28
Midland MXT-115 Micromobile TX Tone
wayoverthere replied to randallbonin's question in Technical Discussion
It uses the tone entered for both tx and rx. -
My one experience with them seems to imply they aren't a US company; radio came with a pile of customs paperwork for it and the extra battery, and my card hit me for a foreign transaction fee on the transaction. (Caught a deal on a gd73 with hotspot for like $5 more than a hotspot normally goes for)
CTCS and DCS repeaters codes for Midland MXt 115
wayoverthere replied to jk06's question in Technical Discussion
Only if the repeater your eyeing uses dcs for access. Dcs and ctcss are just two different sets of tones to control repeater access. Think of it like a filter on the repeater...it only hears signals with the right tone, everything else it ignores. You just have to match the tone to what it wants to hear, and it sounds like you're on track with ctcss. The mxt115 sets the tone you program for both send and receive (In your case, ctcss 103.5). Does that help a bit? -
Glad to help. I had been looking for one for my mxt115 in the past too, with no luck, but this time google turned up a page of power connectors (with photos) that gave me some new leads. https://helpful.knobs-dials.com/index.php/Common_plugs_and_connectors#DC_connectors.2C_EIAJ_power.2C_coaxial_and_more
Did a little digging an turned up some possibilities. Some places call it a 2 pin molex, which turned up this: https://www.amazon.com/2-Circuits-093-Connector-Matched-Hanging/dp/B074LSHTC6 Other sources call it a taimya connector (used in rc and airsoft), which found this: https://www.amazon.com/FLY-RC-2Pairs-Battery-Connectors/dp/B07VL2B5C8/ref=mp_s_a_1_5?dchild=1&keywords=tamiya+connector&qid=1615396940&sr=8-5
Range function in freq mode for Btech GMRS v1
Unless you're adding an extra listen only channel, those (I'm assuming they meant 462.550, since 462.500 isnt one of the assigned gmrs frequencies) are already programmed by default as Rept15. You'll just need to set the appropriate tone. -
Looking for low-loss NMO mag-mount
wayoverthere replied to WRKU973's question in Technical Discussion
Glad to help! I saw the same options from pulse/larsen, but my phone wasn't playing along with being able to link the pdf brochure that showed all the model numbers involved for the sma and unterminated versions.. on the BR-195, i didn't find any actual description either, though i suspect it may be Browning's version of LMR195...it may be one of those trademark workaround things, since in researching, i found mention of the LMRXXX line being Times Microwave products. -
Gotcha. Back to google and found a couple options in addition to what dx engineering offers: Antenna farm lists a rg8x mount, and this one claiming low loss br195 cable: https://www.theantennafarm.com/catalog/index.php?main_page=product_info&cPath=264_265_273&products_id=8079 Arcadian inc also lists pulse/larsen with lmr200 cable and an n connector (pulse/larsen also lists a sma version and a no-connector version) https://www.arcantenna.com/products/pulse-larsen-nmommr200n-nmo-magnetic-mount-12-foot-lmr200-cable-n-male-connector?variant=32296826601603 -
It's a little more than the one pictured, but some googling found this laird that's a pretty close facsimile of the mxta10, though this one is 1/2 wave, supposedly. https://allterracentral.com/antenex-3db-gain-radio-antenna.html More digging also found this Tram at the antenna farm, for a couple bucks cheaper: https://www.theantennafarm.com/catalog/index.php?main_page=product_info&cPath=191_192_196_214&products_id=1564 -
If amateur radio is your thing, they're usable for ham once you have that license. You can listen to anything and everything they'll pick up, it's just transmitting that's a no-no. So they make decent low buck scanners, either for public safety (if your area is still unencrypted like mine is), or for frs/gmrs. For gmrs, you could use those baofengs for monitoring to conserve battery on the other radios, and then jump on the approved radio to respond if you feel the need.
yeah, given the need to install drivers, and the amount of poking at the comm port settings needed to get going, i'm not wholly surprised the Antenna Farm one didn't get along with the EVX. noted on Anytone stuff though...they look SO tempting on the surface, but this, plus all the other quirks (was reading something about how they implemented scan, and another thread about ongoing unfixed software bugs) seems like a lot of reasons to pass.
I'll say wouxun's isnt stuck in my head as being horrible, roughly the same as chirp imo. My vertex stuff was a bit more challenging, but a good portion of that is due to a lot more features and settings to go through. Hit a brick wall at first with the evx, but it came down to having some out of band frequencies the radio didn't like...jumped to the vx mobile, and that went smoothly, and when I jumped back to the evx I had a better idea what I was doing. apparently what reads from the radio says they're 450-512 band split, not the 400-470 the seller indicated (unless I botched something). So not good for ham use, really, but solid reception for gmrs. The mobile is good to go though. On a side note, I took a gamble on an ebay cable (bluemax49ers) for the evx before throwing down for the oem, and is working well so far. Bluemax didn't have them in stock for the mobile, so I got one from antenna farm that needed a driver install, and some poking at the port settings, but it's been good since.
