28
John Fogery can't help me. What the heck is CCR?
wayoverthere replied to STTScott's topic in General Discussion
i will agree with that point as well. there's a wide variety of quality levels. that said, i see mobile as jumping into things a little deeper than just a HT, so more of a situation where if you can get "good" instead of "subpar", for not much more, it's worth considering. -
I'll give the low end manufacturers credit on one point; they DO do a pretty good job of marketing toward new users. Wouxun also seems to be pretty willing to work with the resellers on the feature set/programming, as evidenced by their part 95 certified offerings. that said, as gman covered, the receivers are where they fall short to varying degrees, either in sensitivity (picking up signals at all), selectivity (picking the signal you want out of the background noise) or both. i have the gmrs 50x1, and while i don't have any major complaints (other than how they locked it down for gmrs), you don't know what you aren't hearing, so to speak. the transmit side works solid so far, even with less than perfect antenna placement. there's also the factor that the uv50x2 isn't part 90 or 95 certified, so not actually legal to use for gmrs. all in all,while my personal experience hasn't been noticeably bad, i did jump in without enough research, and now know i could've done better; there's lots of lightly used part 90 stuff out there for the same money or not a ton more that will be a lot better. the fact that you should still be within the return window for the BTech may be an opportunity to try again (if you choose to) and only maybe being out the cost of shipping. -
CCR = Cheap Chinese Radio. in short, there's a lot of inconsistency in quality, a lot of counterfeits and fake certifications, a few decent ones, a lot of complete garbage, and sometimes no easy way to tell which a product is before you buy. one member (gman1971) has done some direct testing that showed just how bad some of them can be. suffice to say, like many others you've found, he isn't a fan of them (prefers motorola). if you take a look in his past posts, he's gone into some detail on his testing.. -
It seems more like a little bit of both sides taking the easy way out....fcc saying "if it's configured like this, fast track for approval", so the manufacturers go with the easy way of passing for approval. Where the wouxun (at least the 805g) is a little more set up for real world usability, not just "the test" Reminds me of something I read about certain cars being geared to minimize shifts needed for 0-60...made for better times (slightly) to hit 60 at the top of 2nd gear. However, for real world driving, that huge gap from 1st to 2nd was a pain, and required winding out 1st to be anywhere near the poweband in 2nd.
I just want to say I greatly appreciate the level of information here compared to some other places online. A similar topic came up related to someone measuring swr on HT antennas, and while there was a LOT of "you're doing it wrong" posts, even the long winded ones blathering about needing better equipment gave zero hint as to WHY what was being done was the wrong way to do it.
(ii) is the one you're thinking of related to ham equipment. the closed to ARRL i see is (iii) under a definition of "teaching" §97.113 Prohibited transmissions. (3) Communications in which the station licensee or control operator has a pecuniary interest, including communications on behalf of an employer, with the following exceptions: (i) A station licensee or station control operator may participate on behalf of an employer in an emergency preparedness or disaster readiness test or drill, limited to the duration and scope of such test or drill, and operational testing immediately prior to such test or drill. Tests or drills that are not government-sponsored are limited to a total time of one hour per week; except that no more than twice in any calendar year, they may be conducted for a period not to exceed 72 hours. (ii) An amateur operator may notify other amateur operators of the availability for sale or trade of apparatus normally used in an amateur station, provided that such activity is not conducted on a regular basis. (iii) A control operator may accept compensation as an incident of a teaching position during periods of time when an amateur station is used by that teacher as a part of classroom instruction at an educational institution. (iv) The control operator of a club station may accept compensation for the periods of time when the station is transmitting telegraphy practice or information bulletins, provided that the station transmits such telegraphy practice and bulletins for at least 40 hours per week; schedules operations on at least six amateur service MF and HF bands using reasonable measures to maximize coverage; where the schedule of normal operating times and frequencies is published at least 30 days in advance of the actual transmissions; and where the control operator does not accept any direct or indirect compensation for any other service as a control operator.
Overthinking a little, but understandably. Valid considerations if you were setting up a non gmrs radio. The part 95 stuff (btech and k805g) has a lot of it covered already, though. Assuming stock programming, channel "rept15" already has the +5MHz shift set. Just set the radio to that channel, go into the menu and look for the "t-ctcss" option, and set the tone accordingly, and hit menu to set. If you want to set it on the receive side as well, look for the r-ctcss option next, and set the tone there as well.
to be fair, the Btech GMRS 50x1 (also supposedly 95e certified) has a V/M button as well, and it will happily let you scan through and receive a big chunk of the VHF and UHF bands. However, it doesn't let you transmit on anything other than the hard coded 1-7 and 15-22 (simplex on 1-7, simplex or duplex on 15-22)...the Retevis may be similarly locked down the frustrating part about implementing the lockdown this way is that even if the extra stuff you've programmed is in bounds for GMRS, nope, rx only.
Hope everyone had a good Thanksgiving! Or, if you don't celebrate it, a nice day off at least.
