WSEZ864
Everything posted by WSEZ864
  1. I'd have to wonder if the OP's battery is deteriorating and causing the high voltage as the regulator is trying to charget. No matter, the whole system should be checked. Here, we have a "Battery Warehouse" battery store that provides free testing of both the battery and charging system - takes 10 minutes while you wait.
  2. Sounds like the violator had better be VERY careful in his response letter to the FCC. Should probably send them a pic of the radio with a bullet hole through it, LOL.
  3. No, not GMRS, ham. Sorry for the crossover.
  4. Our club owns several repeaters, which operate under the club call sign. A "trustree" carries the club license (and responsibility) for their operation. ETA: Clarification - referring to amateur radio repeaters.
  5. True, the small ones definitely do have their limitations when used alone. I've standardized my 12VDC items with Anderson PowerPoles and made up a bunch of PowerPole 'Y' pigtail connectors along with several 'extension cords' so that I can parallel several of the smaller capacity batteries if need be. Also handy when topping off multiple batteries
  6. Gotta be careful with Google AI with these technical/administrative questions. I've been trying to help a blind Canadian immigrant get his US ham license. Due to the difficulty in studying, he is having great difficulty with the Tech exam and after unsuccessful several tries, he was looking for an easier way. Google AI told him his existing Canada license can be 'converted' to an equivalent grade US amateur radio license, which, after much legwork and investigation, we determined is NOT true. The actual situation is that one must pass the US exam to get the US license. Period. The corollary is that he CAN operate under a reciprocal agreement using his Canadian ticket while in the US until a) his Canada license expires, or b) until he becomes a US citizen. I think this is the point Google AI misunderstood and misrepresented - reciprocation vs conversion. Bottom line: Google AI rendered incorrect information that gave the guy false hope and took us a couple weeks to clear up.
  7. I've been lucky to have a friend in IT that services corporate computer systems. They are always having UPS units dying off, most of the time due to one 12v9ah battery in a bank of four going bad. Most mid-size UPS units have a two (12ah) to four (9ah) battery pack that is replaceable, but often costs almost as much as a new UPS. The corporations typically just want to replace the entire dysfunctional UPS rather than making internal repairs, so my buddy just swaps them out and saves the bad ones for me. I check them out and once in a while can make a repair, but usually just strip the batteries out, test them and dump the bad battery. As a result, I have couple working UPSs laying around, plus about 175ah capacity in small 12v batteries, mostly 9ah I've scavenged, but also a few 18-22ah batteries I've bought. About once a month I'll rotate the individual batteries through a quick charge and top them off by plugging them into my bench power supply as I run radios. Most stay near 12.8v between charges, but as soon as I see one go below 12v, I know it's on it's way out.
  8. Your contact was looking for a serial number that YOU assign to your contacts during a contest. In your case above, you could have given him any number, but 001 would suffice. If I am responding to CQ calls on any given day, I number my contacts starting with 001 and if anyone should ask, I tell them what number I have assigned their QSO. Typical QSO verification involves: Call signs Band/Frequency Time Signal reports Serial numbers
  9. I'd agree with the advice to use a radio with a detachable faceplate/control head. Lido makes a bunch of radio mounts. I had a 2012 F-140 4-door and used the seat bolt mount mentioned by WRYZ926. Worked great with a Yaesu Ft8900 remote head. Maybe poke around at the Lido site, click on "Radio Mounts" and see if something grabs you: https://www.lidoradio.com/ I've hung the radio body ("brick") under the driver's seat on all three of my F-150 installations ('07, '12, '20). Lido makes a mount that inserts into the CD slot, which I used in my newer truck with a home made block with a slot cut in it that sits in an unused console compartment.
  10. Maybe so, but it didn't look like it on mine. Mine has the retractable cover inside, side-curtain air bags, plus the regular glass window and by the time I avoided all of those items, I decided it wasn't worth trying to squeeze in there. The truck body is also aluminum and rather soft, so I was already on the edge of not using an NMO on the roof. https://www.ar15.com/forums/outdoors/Installing-Antennas-and-Radio-on-2020-F-150-Crew-w-Sunroof-Now-with-Moar-BackRack-/22-705121/
  11. I considered buy one of those mounts for my 2020 F-150. It too had a sunroof that precluded installing a regular NMO mount. I installed a "Back Rack", which I use to haul canoes, ladders and lumber anyway, and mounted two antennas on the vertical bars at the sides. VHF on one side, UHF on the other. The Back Rack is bonded to the truck bed and the bed is bonded to the cab. I brought the cables in under the rear seat, under the carpet to the front seats, where my radios are hung. Works 'OK', but not quite a well as the NMO in the center of the roof on my last truck.
  12. Draw schematics, answer unanticipated questions AND send/receive Morse code AND travel to the nearest FCC office to take the exam. I could have never done it. It is taken for granted that the exams these days, especially the first one, are essentially a "license to learn" and one really doesn't start really getting into it until they start working with it. I agree that memorizing the answers is really the most expedient way to get licensed. It's a large pool of questions and they are not the same on every exam. We have a least 4 exam versions for every license level, might be more. Studying the test questions actually does provide a bit of education. There are several online study sites with practice exams and flash cards, so studying now is easier than ever. To pass the Tech and General exams, one has to answer 26 our of 35 questions correctly.
