AdmiralCochrane
    9
  1. 100 watts would not increase the range as much as you expect; almost all the contacts you can make with 50 watts can also be made with 25. Unobstructed line of sight prevails as the significant working feature.
  2. My stereo speakers are near field receivers (LOL) for the freebanders that travel on a highway near my location. Wasn't sure what band they were using until I caught them on my scanner. Was between 10m and 11m and they definitely were not "authorized users" on the frequency.
  3. I talk to a traveller about once a week on 146.520. Sometimes people just call out, other times they are travelling across a ridge or bridge at high elevation and know the propagation will be tremendous so they call knowing the likelihood of being heard is greater from those locations. Just one time I talked to a trucker who called out on 520 asking for some local knowledge. It was a great QSO.
  4. Sshannon, here's the same old saw - GMRS has very limited range in most conditions. Without being on a pointy mountain top, a hand held usually has a mile or less range, a vehicle mounted mobile might have 3 or 4 miles range to a similar vehicle. For effective use, learn if there is one or more repeaters in your area and learn if you can become authorized to use it. If so, program your radio to use it and figure out where and when its useful. The best advice is become licensed and use it. In some areas it will be a good standby and alternate comm mode, in other areas it will be completely useless. You won't know without using it in situ and no one can really tell you EXACTLY how it will work for you and YOUR locations. A lot of people say they want something for alternate comms if cells are down - if cells are down, most repeaters will be down too and many GMRS frequencies will be flooded with people with little or no knowledge of using a radio. In my area there ARE several well located repeaters on commercial towers with backup power, but in reality, its rare outside of MAJOR metro areas. There are many repeaters here, but almost none have back up power and most are poorly located. Out of 50 or 60 around here, only 3 or 4 would be useful.
  5. I wore the cables out over and over so I gave up and bought a regular mobile rig. Was still a great way to start, made lots of contacts and friends
  6. Took me an hour with a 3 lb hammer
  7. Wait, ... the Earth isn't flat?
  8. The licensing fee has been authorized to change for a year, it has NOT CHANGED. Its not going to change until they have the software in place to charge for ham licensing, upgrades and vanity call signs. Glad I did my ham license upgrade before the fee was initiated.
  9. I don't see anything to be confused about. GD1 asked specifically about pushing buttons.
  10. Buttons vary more between manufacturers and models as much or more than between GMRS and ham versions from the same makers. The only time you have training advantage is when a manufacturer makes a ham and GMRS radio with the same hardware and only the firmware differing between the two. A clue to this is a GMRS model that ends in G that appears physically the same as a ham model with the same beginning model nomenclature without a G suffix. GMRS is essentially the same as the Technician class UHF 440 aka 70cm band. Some ham radios similar to GMRS radios may also be dual band 2m/70cm radios. Here's a graphic that shows how much more a Tech gets vs GMRS with arrows pointing to the similar 70cm band. I blanked out the bands that require higher ham licensing.
  11. Neither am I. It does not occur as such in page 1 of my searches. Note that GOOGLE changes your search results based on cookies; the results you see ARE NOT the results everyone sees. Its probably a bigger data chaser than Facebook.
  12. My comment about my search engine use being deficient was in regard to the fact that the often quoted Youtube result does not occur in the first page of results I get. Nor does any website that suggests 19. I must be doing something wrong.
  13. I guess my search engine use is deficient. Another info source these days is Reddit. Some of (maybe close to half) of my younger friends that are in the age group most likely to be off road fans ignore Google, Youtube and Facebook and instead rely on searches and discussion on the Reddit platform that is not always found by search engines. I have not looked into what the prevailing opinion on Reddit is for this question.
  14. Not the way English Common Law works. Something has to be prohibited. If its not specifically mentioned, its allowed. Grey areas come about when the prohibiting language is unclear, not when it is omitted.
  15. The math presented appears correct to me. 1% of 65cm is approximately ¼". Just a WAG, but I would present that the data provided suggests that either both SWR readings are showing a slightly longer than optimal antenna or possible difference in accuracy of the meter with different power output. OP did not confirm that readings were taken with the same output. This is one of the advantages of the nanoNVA tool vs a transmitter and wattmeter. Without an analyzer, cut and see if the 1.3 goes up more than the 2.0 goes down, or if both go down. 2.0 SWR isn't going to hurt anything on GMRS, propagation will vary more with where you are standing, how straight up you hold the antenna (polarization is real) and how well charged your battery is.
  16. Citizen, my comment was not intended to point toward either side. People on both sides of the Apple/Microsoft lines are generally ignorant of the opposite mode. On smart phone applications I find all to be equally foul.
  17. He's asking if the MXTA26 will work. It will work but there are better dedicated base station antennae. Many hams start out with mobile antennae on their first low budget rigs, since he is already dedicating more money than first low budget, he's probably pointing toward a better dedicated 65cm band antenna. Internet search is his friend; search for GMRS base station antenna. I would do all I could to get the antenna up higher. Another 10 ft could make the difference between useful and not so. Unless I am mistaken, the harder the surface rocks are the better chance of signal propagation into shaded/non line of sight areas via "knife edge" propagation. Soft soil and trees - dead zones in the non LOS regions.
  18. Same here, I occasionally use keypad to change channel, volume, likewise vfo direct entry. There are many days I don't touch it
  19. Doesn't mean they aren't the same hardware
  20. Many people fear what they do not understand.
  21. Most HT's come with a budget antenna to hold down the price. Another $30 worth of aftermarket antenna is usually a good investment. In fringe areas, antenna polarization is important. The transmitting and receiving antennas need to be exactly in the same plane (hold the HT with the antenna pointing straight up). Outside of that, we would need more details.
  22. In the 65centimeter GMRS band, height means more than anything else for your antenna as long as your coax length is less than 50 ft, then coax quality begins to inch in, but height is still the prime consideration. If your area isn't generally flat, even a well elevated antenna will not propagate well in the obscured directions; a repeater does not overcome this unless it is located at a centrally located high ground location. The advantage of a repeater is to generally double the range of 2 mobile radios. If the repeater antenna can be located on a tower over 150ft high and the tower itself is on a locally high elevation the range between the repeater and regular stations can be 20 miles under perfect conditions. At 50 ft elevation the range of a repeater is more likely to be less than 10 miles, probably 5, sometimes even less with buildings and trees around. Good brands of antenna are Diamond, Comet, Browning, Tram, Ed Fong. There are many to choose from among these brands.
  23. I worked on a demo job at a three letter agency building once, it was isolated as described above. The laborers carried literal tons of copper screen to the recyclers. One floor, maybe 20,000 sq ft and 10,000 - 15,000 fully wired telephone connections. Desks with headsets and typewriters - old school telephone intercept building.
  24. So, you heard more traffic on 19?
  25. The Lone Ranger rides again
