42
Everything posted by quarterwave
Can I use Morse code to identify myself on my GMRS handheld radio?
quarterwave replied to Slickii's topic in myGMRS.com
In Part 90, many times the majority or all of the users don't even know the call sign, let alone when to use it. Thus, auto ID on repeaters and base stations. If it's good there, it's good here. However, makes it harder for non-ham, or someone unskilled in CW to decode and know who they are talking to. I'm a ham and I don't know CW. -
It could be a harmonic of another frequency and you are hearing the carrier and no audio....thus the static sound. I have heard such before.
Just got one, in hi vis yellow-green. Cool little radio, does what I need it to. Easy program. I switched it to NORMAL mode, all open. It retained the GMRS program it shipped with, and I just added my HAM channels on the end, and locked out the FRS channels from scan. I am surprised how well it receives just riding around in the truck, much better than my UV5R I have had for a few years. For the money and performance, I can get behind these radios. Seems like a good unit.
It was about mobile antennae in general. But if you like your antenna inside, you could go that way! LOL.
I recommend starting out, if new to radio, using a 1/4 wave Motorola style antenna, Whether it's NMO hole mount, bracketed, or mag, it will give you the least amount of trouble, and most performance before you start playing with gain rods. Once you have the mount in place, and have experimented to have it in the right place on the vehicle, you have a baseline. Then you can buy a 3 or 6 db NMO style (quality) rod and base and swap it in easily. Tune it and see if it does any better, but the 1/4 wave was always such a solid piece, in looks, size and performance. I don't mess with gain antennae. in fact, I have a couple of the high dollar Motorola Spectrum 6 dB units still in the tubes new. Just no use for them. Your best match and pattern will be with a 1/4 wave. Years ago working in commercial radio, this solved many a problem for us. Just my opinion, trying to help new people.
If everyone is running good equipment, it should be fine. I've been in tight commercial sites where there were 5-6 UHF repeaters within 2MHz of each other. And VHF to contend with. If the filtering is good, you're ok.
The sarcasm is strong with this one. There is probably alot of sideways stuff going on out there, but there are perfectly legit setups too. I've worked in commercial telecom and part 90 for over 30 years, sometimes the most unique solutions seem out of bounds, then all the haters have to peel their foot out of their mouths when they can't prove it is. I figure a collection of interesting experiments or setups to read about is way better than 9,000 random posts by newbies with the big new idea of the day.
Since I often see posts from people thinking out loud, or whom just got a license and got into radio, proposing to do some brand-new wild and crazy idea that will shock the world..... There is little new and shocking about how and what we can do with radio, both in HAM and GMRS. It's all been tried in one way or another. Now, that's not discouragement, but so many wild ideas get a critical response when the wild eyed newbies and inexperienced folks get to thinking with a keyboard. How about we proactively talk about unique setups or experiments we may done or seen. This way when Cleetus wants to link 17 repeaters in 4 square miles with MURS and CB channels, maybe he won't get run over by the radio police. He'll know that's not right, and won't work, at least within the rules. So if you have multiple repeaters, remote receivers, wireline controls, RF linked repeaters, poor mans LTR (AKA - PL scanning) or some other unique setup, we'd love to hear about it, how it is setup and if it works well.
I've never went wrong with a NMO mounted 1/4 wave. Fixed alot of "radio problems" by simply screwing one on.
If you are running a NMO mount antenna, a $5 1/4 wave rod and nut make an invaluable troubleshooting tool that lasts a lifetime.
When you are newer to the tech, I recommend just programming transmit (enc) only and leave your receive (dec) as carrier squelch (no codes or tones at all) until you learn more. You will hear everyone on that frequency, including the repeater you want to hear, but if there is not much other traffic, should be no big deal.
PL Codes/Tones/DCS Repeater use vs Simplex use
quarterwave replied to Webslinger's question in Technical Discussion
A transmission on a frequency can be heard by a radio receiving on the same frequency if it is within range. Squelch tones/codes do not change that, they only filter out anything that does not match your code. If running no code/tone on receive, you hear it all. You can use different in and out tones/codes on a repeater, but it's not necessary, it is usually only done to to mask the input by using a different output. The radio won't know as long as it's programmed properly, but its not ideal for easy operation. Usually a repeater trying to stay inaccessible but only to a private group does this. Simplex - run same codes all around, or none at all if you want to hear everyone (else). Private is not that. The term was used with the intention of reducing audio traffic on a groups radios when said group shared a frequency or repeater with others....back when there may not have been so many to share (part 90). Don't confuse that with scrambling or encryption. -
Mobile antennas and high gain = not always best?
quarterwave replied to SvenMarbles's question in Technical Discussion
A quarter wave antenna pattern looks much like a round ball. A gain antenna pattern takes more the shape of a football, or even an exaggerated football (ellipse). I've never gone wrong performance wise with a 1/4 wave... in UHF, VHF, 800... Nothing against the gainers, they have their place. Just an observation, but usually I see HAM radio (I am a HAM too) using gain antennae because we try to do the most with the least power. Commercial and GMRS largely used fixed power (even though there are adjustable power GMRS radios now) and many times have more power than they really need, so any marginal effect of a higher gain antenna is not seen or even known. That's an opinion, don't anyone get sideways. -
As long as that person is using same PL. BCL prevents transmission when a different PL is being received than the one you are transmitting (Different group on a repeater). Used alot on old community repeaters.