  13. As a lifetime avid outdoorsman; hiking, camping, hunting, rifle matches, fishing, boating, and other activities, even a little 'off road', holder of several commercial radio licenses, licensed GMRS operator, NWS spotter, an FCC Volunteer Examiner AND a relatively seasoned ham radio operator, my opinion is that your statements above are not a true picture of either "hobby". Learning more about ham radio may be of benefit...if nothing else, perhaps you would know what you were talking about. Ever notice all of the talk here on this GMRS forum about clubs and nets and linking repeaters and setting up repeaters? Those aspects of GMRS have "ham" written all over them. Not being critical at all, but simply pointing to the elephant in the room. I think they are more closely related than some care to admit. In spite of the denial, I believe a lot of members here DO look at GMRS as 'ham lite', a low-tech shortcut to radio commo - I think that's great, and if the interest persists and deepens, there is a lot that can be done if one decides to move on to amateur radio. Yeah, yeah, there's a test. So what? As a VE, I work with a small group that gives the exams and I assure you that it's not near as bad as rocket surgery...we have kids as young as 8 or 9 passing the Technician exam. I am new here, but even then have seen MANY people asking questions indicating they have bought the license and the equipment, and would like to use it to find active repeaters, some with nets and clubs, in order to make contacts with people outside their social circles and caravans. That approach in no way takes away from the fact that many, maybe even most, GMRS users use their radios during their other activities, or those users that simply want to stay in touch with family members while they're out and about. Perhaps unbelievably, ham operators also use their mobile radios during their activities and to chit chat with acquaintances while commuting. I will say that with ham radio, the equipment and technical knowledge actually IS the hobby. If one is interested in electronics, it can be quite interesting. Almost everything about ham radio is geared toward learning about radio operation, propagation, building your own antennas and other technical aspects, and the results are measured in contact quality and distances. I am a former radar repairman and also built and serviced surveillance receivers and test equipment for a manufacturer. This ham radio hobby is an extension of that and right up my alley. Like GMRS and CB, simply another face of the radio hobby. Electronics and radio science is not for everyone and I get the idea that many people just want to use the radio as a tool without having to learn any more than necessary. I know a lot of people like that and that is one factor that led me to setting up GMRS - this radio service allows me to talk with my brother and sister outside the infrastructure, neither of whom wish to be ham radio operators. Many members of my ham radio club are also GMRS operators. No one hides it and we simply look at it as another tool in the box. Sorta the same with CB, although most of us avoid CB due to it being a zoo here. That didn't stop me from installing a CB here at the house and wiring an antenna in my truck for when I want it on the road. Civil uses of ham radio include operating safety checkpoints for marathons, races and organized hikes, weather warning/monitoring like the National Weather Service's dependence on spotters to help calibrate equipment (radar sensitivity and resolution) and to provide instant warning of severe weather developments. There is overt emergency response via groups like RACES and ARES. Our county emergency services work with us and even sends the commo truck out for our field day events. Our repeater covers a tremendous footprint and in the event of an emergency or severe weather becomes dedicated to public service. It runs on a generator and then batteries when power drops out. Our club is one of several in the area and just between our members contacting members (we can just go simplex on the repeater input frequency), we can cover a tri-county area. The maligned "POTA", "SOTA" and other temporary activations like "Field Day" are as much about determining how to operate in austere conditions and how to make solid contacts under tough conditions. Oddly enough, I see some of the same goals with my fellow GMRS licensees, "portable ops", "emergency contacts" and other terms are interchanged between these closely related radio hobbies.
  14. This part is probably the craziest thing I've read this week, and I spend a LOT of time reading. Tell us you know nothing about ham radio without saying that you know nothing about ham radio.
  15. One major reason a repeater hangs for a short time is "picket fencing". When a mobile unit is traveling and experiences a short dropout, the repeater doesn't immediately abandon the signal and stays engaged. This both provides unbroken coverage benefit for the mobile and provides a bit of a safety delay so the repeater doesn't get hammered with rapid on/off cycling. @HHD1: The expression "squelch tail" describes the "dead air" hang time after an incoming signal drops and has released the repeater. This delay is often followed by a sound signal ("beep") as the repeater ceases transmission.
  16. If that's all that's stopping you, there are workarounds... I use the QRZ.Com logbook function and it's very easy. If I'm on the radio looking for contacts, I start out by logging in to QRZ and opening my own logbook page. When I hear a station I might want to contact, I look up their call sign on QRZ and decide whether to try them. On their QRZ page is a button that says "Log a new contact with _____". If I try them and succeed, I click that button and the contact sheet that pops up is already populated with most of the needed info. All I need to fill in is the frequency and signal report, hit 'enter' and it's done. I used to use a paper log. I have a dedicated clock set to UTC, a formatted spreadsheet with required info blanks and would write as much info as possible. Using QRZ is a lot faster and their logbook function is pretty flexible for sorting. I think one can even upload directly to LoTW, but I don't bother going that far.
  17. Just did a quick fixit for you. UHF actually starts at 300 mHz.
  18. I would only add to marcspaz's post that this past weekend's contest was about "working all prefixes" and the contesters' goals were to talk to as many different areas as possible. Contest traffic really can be a pain in the neck, but contests also offer great opportunity to talk to many relatively rare countries/DX entities that might not be on the air otherwise. This can be important to those who are trying to make contact with all of the possible DX entities and/or all states. I don't actually participate in the competitions, but do occasionally take the opportunity to make an unusual contact.
  19. Most repeaters are 'tone coded' (CTCSS) and not DCS. Double check your repeater's requirements.
  20. I have two ground planes mounted above one another on a single PVC mast mounted to my chimney. The top antenna is for 2 meters and the lower one is for GMRS. The top of the lower antenna is about 12" below the bottom of the upper antenna. No noticeable interaction.
  21. Just checked - back online this morning.
  22. Doesn't seem to be working. I've never had trouble reaching it and just now tried a test with no response. Either down or a new tone.
  23. Every 15 minutes and, as you say, at the end.
  24. Amphenol.
