quarterwave
    42
Everything posted by quarterwave
  1. It doesn't take much for one of those duplexers to be off and cost you your power out or rx in. I have a celwave and it needs retuned once a year, the antenna and line are fine, it just take a minor tweaking and she comes back. They are touchy in my experience. I "backwoods" tune my stuff since I don't own a service monitor. Usually close enough for me. I found a quarter turn on one of the cans equaled half my power once.
  2. Can't beat that MTR for solid performance, I run one with a Zetron and a ASP fiberglass antenna (800 model I think) 22 feet long on my 50 foot tower, which is on a hill 150 feet above average terrain. It has always provided good range. Before the MTR, I had 2 mobiles running, it was good, the MTR is the real deal though. For duplexing I run 2 receive cans, and one transmit can, stuff salvaged out of an old Motorola community repeater. Works great.
  3. Yes, there is a kit. I have one... with a Zetron so I can remotely make PL/DPL changes, etc, awesome repeater, set it and forget it.
  4. Yes, yes they will.
  5. I took down my second repeater that this weather control base was hitting. I want to put it back up in a new location, maybe this Spring. In the mean time, I programmed another M120 and took it to the site and swapped it in, so it's a 40 watt base station now, used for WX alerts only. Just heard the test go out at just after 11 as I was sitting at work in my office. The repeater was only running about 15 watts, so this should fill in coverage better. I will say, the setup has been reliable.
  6. I use my UV5R as a scanner and GMRS radio...but I can't hear much anymore. I am looking at a Uniden 325P2 so I can get back in the "know". I leave my UV5 at work, because it is cheap and if it came up missing I would not be out much. I usually use my M gear for real comms. Although I did recently pick up a NEW pair of Unidens (about 2006) model GMRS/FRS radios that had a scrambler in them. Nice little radios. I have had a set of Audiovox for years, but these are really nice. I use them on vacation, etc. I wanted to try out the scrambled audio feature on the Unidens, even though those were discontinued right after they started selling them. They had FCC cert but then there was a misunderstanding between FCC and Uni about the scramble, and they lost the Cert. I like them, and will be looking to get another pair for reserve. So yeah...a purpose built radio is best.
  7. I still have one NIB too! I have the other on the work bench as a control station, used to have it in my pickup. Good little radios. Is the CPS for the CM/PM radios available or subscription only? I haven't needed any mobiles for long time, but updating a little would be good...assuming I can self program. Back when I radio-ed all the time and worked in the industry the old RSS was guarded like a gold bar...now no one cares.
  8. Public safety repeaters are the only ones I ever worked with that ID'd 24/7. Most commercial setups, and even my own GMRS ID was/is based on use. So in other words, if you don't key the repeater for a period of time....3 hours, 3 days...3 weeks....it never ID's. If you key it up, it ID's after receiver drop, and again if use continues beyond 15 minutes. Setting up for continuous ID is a waste of air time. And I just realized how old this post was....
  9. I would check water tanks, building tops, maybe you local telephone co. most of them in rural area's all had repeaters at one time they used, may not now but if they own a tower you might be able to get on. You have to be sure you express that it is non-commercial use, and could be used in a community emergency, etc. As long as they know you don't and can't money from it, they may be more open to it.
  10. I think the issue will be the receiver in the MRE verus anything else. If you can get the antennae as far apart as possible, and use as little power on the CDM as possible (If you don't have hi/lo programmed on it, get it set for 10 and 40 then you can switch it) and use 1/2 watt on the MRE you may get better results. I have done all sorts of projects in commercial/public safety and sometime you would be surprised what a better antenna position and LESS power will do. I know when we used to service PAC-RTs as MRE on Low Band MICOR radios...the VHF PAC-RT's ran at 250mw and the HT600's were 1 watt. Of course the Micor was low band, but it was blasting 100-120 watts on a long whip 2 1/2 feet from the VHF antenna. In band is tough, not alot of options, but worth playing with. I had a case to (oops!) leave a 1/2 watt FRS on VOX laying in front of my Uniden 780 scanner in my truck and listening on my P1225 while out of the truck....worked great, even when the 780 was picking up 453 and the FRS was Txing 467. I could get 1/4 mile away in a building and still hear it. Didn't do that much, but had some stuff going on once that I wasn't going to miss...needed LB, VHF, UHF and 800 all together.