Think of it as listening to two people talk at the same time. If they're both standing side by side, it's hard to pick out one over the other. If you put a barrier between them, and stand on one side or the other of the barrier (the filters repeaters use) you can make out one easily. Likewise, if they stand far apart (vhf vs uhf), you can more easily pick out one without the other interfering too much
I will second mbrun. If you have/can get a clear line of sight to the repeater, 40 miles is doable. I have two at 30 and 60 miles out on the hills on the either side of the valley I'm in, and I can get into both solidly, though with my antenna being in the attic takes full power to get into the far one consistently.
I ran to this on my 50x1 too, though it doesn't seem to work right. Was looking for a recent post I saw about it, but didn't find it (might've been on the book of faces or reddit). Doesn't seem to work right on mine, even if I start typing in the vhf range, it jumps and starts scanning uhf. I suspect something left over from when they redid the firmware from the ham versions (50x2) -
Wouxun KG-805G Stopped RX-ing/TX-ing after using CHIRP.
wayoverthere replied to MozartMan's question in Technical Discussion
Glad his codeplug was able to get you sorted! Way to go Mac! -
Vince, Thank you for taking the time to clarify.
Just found that in btwr's response here ..damn. https://www.buytwowayradios.com/blog/2020/07/wouxun-kg-805g-and-kg-805m-video.html -
One thought that comes to mind (if you haven't already) is to set the display to show frequencies instead of channel names...I'm curious if it may have carried in the frequencies incorrect, hence no receive. Also, have you looked into the factory reset suggested in that radio reference thread? (Haven't needed to do it, so not sure what it entails...) -
More thinking out loud than any intent to get one. One of those "just because you can doesn't mean you should" kind of things, but interesting to ponder. More general (honest question, trying to understand because I wouldn't say I'm even close to well informed...), what would be the issue if this were set up with a radio configured like a repeater (receive on 467.xxx, retransmit on 462.xxx, appropriate access tones on both) vs just going back and forth on the 462.xxx in simplex? The output frequency gets tied up whether simplex or duplex either way. And the repeater input side is tied up to send whether it's to an actual repeater or a simplex box. I can see you'd need to configure the tones correctly to keep it from becoming an endless loop if it were done with dual watch. The only other issue i can see is simplex repeat doesn't have a capability to listen before transmitting....busy channel lockout could address this, but you'd lose what you're trying to repeat in that scenario because the box won't know the radio isn't transmitting. Is there something else I'm missing?
While it has the flexibility to be used on otherwise non repeater capable radios, couldn't it be made to work with the normal repeater channels as well? As long as you have a radio with dual watch, set to monitor the "repeater input" (467.xxx) and set the transmit yo the normal output side (462.xxx). The new 95e certified baofeng comes to mind, mainly from experience with the uv5r and dual watch, but I'm sure there's lots of other options with similar capability. And it would address the "hearing twice" thing, though the delay is inevitable for a simplex repeater.
Side-by-Side Range Comparison (KG-805G vs Part 90) - The Findings
wayoverthere replied to mbrun's topic in Equipment Reviews
I think it comes down to the low bar to entry; since there's no knowledge requirement for a gmrs license, this is the FCC's way of giving a user with zero knowledge a way to know they're using compliant equipment, and (in theory) not throwing spurious emissions all over the spectrum. Ham, on the other hand, has some level of knowledge required, so they allow more freedom on equipment, with the burden on the operator to ensure the quality of their own equipment. -
I don't know of a good step by step offhand, this thread translates some of it:https://forums.mygmrs.com/topic/1978-translating-repeater-info-into-chirp-btech-gmrs-v1-vocab/ That said, it's really just knowing what codes the repeater uses, the menus are fairly straightforward for that part. Once you hit the menu button, scroll through and look for t-ctcs or t-dcs, depending what tones the repeater uses (if there's decimals, it's ctcss, 3 digit number, possibly followed by I or N is DCs). Hit menu to select that item, then scroll through to the correct tone, and hit menu to confirm (this is your "input tone"). You can also set a receive tone as well, but since it functions like a filter, you're fine leaving it off unless you only want to hear the repeater traffic on that channel.
For simplex or repeater use, programming should not be nee the only setting you may need (especially on a repeater) is ctcss/DC's tones, which can be set from the front panel, no computer needed. In many places, gmrs is used (as is its primary intent) within families/groups, so generally stick to their group. also, traffic is pretty low I some areas, so there may be no one there, or they may be running tones (which act as a filter) and not hear you.
New Interfering (IX) Signals - "Baby Monitors" using GMRS/FRS
wayoverthere replied to intermod's topic in General Discussion
I think the face that, by default, Amazon bugs you about questions posted on items youve bought leads to people with little to no clue of the actual answer posting useless answers...I'm not sure why, though, as it doesn't seem to give you points of anything...- 44 replies
- ix
- interference
(and 5 more)
Tagged with:
