27
Wouxun KG-805G Stopped RX-ing/TX-ing after using CHIRP.
wayoverthere replied to MozartMan's question in Technical Discussion
One thought that comes to mind (if you haven't already) is to set the display to show frequencies instead of channel names...I'm curious if it may have carried in the frequencies incorrect, hence no receive. Also, have you looked into the factory reset suggested in that radio reference thread? (Haven't needed to do it, so not sure what it entails...) -
More thinking out loud than any intent to get one. One of those "just because you can doesn't mean you should" kind of things, but interesting to ponder. More general (honest question, trying to understand because I wouldn't say I'm even close to well informed...), what would be the issue if this were set up with a radio configured like a repeater (receive on 467.xxx, retransmit on 462.xxx, appropriate access tones on both) vs just going back and forth on the 462.xxx in simplex? The output frequency gets tied up whether simplex or duplex either way. And the repeater input side is tied up to send whether it's to an actual repeater or a simplex box. I can see you'd need to configure the tones correctly to keep it from becoming an endless loop if it were done with dual watch. The only other issue i can see is simplex repeat doesn't have a capability to listen before transmitting....busy channel lockout could address this, but you'd lose what you're trying to repeat in that scenario because the box won't know the radio isn't transmitting. Is there something else I'm missing?
While it has the flexibility to be used on otherwise non repeater capable radios, couldn't it be made to work with the normal repeater channels as well? As long as you have a radio with dual watch, set to monitor the "repeater input" (467.xxx) and set the transmit yo the normal output side (462.xxx). The new 95e certified baofeng comes to mind, mainly from experience with the uv5r and dual watch, but I'm sure there's lots of other options with similar capability. And it would address the "hearing twice" thing, though the delay is inevitable for a simplex repeater.
Side-by-Side Range Comparison (KG-805G vs Part 90) - The Findings
wayoverthere replied to mbrun's topic in Equipment Reviews
I think it comes down to the low bar to entry; since there's no knowledge requirement for a gmrs license, this is the FCC's way of giving a user with zero knowledge a way to know they're using compliant equipment, and (in theory) not throwing spurious emissions all over the spectrum. Ham, on the other hand, has some level of knowledge required, so they allow more freedom on equipment, with the burden on the operator to ensure the quality of their own equipment. -
I don't know of a good step by step offhand, this thread translates some of it:https://forums.mygmrs.com/topic/1978-translating-repeater-info-into-chirp-btech-gmrs-v1-vocab/ That said, it's really just knowing what codes the repeater uses, the menus are fairly straightforward for that part. Once you hit the menu button, scroll through and look for t-ctcs or t-dcs, depending what tones the repeater uses (if there's decimals, it's ctcss, 3 digit number, possibly followed by I or N is DCs). Hit menu to select that item, then scroll through to the correct tone, and hit menu to confirm (this is your "input tone"). You can also set a receive tone as well, but since it functions like a filter, you're fine leaving it off unless you only want to hear the repeater traffic on that channel.
For simplex or repeater use, programming should not be nee the only setting you may need (especially on a repeater) is ctcss/DC's tones, which can be set from the front panel, no computer needed. In many places, gmrs is used (as is its primary intent) within families/groups, so generally stick to their group. also, traffic is pretty low I some areas, so there may be no one there, or they may be running tones (which act as a filter) and not hear you.
New Interfering (IX) Signals - "Baby Monitors" using GMRS/FRS
wayoverthere replied to intermod's topic in General Discussion
I think the face that, by default, Amazon bugs you about questions posted on items youve bought leads to people with little to no clue of the actual answer posting useless answers...I'm not sure why, though, as it doesn't seem to give you points of anything...- 44 replies
- ix
- interference
(and 5 more)
Tagged with:
I was listening to one of the nets Thursday night via zello, and they were discussing preparedness, and something along those lines is one aspect that came to mind. Since I don't have a good place to stand up my own repeater and would have to depend on others' equipment, I would want to have some idea that they've made efforts to have at least some basic backup plan (or not) to know how much I should plan around it.
Personally, I don't mind the chatter....that may be the seeds of the radio hobby taking root to bloom later on. Its just the endless call tones that get old.
If you're lucky, sometimes NOS stuff comes up on eBay. There is currently a couple of vertex vx handhelds that will cover gmrs frequencies, and not too long ago I snagged a mobile (vx4207) for about the same as I paid for the btech...I paid a premium over the used stuff, but I'm okay with that. Half tempted to grab another of the used ones, honestly.