Kenwood tk880 no audio, or voice
wayoverthere replied to Vanselow's question in Technical Discussion
i'm not familiar with the model (i'm sure there are some here that are) to tell you exactly where to find the setting. that said, since it works when you hold the 'monitor' button, that sounds like it's something with your squelch setting, either looking for a tone, or level set too high. there's some info on page 6 here (if you don't have a manual) http://www.repeater-builder.com/kenwood/pdfs/tk-880-svc-man-rev-e.pdf -
edit: scratched duplicate post, and it probably helps to link the manual. https://midlandusa.com/wp-content/uploads/2016/12/MXT400-Owners-Manual.pdf
the main thing you need to know is the output frequency (which is what you're listening to), what channel that is on the midland (pg 25), and the tones. assuming the repeaters follow the normal convention (+5mHz), your radio will already be set up for the repeater channels (RP15-RP22) to use the proper offset (transmit on the correct input frequency) for the repeater to hear you. first, you probably have to enable the repeater channels (pg 22). then, dial up the correct channel. after that, you'll have to enter the correct codes (pg 17-18 have the how to); midland has codes for the different tones, so once you know the tone used, you have to go back to the manual (pg 26) to see what code equals that tone, and enter it. that's the basic level to get started. i know it's easy to get caught up in the terminology (and some of the workings), but the basics mainly come down to being on the right channel, and having the right tone (like a key, kind of ) to get into the repeater.
I think his point was that there's both good used stuff and garbage on eBay, and it takes some dilligence to choose the good stuff.
miklor.com has a good amount of information for baofeng/btech stuff. i find it significantly easier to mess with the settings in chirp than directly on the radio. https://www.miklor.com/F8HP/
this would be my thought as well...paracord, a tree, and something for weights (nut&bolt?)...if there's an available ground/balcony, tripod and a push up. failing that, (if railing is it) i'm thinking if there isn't enough to anchor a push-up, maybe a cheap pool cleaning pole to clamp to to get an antenna up. antenna wise, ed fong is a good thought. been meaning to try the pool pole quickie with a 5/8 over 5/8 browning i've had sitting on the shelf, as an alternate to the 'antenna in the attic' i have going now.
while i'll stay openminded to possibilities, i don't think it would be possible to carry the analog signal from the transmitter to the antenna; bluetooth between the mic and the transciever itself exists, at least in the CB arena. alternatives do come to mind, though. do you have access to crawl or attic space? while not ideal, attic space could provide a place to stash an antenna; it may be possible to cover up a small coax hole. if there's a crawl space, a small hole to run coax under the subfloor to one of the vents to get a line outside for an antenna. there are also ports you can install in a window screen to run a cable through (with the window open), and passthrough boxes to put in the window gap that you close the window to seal against. running cable out at the crack of a doorway may be feasible as well.
Wouxun KG-805G - Any Experience to Share?
wayoverthere replied to mbrun's topic in Equipment Reviews
Buytwowayradios.com claims yes. https://www.buytwowayradios.com/wouxun-kg-805g.html?utm_source=mygmrs_topbanner&utm_medium=banner&utm_campaign=mygmrs -
Yes to both questions, at least per what buytwowayradios has for info. Have tested transmit outside the base 30 slots as well, and can confirm it. I have two local repeaters on 16, with each in their own slots, plus a second "spare" set of repeater slots for travel.
On a side note, I wanted a spare harness for a t-type connector (easty transfer of my "base" radio...looked over what dxengineering listed, and picked one for a radio with similar or higher power rating (ft-2900r). unlike the Amazon cheapo, this one has blade type fuse holders...good stuff.
Could do a fender bolt mount (like this: https://www.theantennafarm.com/catalog/ford-f150-2005-2008-1189 ) or lip mount, mag mount is an option, but not the best for your paint...
So..I have 50x1 as my 'base' and a wouxun 805g, and a similar situation of 2 repeaters on the same channel. Where the btech makes the first 30 rx/tx and everything beyond rx only, the wouxun allows all the slots to be rx/tx as long as they're in bounds for gmrs. I have the normal 30, 3 local repeaters, then another set of the repeater channels to have extra spots for repeaters when travelling. Btech was also rather unhelpful when I emailed support about what was in this password protected menu that came up. Haven't had Any luck getting into it yet either.
B-Tech 50X1 vs QYT KT-980 plus from Nat. net convo
wayoverthere replied to aj22185's question in Technical Discussion
I was actually contemplating doing a repeater build with one of those, for rx, the btech for tx, with a surecom to interface them...but then I'd be in as much on those as I would be on a proper repeater -
MXTA26 6DB GAIN vs. Browning BR-450 5.5DB Gain
wayoverthere replied to Greg43545's question in Technical Discussion
I've been running the Midland mag mount as well, without the isolator, sometimes sitting in direct sun for a couple weeks at a time, with no noticeable issue. Not sure where the issue is, tbh. I haven't done much transmitting, but we do see a lot of triple digit heat in june-aug And some of Sept, with low humidity. And again, the lack of the rubber isolator. -
Midlands are limiting for hobbyist usage, but they're hard to beat for simplicity, and standing behind their products. My gmrs 50x1 has been solid, though I don't know about the level of support from btech. I know my contact with them was less than helpful (questions on a menu)
if you don't have it, the manual is here: https://midlandusa.com/wp-content/uploads/2017/10/MXT275-Owners-Manual.pdf out of the box, you probably have to enable the repeater channels in the menu (look for option 'rp' and set it to 'on'). next, pick the repeater you want to access, note the frequency and tone, and figure out which channel it equates to. (pg 27 has a chart of channel to frequencies). switch to that channel, then back into the menu, and you have to set the tones. page 28 has the code charts; see what code the tone equates to, and set it in the menu. from there, you should be set on the basics.
