28
UHF frequency antennna ( 462 mhz ) tuned to what VHF frequency
wayoverthere replied to Elkhunter521's question in Technical Discussion
agreed...makes me wonder how good that SRH701a that came with my vx7r is doing (though i usually swap have a srh320a triband on instead, or occasionally the 940 to see what little there is to hear on 6m). or diamond in general... (moving the mostly off topic musings to another thread...) -
That sums it up well ?
Yeah, @rdunajewskican get it squared away, one way or the other
I have a baofeng uv5r (older, unrestricted) that we use as a scanner, though admittedly it doesn't scan quickly. That said, we only have maybe 8-10 channels programmed. Chirp had checkboxes on the settings tab to disable tx. For my LMR stuff, I used weird splits to dump any unintended key-ups on either gmrs ch 1 (which is just mess of kids kerchunking and pounding the call button on bubble pack radios here) or one of the murs channels.
New to GMRS, and need help with connecting to repeaters.
wayoverthere replied to WRTS290's question in Technical Discussion
Usually the simplex (transmit and receive on the same frequency) channel for 462.725 is named something like GMRS22, while the repeater (or duplex) channel, named something like REPT22, has the offset needed to use a repeater preset. (Your radio transmits on 467.725, and receives on 462.725). Nearly all repeaters also require a tone; this is basically a filter on what the receiver hears, and only signals with the matching tone get through, everything else is ignored. If the repeater uses tones, you'll need the right one for it to hear you. Using one on what you receive is optional. You'll do this on the repeater channel that he's the frequency you want to use. In terms of knowing if you got in or not, you may hear a bit of static, a tone, a transmit with no audio (known as a squelch tail), or the repeater may then identify itself, verbally or in Morse/CW. -
I don't have it in front of me, but I want to say chirp defaults values into all of those fields, but ignores some based on your actual tone settings (ignores dcs when tone is selected, ignores ctcss when DCS is selected, etc).
I'm not seeing anything that stands out as an issue, though I'm looking on a phone screen. Are you getting some indication that the radio is indeed transmitting on channel 31? The v2 should be able to create some new tx channels, but I might try manually programming the tone via the menu in slot 30 (rept22)...t-ctcs should be the menu item you want. The v1 and 50x1 did not allow new tx channels, and a firmware glitch preventing tx is a distant possibility. That aside, the description looks like it's a rather short range setup, and may be up or down sporadically....it being offline temporarily is entirely possible
? Looks like one application was dismissed, but the second granted a couple years ago...the gmrs call sign he signed up with lines up with the ham one of his username. Certainly quick to jump on his soapbox though...stellar first impression.
Great presentation, Marc...well organized, and no fluff or foolishness.
Looks like xpr7550's
Is my SW-102 and/or DB25-G working correctly?
wayoverthere replied to WRQV528's question in Technical Discussion
Same here...pretty spot on between the sw102, sw33, and nanovna. -
I think that means the red tape of talking the city into bankrolling the cost of equipment and/or tower placement, not the gmrs side of things.
It probably will be, it's been showing it's age and I don't even know if I can still get toner for it. (Circa 2000 or so Samsung laser, on clearance from CompUSA).
I can't say what the community is like in Tampa; some areas you'll find the hobbyists, sometimes dual licensed hams, willing to chat with whoever. Other areas people stick to their group more, and just use the radio as a tool. I see a few open repeaters around Tampa that may be usable. On the possibility as a scanner...at least the public safety stuff for Hillsborough county looks to be all 800mhz, so probably outside the capability of the radio you're looking at. A dedicated scanner may work better if that's what you're after. That said, there's a fair bit of ham stuff around Tampa on repeaterbook, and the radio you have your eye on will be able to pick up some of that. If you went the ham route too, you'll usually find more people to just shoot the breeze with (aka ragchewing) than on gmrs. I'm in the same boat with no inbuilt group to talk to...the family has basically ZERO interest in radio....my area has a few hobbyists and a couple repeaters, but I made the jump to ham as well.
Sounds like a match made in heaven ?
When I first set up my btech, I had the 1/4 wave antenna sitting on top of my printer, mag mounted to a piece of sheet metal. When I keyed up, the printer woke up and printed a page of gibberish characters. ? Setup has since moved, and the antenna is on top of a bookshelf now.
Is the Baofeng GMRS-9R the fully fixed version of the Baofeng UV-9G?
