31
Everything posted by BoxCar
New to Radioddity DB25-G GMRS Mobile Radio 25W
BoxCar replied to Lifegood's question in Technical Discussion
Michael, receiver antennas don't need tuning as they are all band from one quarter inch stubs to mile long wires. Yes, the length matters in that a longer wire is more sensitive; but length doesn't affect the frequency range. You can prove this to yourself by using a simple piece of coat hanger or any wire connected to your radio and listening to the various stations on different bands. -
If the radio is GMRS transmit only I wouldn't buy a dual band antenna but one for GMRS. You can receive on almost anything as an antenna. -
To make a complicated subject a little clearer, the intelligence in an FM signal (GMRS is FM) is carried by the shifting of the frequency within its channel. Wide band signals can shift a total of 5 kHz while narrow band signals can shift only half that amount. The result is two-fold, the signal sounds softer and additional channels or paths for transmission can be created between the wide band channels.
Can Non-Licensed Friends Transmit Legally on a GMRS Licensee's Radio?
BoxCar replied to mrgmrs's topic in General Discussion
The application requires certain personal information and the person submitting the application certifies they are the applicant so no; you can't buy a license for another person. That does not mean they couldn't make the application and then you use your credit card to pay for it. It's the statement where the applicant certifies all the statements are true. Falsification is a federal offense. -
Could also be something as complicated as the volume knob....
Plans for Open Stub J-Pole Dual Band GMRS Antenna
BoxCar replied to DownEastNC's question in Technical Discussion
440 MHz refers to the ham 70cm band which is below the GMRS frequencies. A J-Pole cut for the 440 band would need to be shortened by a small amount to put it into the middle of the GMRS band. -
Setting up my Own repeater - Worth it??
BoxCar replied to htims05's question in Technical Discussion
Why not ask your Ham club if they want to install it? -
Truly the best solution is a rig built as a repeater rather than a home-brew setup. The key piece is the duty cycle of the repeater transmitter. It has to be active for both people and that means it is transmitting throughout the entire conversation. Your typical base station is designed around a 20% duty cycle which means you spend 80% of the time listening and less than 205 of the time talking. A 5 minute conversation is only a couple minutes for each radio but double that for the repeater. -
You can use this to calculate the RF exposure. It's now required by the FCC. RF Exposure Calculator (arrl.org)
Narrowbanding was mandated for the VHF frequencies below 174 MHz.
PL-259 will mate with the female SO-239. This is the same connector pair used on mobile radios.
Welcome Tim. GMRS/FRS is a viable solution for your situation. A small mobile unit set up as a base station at your home with an attic antenna would guarantee communications between the two houses. A 20 to 25W mobile is all that's needed (actually 5 watts on an attic antenna would probably work). Midland makes a 15W unit that would be perfect. Look on Amazon for a small 12V DC power supply with at least 15A of output and you're golden for the base. A J-Pole antenna is what I'd use, there are several different ones available. Here's one made from copper pipe rather from twin-lead plastic cable: 462 MHz Land Mobile (GMRS) J-Pole Antenna - KB9VBR Antennas (jpole-antenna.com)
I believe it's called the ping-pong effect when one repeater starts keying another and they bounce back and forth. Other than different codes or powering down there isn't a way to stop it. Cell companies had the problem when private repeater nodes started appearing. Thet could shut the feed down to an antenna and then send the FCC to cite the repeater operator for an illegal transmitter.
Comet, Diamond, Nagoya are just a few that make replacement/upgrade antennas.
Ham repeaters in my corner of NC are a mixed bag as far as tones. Some use them, many do not. N2GE, the repeater on Mt. Mitchell which reaches into 4 states does not use tones along with our club repeater, N4MOE on Mt. Spivey. There are 3 repeaters on Bearwallow. Two of those use tones, the UHF and the GMRS.
Quality isn't free. It takes time and money to develop many of the things you believe should be available in a $20 radio. Some of those features may, at some point, trickle down to bottom tier radios but it would only happen after the costs of the initial development and testing had been paid for. Bottom end radios are just that, bottom end. Many are poor reverse engineered copies of more expensive offerings by other manufacturers but then again, they are poorly engineered copies that will not have any quality components or testing other than it powered up - sometimes.
As long as a licensed operator is "in control" of the station it is permissible for an unlicensed person to use your radio. In other services, the licensed operator would establish contact and then hand the mic to the other person. While the rules are a little vague, the use of a call sign is limited to the actual person holding the license. That does not preclude an unlicensed person calling your call sign and identifying themselves as "Unit X." -
FCC Report & Order - GMRS License Fee Lowered to $35
BoxCar replied to WQPT412's topic in FCC Rules Discussion
The PDP-11 was referred to as a mini. Mini computers were often rack mounted and performed many of the same tasks as mainframes. These were displaced by the PC coming on the scene. Minis were quite prevalent beginning in the early 70's thru the 80's. They were almost all gone by the early 90's. Digital Equpment or DEC was one of the biggest manufacturers of those systems. Some of their models were the PDP-7, PDP-8 and PDP-10 along with their flagship PDP-11. The different models had various capabilities with the -7 being the least powerful. These systems often acted as front ends or pre=processors for many mainframes from companies like IBM. Univac, Control Data, Burroughs and others including Xerox. I spent 10 years with a mini manufacturer, Four Phase Systems. Our systems replaced a great many IBM terminal systems preprocessing key punch data and acting as print spoolers routing printer output to various printers scattered around different locations. -
A good portion of the support costs for a product can be distributed over a group of radios using common components and design firmware in the unit. That would allow products such as programming software would have a common core with modules linked in for different versions to support addition features on higher end units.
There is allso the issue of support costs. Developing the necessary infrastructure to support a radio that retails at a low price point can end up costing the company more than sales returns.
Check for a local radio shop. Any shop that handles Motorola should be able to do the work for a small fee.
Antenna in the Attic solution, help with parts and connectors
BoxCar replied to pcradio's question in Technical Discussion
If you have enough space, why not put in a base station antenna with some gain? There are several that don't require a ground plane as the have radials that are only a few inches in length. Your best bet would be to plan for the future and get a dual band if you want to take the ham Technician test. The ham 440 band is just below the FRS/GMRS band. -
It depends on where the repeater is installed. Remember, height equals coverage area.
Start with HRO (hamradio.com)
If you have the circuit board with the failed parts out of the case, take it and the parts to ay radio shop and ask them for a quote to replace the components. They may do the work for only the bench rate as there would be no disassembly or testing involved.