I run a MTR2000 with a Zetron. There is hang time, which is the time after proper carrier AND PL is lost, that the transmitter remains on air. It is used to keep the carrier up so another person can respond without any re-keying time. I set mine to 6 seconds. In my area alot of Ham repeaters have a long hang time. It's ok to not use it at all, but with a 100% duty cycle repeater, I'd rather have it. Then...there is tone in tail. Your carrier in hang time can transmit the PL or not. You can drop the PL and the carrier will stay up for the duration, but receiving radios (programmed with the output tone) will close their squelch. I also use the Zetron input carrier beep, which is a medium "beep" when a carrier drops. This helps people tell if a unit is on the fringe of coverage and their actual signal is weak or just their audio. It helps the non radio people learn repeater-ese.
Not to play Bill Clinton's lawyer here, I don't have a dog in this but... What is the definition of "network". A telco's phone and DSL system could be called a network. But, what is a cable system, or fiber system, is that considered a "network". I guess being from telecom, I consider a system with multiple destinations or addresses a network, but something like a fiber, or even a a VPN over the internet is more like a point to point because it is only accessible by the party (or device) on either end (dedicated). Same with a T1. My thought after reading this stuff for years was that the rules were to keep radio audio off of PSTN lines. Fiber and cable are not that. Just a thought.
Going back to one of my old experiences when I worked for Motorola years ago... A small city police department had a failure of their old GE repeater they had been nursing along for many years, so they needed a new one. Budgets were tight, but they insisted on a 100 watt unit. Now, the repeater was naturally on a hill, on a water tank, and was at the highest point in the city, and no more than a mile from the city limits in any direction. They wanted 100 watts. VHF, carrier squelch mind you...and 100 watts. While they waited for a new repeater, we loaned them a Desktrac (not what you need for public safety, but it'll work in a pinch). Once on the air, the asst chief said, man, that sounds good. And the range is great, can we just keep that one? Is it 100 watts? Sure, it's 100 watts. It was in fact 25 watts..... no one could tell. They later got a new repeater, but we still didn't set it up for 100 watts. Point is, don't get hung up on wattage, use what works for the situation you need it in.
What do you guys think of linked repeater systems?
quarterwave replied to SvenMarbles's topic in General Discussion
"ME THINK, WHY WASTE TIME SAY LOT WORD, WHEN FEW WORD DO TRICK." - Kevin Malone -
Just set the circle where it actually works, I had to do mine that way.
It's not a real question if you intend to run a real, reliable repeater. Some loss is part of the game. Good equipment reduces that issue. I setup a split repeater once, antennae were separated by 150' horizonally, and about 30 feet vertically. Just a pain in the ass to maintain, and still needed a can on the receive side. You don't have to buy a $10k repeater setup, but going cheap will result in cheap operation.
In chirp, just use the T-DCS until you get more familiar. That way, you won't have any mixed tone issues with receive and you'll just hear anything on that channel. Also, keep in mind, some repeaters may not give you any indication you hit it, it you are just kerchunking. If they have the hang timer at 0, by the time your radio switches back to receive, the TX has dropped anyway. If you have another receiver near, maybe with a remote or outdoor antenna, you can hear it. Else, you'll need to make contact with someone to see if your in.
What's your GMRS mobile setup, and how does it work for you?
quarterwave replied to WRQC527's topic in General Discussion
I've used a variety of setups, probably the most effective ever was a Motorola Spectra 9000 A9 and a 1/4 wave mounted antenna. That was a long time ago. -
I saw a post on FB about the release of the antennae. I think they are good looking pieces, as long as they work well. I had commented on said post, and a local know-it-all who probably got his license 3 weeks ago and discovered what radio was 4 weeks ago.... proceeded to tell me off as if I was wrong and didn't know anything. That's fine, I deleted my comment, so he's talking to his self. I don't argue with idiots on FB. The summary is I felt the product was nice, but Midland is good at marketing. You'll buy a $259 antenna because they tell you it's good. If you need a rugged antenna for Jeepin', that's cool I get it, I hope it works good for you. I know the going gets rough out there, but my only point was that in all my years of experience, a 1/4 wave has outworked everything in the long run. That doesn't mean I'm telling anyone they have to use it, just that tried and true is just that. I have worked in radio and telecom for 30+ years, I know what I know. I don't push that on anyone, but I have helped many people with radio issues and I don't do it to be heard, only to help. When I first got a GMRS license nearly 30 years ago, we had to find a commercial radio to recrystal if we wanted to use GMRS. Now there is some great product out there, and I do like the Midland stuff too.