They've been pushing the tacticool folding tape measure antennas on Amazon for awhile...perhaps they've decided to take a shot at what btech has done with baofeng and what btwr and others have done with wouxun... spec'ing a run of certified/certifiable radios? The telling part would be whether there's another source for that model besides Abbree. If not, custom spec is probably what it is....for Baofeng, its a win because they just make the radios and ship them, Abbree takes the risk on whether they'll sell or not. -
I don't see it listed as supported, nor the radioddity gm30 it seems to be twins with. https://chirp.danplanet.com/projects/chirp/wiki/Home does look like the gm30 is being worked on though: https://chirp.danplanet.com/issues/9237
There's a few addresses around here that show up on 2 or 3 dozen licenses....they're box numbers at the local UPS stores.
If you're looking for an easy starting point to start testing, a mag mount may be a good bet...nmo is very common for the antenna connector, and you'll have no problem finding a variety of sizes of antennas to match up to it. Lip mount is another very flexible option. In terms of antennas, anything rated for 450-470 or 460-470 mhz should work fine. One consideration to ponder is overall height: desired mounting point and antenna length. Generally more gain means longer antenna, and also means less vertical height of your signal. 1/4 wave antennas are around 6" long but depend on a bit of metal around the mount to work properly (about a 12" diameter circle). 5/8 wave run around 12" and are a bit less dependent, you can also find 1/2 wave that don't need a ground plane. Midland's 6db whip isn't a bad choice, 2 5/8 waves, but also close to 3 ft long. (Imo, a 1/2 or 5/8 wave, sometimes labeled as 3db gain, would be good starting point, since it's reasonably short but still has some gain). At the radio end, most mounts will have a pl259 (the male side, or PLug) connector on the radio end of the cable (also known as uhf connector); this mates to a so239 (female side, or SOcket) on a mobile radio. For your use you'll want an additional pigtail with so239 to either sma-m or sma-f. If the antenna on your uv9g threads into the radio body, the radio is the sma-m, and the antenna is sma-f (so get so239 to sma-f). If the antenna screws onto a connector that sticks out of the radio body, the radio side is sma-f, and you need so239 to sma-m).
Wattage limit via cigarette lighter plug?
wayoverthere replied to Chilango's question in Technical Discussion
Well, pending hands on testing, it looks like they've made an effort to address the weak point ? -
While the 12v socket and what it can handle is definitely important, that part of the circuit is easy to determine, either from the owners manual or the fuse rating; likewise, you can spec adequate wiring from the radio to the plug, and have reasonable assurance it can handle the load. The hazy spot is the internal construction of the 12v plug itself, and the spring @Lscottomentions inside the plug that allows the center pin of the plug to move and maintain contact with the positive center conductor in the socket. That spring conducting between the radio side and the pin contacting the socket is the big unknown. If I had the socket to support a big draw, and really wanted to use a 12v plug, I'd probably want to add a better connection inside the plug, between the wiring and that center pin, so it isn't dependent on the spring for current, only keeping the pin in contact inside the socket -
The 50x1 and v1 also program with chirp..on those there simply isn't a software setting for transmit or no transmit, it's set in the firmware and I've not found a way to override that. I will note my uv5r based radio have a "tx disable" setting on a band-wide basis, vhf and uhf. In the case of your gt5r, does baofeng have their own software for it? If it's a very recently certified version, it may be that the chirp isn't quite compatible with the new firmware needed to lock it down for part 95 certification. That lines up with the info I found on radioddity.com as well. 2m/70cm only, rx only outside that.
That may be it right there...What info i'm finding on the GT-5R seems to indicate these are locked down to transmit on ham frequencies only, which would explain why it's not allowing transmit on GMRS frequencies. That aside, if there's a GMRS legal version of the radio that i'm missing, it may also depend on the method used to lock them down for part 95e compliance. While they've made some progress with the GMRS-V2, the earlier Btech models (GMRS-V1, GMRS 50x1) forced compliance by not allowing the user to program ANY additional transmit channels. They got the base 30 (22 simplex, 8 repeater) from the factory, and anything else added by the user was RX only, whether it was in bounds for GMRS or not.
How did China corner the GMRS market, and why?
wayoverthere replied to WRQV528's topic in General Discussion
There's the added wrinkle of that requirement of not being able to operate in unlicensed services that I believe was added when GMRS moved from 95a to 95e. For the 450-512 radios, no real issue, but, but the 403-470, and some of the newer crop that do 400-512 out of the box...no go. Starts limiting how far they can spread that certification cost
