270
If what that person said is "the FCC does not allow new GMRS repeaters", then that person lied to you or is an idiot - likely both.
I would have to consult the manual for that one.
Those tones sound familiar... My guess is that you have the tones backwards, OR it's actually working the way it is supposed to.. Be sure to enter the 271 on your radio's TX and 073 on your radio's RX.. Note that these are DCS/DPL tones, not CTCSS tones so make sure you are putting them in the right place (consult the manual). Leave the RX (73) out for troubleshooting.. If you enter the TX (271) and can hit the repeater, then you should be good. When you enter the RX (73) then you should then ONLY hear transmissions from that repeater and nothing else - this is optional.
Sounds like the door-chime at my local Kwikee Mart.
Look up your local repeaters and get them programmed in!
How do you plan on setting up your MXT500 as a repeater?
Just call me BoZo ..
Welcome to the forum and welcome to the wonderful and exciting world of GMRS! Word of warning: Soon you'll be selling a kidney to buy every new radio you see those clowns on Youtube playing with...
I own and use all 3 of those radios, and they are all great. The 9G Pro is a bit more complicated than then 905G which is very simple & easy to use. The 1000G is probably the best GMRS mobile unit you can buy today.
Sounds like a good setup - try it and see how it works! I'm using an old/used VXR-7000 repeater with LMR400 coax, PL259 connectors, and a Tram 1486 antenna - I have a good/high location and I get a range of about 55 miles - it would be further but I'm surrounded my mountains.. Location more than anything else will determine your range but that tower should help. Be wary of "some people" that will leave comments and try to drastically over-complicate everything trying to impress us.
make sure you have correctly plugged in the mic into the correct hole. Plugging the mic into the wrong hole may cause this. Also make sure you have the faceplate correctly plugged in with the correct cable and in the right holes. If after confirming that and trying any tips that others post its still not working right, call BuyTwoWayRadio and they dont have an answer they will send you a new one.
Yes - if it is still under warranty they will replace the radio.
This behavior is by design on the 7000.. If nobody uses the repeater for a while it wont ID, but as soon as someone starts transmitting again it will ID again while the repeater is in use.
Assuming you purchased from BuyTwoWayRadio, call them and they will replace the radio.
1) A "Repeater channel" is a combination of two channels - a sending channel, in the 467Mhz range and a receiving channel in the 462Mhz range. The receiving channels are shared with some of the 'regular' channels, so you can hear someone talking on Repeater 24 on CH16, but if you transmit back on 16, they (likely) wont hear you. When you put both a TX and RX tone on Ch24, you are setting the radio to only listen to Ch24 repeater traffic. If you want to listen to ch16, put the radio on Ch16 OR, dont enter a RX tone on Ch24 2) Depends on what "emergency channel repeater 20" you are referring to - But in general, you must enter the correct TX tone to use the repeater. As eluded to in #1, adding the RX blocks out all other traffic except for traffic using that tone - so if the repeater is transmitting with a tone, if you DONT enter that tone you would still hear the repeater, and you would also hear anyone else talking on that shared channel. If the repeater does not transmit a TX tone, and you enter a tone (or enter the wrong tone) you wont hear the repeater - you will only hear transmissions that are sending the tone you've entered. Since you're new to GMRS, it is my job to make sure that you also know about Channel 19 (no tone) which many people use as the "unofficial official" road and travel channel, and Channel 16 (no tone), which many people use as the "official" off-roading/hiking/adventuring channel. Also be aware that "some people" will prefer to argue over the use of those channels rather than actually do/say anything helpful or constructive - just remember that nobody cares what the complainers have to say so you can ignore them - dont worry, they'll be easy to spot. Welcome to the forum and welcome to the exciting world of GMRS!
Sorry - I thought you wanted to be able to PTT to talk back? In that case, SE is better? Either way, use what works for you and enjoy the radio - The 935G is my favorite GMRS HT.
That sounds like the radio is scanning, and it gives you 4-5 seconds to respond before scanning resumes. So on the 935G you would enable scanning and set the scan mode to "SE" in Menu option 15) . You can optionally select a priority channel as WRPD494 mentioned. With Menu options 18 and 19.
Thats not the real-world that I live in, so i'm glad to see that for everyone like me not in an RF-heavy urban environment, the radios dont "suck" .. Because at first, based on your statement, us non-techy people might have misunderstood you to be saying "they suck", which it seems is not the always case, so thanks for clarifying.
I guess you'll need to provide us with the technical definition of "suck" - because i've used/use dozens of these cheap/SOC radios and they all work just great for my needs - and millions of other people seem to agree.
Kg-1000g faceplate install overhead Jeep Wrangler
OffRoaderX replied to austinpa's question in Technical Discussion
Yup! Just sheet-metal screwed it right into the freedom top - but that wont work if you like taking your top off. Tossed the chassis under the passenger seat. -
I always use the -d switch, and it does nothing for the narrowband mandate, the only way around it on the version I am using is to change the clock.
For someone new to GMRS, I always recommend staying away from non-GMRS radios (ie commercial radios), until you've learned the ropes.. Remember the warning on my earlier reply about "some people" ? But, its good to know all options and then make the choice thats best for you.
I have never messed with any of those settings on my 7000.. For me, those are in the "if you dont know what they do, dont F with them" category.. The only other thing you might want to enable is the Courtesy Blip, aka the RRB or Repeater Roger Beep. The narrowband thing is a PITB .. To get around it you have to set your computer clock back to something like 2003 before you open the software - then you can keep your wideband setting.
I own and have used every one of those radios... All are great radios - Except for the 50X1 - Scratch that one off your list. Its overpriced and VERY limited in its features and in my OPINION, it is not worth the price - and you will never actually get 50W out of it. The XS20G is a great (very) little radio. The UV9G Pro is a great radio - but also very complicated.. Same with the 916 (I have one, it will be a long time before you can get one)- But if all the pre-programmed SHTF stuff is what you want/need, then either is a great choice.. I would recommend also considering the KG-905G OR the KG-935G. The 905G is SUPER simple.. the 935G is a little more complex/does a little more, but IMO, still easier than the UV9G or 916.
Welcome to the forum! But watch out for "some people" that will try to grossly over-complicate things when answering even the most simple of questions in sad attempts to show you how smart they think they are. Superhet receivers are generally "better" than cheap SOC type radios - but most people would not notice any difference.. I would worry more about features/what the radio can do more than the receiver type, but thats just me. On wattage, unless you are looking at a huge difference like 25W vs 5W, you aren't going to see much difference in range - for example, the only thing you would notice on an 8W radio vs a 5W radio, is that the battery will go dead faster on the 8W. For the antenna, almost anything will work better than the rubber ducky on your 5Gs. You didnt say if you wanted to upgrade to another HT or a base/mobile type radio - if you post what you're considering we can give some feedback on the exact model.
