transmissions are in violation of Commission rules.
I would put an RF choke (Ferrite ring) around the power cable between the T connector and the radio. Amazon.com : ferrite chokes
BINGO! You got it. As it is a treaty it has to go through the Congress Critters in the Senate who will do everything in their power to politicize it.
Good question. In the Part 90 world a fixed station is primarily used for data transmissions between two points. Fixed stations are usually used for automatic reporting of fluid levels in storage tanks, river levels and the like. They are primarily one way transmissions but they can also be two way such as the control station sending a command to open a valve or flip a switch.
For the price they're asking for it, plus freight to Alaska you may be better off with a Kubota or Deere tractor. The tractor would be more versatile than the single use dozer.
IIRC, international traffic is specifically mentioned in the rules as being permitted but there is no mention of domestic traffic between services. I have a feeling the FCC would frown on it and the ham is subject to contact by a volunteer monitor about questionable operation.
The only Part 97 transmissions allowed with no identified receiving station are CW and test messages.
The Enforcement Bureau is more focused on protecting the commercial users such as FM radio and cellular providers than individuals. They do go after major importers of equipment but not as aggressive as they used to.
If you get the 706 there is no pressing need for the 2730 as the 706 does 2M and 70CM.
There are several sites that provide reviews of units that can be used for a base station. Within your budget there are 2 that cover your needs from Icom. The IC-7100 is a mobile/base covering all bands but doesn't have the waterfall display. The Icom 706 MK IIG is available on the used market again, no waterfall but both are solid 100W units. You can get an SDR radio for fairly cheap that will throw up a waterfall display using a software program downloaded from the net. For my 2M/70cm work I use the ID-5100A and a hot spot for D-Star. Probably one of the best sources for an unbiased review is the ARRL. You may want to consider joining them for their wealth of information available. The other trusted(?) sources would be the ham equipment dealers such as Ham Radio Outlet, DX Engineering, Gigaparts and others. They will, of course, be biased to their new equipment lines but can definitely offer good advice on power supplies and antennas along with other accessories you'll end up needing.
Michael, Kindly show the world where there is an approved device that covers both the GMRS and CB frequencies and not a unit that covers frequencies outside those two bands.
Yes Michael, there are units that do cover those frequencies but Mr. KIA, the OP was asking as a person not licensed to operate that type of unit and specifically for a unit to cover just the GMRS and CB bands which there isn't a unit. So, quit being an idiot and address the question being asked in the frame it was asked. And further, the Yaesu doesn't operate on the GMRS or CB frequencies without illegal modification so the answer is STILL there isn't a unit that combines those particular frequencies.
GMRS is short range, line-of-sight communications but has a higher power output than CB. GMRS is also FM where CB is AM so the messages are much clearer. GMRS is able to use repeaters that improve the range and can be connected to form networks. Because the frequencies for CB are around 27 MHz and GMRS is in the 460 MHz area the two can't be combined into a single unit.
High SWR when tuned to repeater channels?
BoxCar replied to JFITZ7's question in Technical Discussion
Before you do any more to the antenna, CALCULATE what the length should be. There are several sites you can use that will provide an answer in either millimeters or inches. The adage measure twice, cut once always helps. The loading coil if used adds an even amount like a 1/4 or 1/2 wave so you need to be able to calculate the length of the stinger above the coil. The length is measured from where it comes out of the holder to the tip, not the physical length of the stinger so it needs to be a little longer than the calculated length. -
A used Part 90 repeater is a better investment. Units from Motorola, GE, or others are proven, solid units. Amateur units from Kenwood, Icom or Yeasu are also good candidates. The key piece for a repeater is the antenna. It needs both height above ground and gain. Gain increases the effective radiated power and improves reception. Gain is reported in either dBi or dBd. Dbi is imaginary while dBd is real gain as you subtract 2.1 from the dBi figure to obtain the real power increase of dBd for an antenna. Repeater life is measured by the duty cycle which is the amount of time the repeater is in use. Low cost units have a duty cycle or time spent actually on-air of about 20% or working about 12 minutes per hour. Part 90 units and amateur units will start with a 50% duty cycle and go up to a 100% duty cycle which means constant use.
Are you worried about scratching the metal plate? If not, remove the boot and check the SWR on the antenna.
The only way this could be done is by using the Internet to carry the traffic between repeaters. As you would need the Internet, why not use programs such as Skype or one of the video terminals from Google, Amazon or Facebook?
Repeater ID can be done in many ways but it doesn't need to be automated and broadcast when not relaying a transmission. The repeater would be properly identified if I stated this is call sign using repeater call sign or the repeater did transmit a CW id after carrying a transmission but otherwise remained silent. The reuirement is met.
Fattening the radiation pattern is a double-edge sword as it may impact your coverage closer to the antenna.
This is for your home base station? Are you having problems hearing with the Tram? The biggest factor on improving the quality of the signal is antenna placement. Changing antenaas without changing where it is located does very little to providing any improvements except in the area you already cover.
These radios aren't the Star Trek communicators seen on TV. They suffer from an entire range of issues regarding antennas, power output and terrain. First of all, standing where you are could you see where the repeater is? If there is anything blocking your view such as buildings, hills or mountains, fuggitaboutit. The second thing is if you could literally see where the repeater is, how far away are you? More than 10 miles with a clear line of sight is iffy at best. That's where output power comes into play - not only your handneld, but the repeater's output as well.Third is the antenna,the little stubby antennas on your radio is radiatting less power than your radio is rated at - period - statement of fact. How much the power is reduced depends on how the antenna is made and you aren't going to fix that. The primary key to increasing the range from any radio is how high above the average height of the terrain surrounding your radio. The HAAT (Height Above Average Terrain) of the antenna is the most important piece regarding range. As GMRS type radio waves radiate in a virtual straight line the range is how far away is the horizon from the antenna. By law, the amount of output power for GMRS is fixed so the theoretical range is also fixed depending on the antenna height. In other radio services the FCC uses the HAAT of an antenna to limit the output power. So, the range your radio has is limited by these three factors. Now, speaking of codes, a code is used to further limit the number of stations on the same frequency being heard. If the code does not match, the radio does not process the signal to the speaker. When programming in codes, do not limit your receiver to only "hearing" if a code is sent, most repeaters only use an input code which your transmit sends. So, leave the receive frequency set to no code unless specifically required. This is the most likely reason you can't receive a repeater signal when a transmit code is required. It's so easy to assume a receive code is also needed when in fact the code is blocking the signal.
