9
Exterior vehicle antenna on a HT?
AdmiralCochrane replied to Marius1195's question in Technical Discussion
I wore the cables out over and over so I gave up and bought a regular mobile rig. Was still a great way to start, made lots of contacts and friends -
Took me an hour with a 3 lb hammer
New model Baofeng appears to be a great improvement
AdmiralCochrane replied to jc1240's topic in Amateur Radio (Ham)
Wait, ... the Earth isn't flat? -
The licensing fee has been authorized to change for a year, it has NOT CHANGED. Its not going to change until they have the software in place to charge for ham licensing, upgrades and vanity call signs. Glad I did my ham license upgrade before the fee was initiated.
I don't see anything to be confused about. GD1 asked specifically about pushing buttons.
Buttons vary more between manufacturers and models as much or more than between GMRS and ham versions from the same makers. The only time you have training advantage is when a manufacturer makes a ham and GMRS radio with the same hardware and only the firmware differing between the two. A clue to this is a GMRS model that ends in G that appears physically the same as a ham model with the same beginning model nomenclature without a G suffix. GMRS is essentially the same as the Technician class UHF 440 aka 70cm band. Some ham radios similar to GMRS radios may also be dual band 2m/70cm radios. Here's a graphic that shows how much more a Tech gets vs GMRS with arrows pointing to the similar 70cm band. I blanked out the bands that require higher ham licensing.
Neither am I. It does not occur as such in page 1 of my searches. Note that GOOGLE changes your search results based on cookies; the results you see ARE NOT the results everyone sees. Its probably a bigger data chaser than Facebook.
My comment about my search engine use being deficient was in regard to the fact that the often quoted Youtube result does not occur in the first page of results I get. Nor does any website that suggests 19. I must be doing something wrong.
I guess my search engine use is deficient. Another info source these days is Reddit. Some of (maybe close to half) of my younger friends that are in the age group most likely to be off road fans ignore Google, Youtube and Facebook and instead rely on searches and discussion on the Reddit platform that is not always found by search engines. I have not looked into what the prevailing opinion on Reddit is for this question.
Not the way English Common Law works. Something has to be prohibited. If its not specifically mentioned, its allowed. Grey areas come about when the prohibiting language is unclear, not when it is omitted.
High SWR when tuned to repeater channels?
AdmiralCochrane replied to JFITZ7's question in Technical Discussion
The math presented appears correct to me. 1% of 65cm is approximately ¼". Just a WAG, but I would present that the data provided suggests that either both SWR readings are showing a slightly longer than optimal antenna or possible difference in accuracy of the meter with different power output. OP did not confirm that readings were taken with the same output. This is one of the advantages of the nanoNVA tool vs a transmitter and wattmeter. Without an analyzer, cut and see if the 1.3 goes up more than the 2.0 goes down, or if both go down. 2.0 SWR isn't going to hurt anything on GMRS, propagation will vary more with where you are standing, how straight up you hold the antenna (polarization is real) and how well charged your battery is. -
Dual watch to scanning FRS radio
AdmiralCochrane replied to AJBelayer's topic in Family Radio Service (FRS)
Citizen, my comment was not intended to point toward either side. People on both sides of the Apple/Microsoft lines are generally ignorant of the opposite mode. On smart phone applications I find all to be equally foul. -
He's asking if the MXTA26 will work. It will work but there are better dedicated base station antennae. Many hams start out with mobile antennae on their first low budget rigs, since he is already dedicating more money than first low budget, he's probably pointing toward a better dedicated 65cm band antenna. Internet search is his friend; search for GMRS base station antenna. I would do all I could to get the antenna up higher. Another 10 ft could make the difference between useful and not so. Unless I am mistaken, the harder the surface rocks are the better chance of signal propagation into shaded/non line of sight areas via "knife edge" propagation. Soft soil and trees - dead zones in the non LOS regions.
Same here, I occasionally use keypad to change channel, volume, likewise vfo direct entry. There are many days I don't touch it
Doesn't mean they aren't the same hardware
Many people fear what they do not understand. -
Most HT's come with a budget antenna to hold down the price. Another $30 worth of aftermarket antenna is usually a good investment. In fringe areas, antenna polarization is important. The transmitting and receiving antennas need to be exactly in the same plane (hold the HT with the antenna pointing straight up). Outside of that, we would need more details.
In the 65centimeter GMRS band, height means more than anything else for your antenna as long as your coax length is less than 50 ft, then coax quality begins to inch in, but height is still the prime consideration. If your area isn't generally flat, even a well elevated antenna will not propagate well in the obscured directions; a repeater does not overcome this unless it is located at a centrally located high ground location. The advantage of a repeater is to generally double the range of 2 mobile radios. If the repeater antenna can be located on a tower over 150ft high and the tower itself is on a locally high elevation the range between the repeater and regular stations can be 20 miles under perfect conditions. At 50 ft elevation the range of a repeater is more likely to be less than 10 miles, probably 5, sometimes even less with buildings and trees around. Good brands of antenna are Diamond, Comet, Browning, Tram, Ed Fong. There are many to choose from among these brands.
I worked on a demo job at a three letter agency building once, it was isolated as described above. The laborers carried literal tons of copper screen to the recyclers. One floor, maybe 20,000 sq ft and 10,000 - 15,000 fully wired telephone connections. Desks with headsets and typewriters - old school telephone intercept building.
So, you heard more traffic on 19?
The Lone Ranger rides again
A crappy rubber duck would also inhibit longer distance propagationand can limit it to UHF/GMRS wavelengths. example: My very nice Kenwood ham tribander is super with a good antenna, but near worthless with the rubber duck that came on it. I can hit repeaters over 20 miles away with proper elevation and the good antenna on all 3 bands, but only UHF under a mile away with the rubber duck. -
I don't think its dual watch, but outside of that, its sort of what OP is looking for. -
The simple solution is an FRS radio and a used handheld scanner from eBay. There were very few dual service part approved radios and I'm not sure any of them could be programmed to do what you want even if you could find one.