  11. No, I am not questioning whether closed repeaters should exist, I have one, and I know what it costs and what I want it used for, and more importantly what (who) I don't want on it, so I have no issue with closed repeaters. My comments were only to whether it makes sense to list repeaters no one but the owner and his friends use. Yes, it can help with channel finding, but that can be done other ways more reliably, as it's the unlisted ones that will pop up just when you think you know what's around given a "listing". In commercial radio, when choosing from new frequencies sent over by a coordinator for public service or commercial use, we would always set up a receiver at the proposed tower site, a recorder and a clock-timer triggered by carrier, and leave it on the air for about a week per frequency to capture the audio and amount of air time on the frequency, if any. When we narrowed it down to the one we wanted, we ran it for another week, just to be sure. Did that with PL decoding for distant stations sharing same freq as well. But, back to the issue...I just had wondered about how legit what I saw was.
  12. There are quite a few repeaters in the Ohio list these days, that is good to see. I have one on there myself. However, another member told me he emailed the owner(?) of the larger group of repeaters, which are marked Private, Paid, Members Only and such...and was told not all of them existed. The member thought maybe the owner felt he could "reserve" channels by posting them. Secondly, Do we want repeaters listed if they are only for the owners or private "members" to use? I have an open repeater...but I also have a "private" one, that I do not list. I'm not saying it "should" be one way or another, but just asking what others think. Maybe that owner can chime in and tell us what's up as well. I guess I just lean towards..if you are going to make a repeater known to the public, then it should be open or request-permission type of thing...but paid, membership, private? Just seems to make me think of someone trying to look good on paper. "I've got an ice cream cone...and you can't have one" Could just be the mood I'm in today, though.... ha ha ha.
  13. No. No corssband / cross-service allowed in GMRS or MURS.
  14. Good One.
  15. http://www.batlabs.com/msf5k.html
  16. Yep, that's the standard old MSF. I run a MTR2000 (newer generation of the MSF) and it is awesome. Turned it down to 50 watts and it will run 100% duty cycle with no fans (probably at 100 watts too!)
  17. Agreed. This UV5R is no gem in the RX department. I got a new truck and I have talked myself out of installing a Bearcat HP2 right now...I was wondering how the UV82 is for a receiver, would like to put a dual band portable in the truck with a battery eliminator to get my UHF stuff on but also hear city and county fire channels on. My UV5R is deaf once in the cab, but my P1225 is fine. Would rather leave a radio I can afford to replace in the truck these days...people will steal anything.
  18. I would have to look at my CHIRP file at home, but I have a UV5R working with one of my repeaters using DPL. I think what you showed there is right. So, you are saying you can talk through the repeater ok, but you cannot TX from the repeater radio and break the squelch on the portables? Later that day... Change your DUPLEX to (+) and your offset to 5.0000, and then the frequency to 462.6000. The way you have it set it is going simplex on the high side, so the other other radio, provided it is programmed the same, is hearing it simplex, but it is also keying the repeater although you are not hearing the actual output of the repeater. I see your HAM repeater below is set up correctly as a (-) duplex and 600k offset. Let us know if that fixes it.
  19. https://midlandusa.com/new-extended-range-and-ultra-slim-midland-mxt100-micromobile-gmrs-2-way-radio-allows-you-to-stay-connected-to-everyone/?avad=55963_c911208a
  20. Update. I did swap to a M120...and I run about 8 watts to hit the repeater from my house. It tests and alerts for my area (FIPS/SAME coded) reliably for a couple of months now. I am limiting the TX to 45 seconds now which give you time to hear the core of the message if it's a severe alert. Still pondering making a base out of it at the tower site...just make it go out on 675 rather than be on one of the repeaters. I guess the big takeaway is the very simple setup using a minimum of equipment works well.
  21. It could be a licensee, or some rougue radio dealer that setup and unsuspecting customer with SCADA-like or simple remote controlling hardware, it could very well be simplex. You can use DTMF encoder/decoders to kick on relays for various things, setup/knockdown repeaters, etc. The receiver radio basically has an output that drives a relay and then things that can be done are many...high and low voltage switching. It could also be a trigger of some sort sending the DTMF, and the receiver just goes into alarm to signify something happened....could be an alarm, alert, water level, power out, door that opened...etc. Those are some more elaborate examples, but in the radio biz I setup a fire departments' big siren on the roof of the FD to blow by remote, also setup thier garage doors to go up when a certain code was used, and a real cool one...gas pumps active for 15 minutes after a code was put through. If you are hearing a rapid string, it is pre-programmed and is likely intentional. Legit use of the freq? Probably not.
  22. Sounds like DTMF remote control, if it's a string like that. Is there a repeater on that freq?
  23. Nice! Glad to see more in Ohio.
  24. I always skipped the RICK (it was just another way for M to get another $300 out of a customer) and built my own, or used one from MRE1032 (MRE Direct) on eBay. I run one of those on a couple of M208's right now, it has a delay and adjustable audio. You can also use a 5 Pin for the TX as they use the RJ45. I think the only issuse using a 5 Pin for RX was getting COR to the RJ45. I didnt' want to modify the radios, so I never did that specifically.