The incessant use of the call button? I have a couple channels set with a random ctcss code on my mobile, because there's group in my area on those channels regularly, rarely talking, just call button symphony...
power supply to use and set up my 50X1 with chirp
wayoverthere replied to cbrown038's question in Technical Discussion
If it has speaker type clamps, or screw down binding posts, the bare wires on the post are fine. I chose to add banana plugs to mine, for easier swap, though. -
my 2 cents....the specs look good, and leave headroom to power other equipment at the same time. the reviews do give me a little pause, but amazon's return policy is good at least. i believe others on the forum have used some other Tekpower stuff with good results (this one or the version with digital meters). -
Good point, Kirk. While repeaters are the big one it comes into play, it really applies to any time you'd want to use 2 different tones on the same frequency, for different recipients.
mbrun covered it well. it's clearly not a strict requirement, as wouxun seems to have no problem offering tx in all memory slots as long as they're in-bounds for gmrs; i suspect Btech just took the easy way out. not so much non adjustable, as it doesn't adjust low enough for FRS. i believe removable antenna is a no-no for frs as well. i ran into the same issue with my 50x1 as well...had a couple local repeaters programmed, but couldn't figure out why i couldn't TX, till i started digging and discovered everything above slot 30 is rx only. i'll still put the btech to use, but it's been bumped from the base spot, and will probably replace the midland in the truck in the near future.
the biggest issue is you can only transmit on the preloaded non-frs channels (1-7, 15-22). Everything else is RECEIVE only...you can program repeaters and everything, but no transmit, even on frequencies in-bounds for gmrs. realistically, unless you want to add some listen only channels, the cable (and using chirp to program) isn't really necessary, since you can change tones pretty easily via the menu.
It's kind of interesting seeing how well the wouxun did, at least in the environment you're working with. Thank you for all the effort you put into this...interesting reading. -
What can I expect from hand-held? Will it work for Net system?
wayoverthere replied to WRKS279's topic in General Discussion
Stay on rpt19 (27), it should already be set with the right frequencies and offset (though given the answer in the other thread about theirs coming unprogrammed, it doesn't hurt to check if you haven't already), r-ctc and t-ctc will both be 141.3. your settings should be good from there it pretty much boils down to if you're getting enough signal to the repeater. From there, look at the antenna...if you haven't already, mag mounts generally want to stick to something to have a good ground plane...top of a steel file cabinet or a pizza pan will do. Next, how's line of sight from antenna to repeater? With only 5 watts, obstruction is going to matter more. If your setup checks out there, I'd say stick the antenna on the car, and head closer to the repeater...see if it works closer in and/or less obstructed. If so, your settings are good, and better antenna location (or better antenna) and/or more power are the next steps. -
Yeah, when I bout the evx's, it was a difficult debate with myself whether to just get the 2, or buy all 4 the seller had listed. I've been trying to stay off eBay since...
I'll echo RadioGuy, been satisfied with my 805g, it's ready to go out of the box, but still flexible as you dig deeper into things like split tones and more repeaters
Thanks for the food for thought, and the reminder that i need to give the antenna side of the equation a little more thought as well. The part 90 route may end up being the winner (gmrs is mostly pretty dead here too, but nice to have the option), and the RF exposure aspect was something i hadn't thought about, but definitely need to...that aspect also makes the dual band mobile/single bands at base sound better, though getting the antenna OUTSIDE will be a necessity.
It's easy to end up with extras as you upgrade, bit by bit. I started with a pair of bubblepacks. Added 3 better HTs and 3 progressively better mobiles since then.
Mobile Antenna Tests and Final Decision
wayoverthere replied to jas's question in Technical Discussion
It's a shame to hear the ghost is that bad. I have the antenna it replaced, (I forget the mxta number), ~12" base loaded whip, and it does pretty well shoved up in my attic as a base antenna, and doesn't need much clearance on the truck, even on the roof. -
So...radio to radio, ch 19, you transmit on 462.650, they listen on 462.650 as well. Repeaters listen on a different frequency (input) than they retransmit (output) so it can be done real-time. Realistically, only one person can effectively use a frequency at a time, hence the different frequencies, and the RPT channels take that into account When you're going to use a repeater on 462.650, yes, just leave the radio on rpt 19. Your radio knows to transmit on 467.650, because that's where the repeater is listening, and it retransmits on 462.650, because that's where you're listening. I think the basic key is looking in terms of to hear each other, you have to be transmitting where theyre listening, and vice versa.
I reached out to their support via email, rather than calling, as this was during the "everything is shut down" portion of last year.
