WRKC935
    17
Everything posted by WRKC935
  1. From the Generator source web site. Changing Engine Speed to Vary Output Frequency Present-day generators consist of an engine directly connected to an alternator to produce electricity. One of the most common ways of changing the output frequency of a generator is to change the rotation speed of the engine. The two factors are related as per the following formula – Generator Frequency (f) = Number of revolutions per minute of the engine (N) * Number of magnetic poles (P) / 120 Conversely, P = 120*f/N As per the above formula, a 2-pole generator producing an output frequency of 60 Hz has an engine speed of 3,600 rpm. To change the output frequency to 50 Hz for the same generator configuration, the engine speed needs to be reduced to 3,000 rpm. Similarly, for a 4-pole generator, an engine speed of 1,800 rpm produces output of 60 Hz. Reducing the engine speed to 1,500 rpm yields an output of 50 Hz. https://www.generatorsource.com/Generator_Frequency_Conversion.aspx It was a bold statement. But it was a 100% CORRECT bold statement. It comes up as soon as you Google it for God sake. https://www.google.com/search?client=firefox-b-1-e&q=Generator+poles+and+speed Click down on 2 pole speed, then 4 pole speed and it clearly states what I said. Yes, 3 phase generators have more poles. But most of them are 1800 RPM or lower in operation. Depends on the size of the generator head and the engine size. Big engines don't make 1800 RPM. The mammoth stuff is under 800 RPM. Mind you a train engine diesel motor maxes out at 1000 RPM. Talking about stuff bigger than that. Little pull start gas generators that are 110 only have two poles that are not tapped at the center. Half the winding is on one pole the other half is on the other. For a slightly larger 110/220 generator. Each pole creates 110 volts. There are 3 slip rings on those stators and the center is tapped and those poles are 180 degree's out of phase. So when one side is producing a positive going wave, the other one is producing the negative going wave. Since there is a center tap, each leg can be individually referenced to the center tap and produce 110 volts, and across both legs 220 volts is created since they are 180 degree's out of phase.
  2. FROM DELCO REMY web site. Alternator Output All alternators are listed at maximum output. Since alternators are rotational devices, the output listed is at approximately 5,000 RPMs, shaft speed. The alternator pulley is much smaller than the crankshaft pulley, so it is turning much faster than the engine RPM (generally 3.5:1, up to 4:1 ratio). This means that the alternator is well into its maximum output when the vehicle is going 65 mph. https://www.delcoremy.com/the-latest/2018/january/how-to-select-the-right-alternator 2K RPM time 4= 8K RPM. You're right. It does help to know things. Which it seems I do, at least about this.
  3. Something else to stick in here. Anything that is going to vary in input RPM will not work well for direct AC generation. Meaning AC (house current) generators have a pole count. Two pole generators need to spin at 3600 RPM to generate 60 Hertz power. Four pole generators need to spin at 1800 RPM to generate 60Hz power. Varying the RPM on an AC generator will vary the frequency output. You are far better off to create DC power and charge a battery bank and if AC power is needed, create that AC power with various sizes of inverters. The reason for the various sizes of inverters is the idle load of the inverter. A 5KW inverter will at idle draw as much power as a 100watt inverter at half load. So just having one big inverter is going to waste power as heat. I am kinda going away from portability here. I know the initial question was about 'hand crank' stuff. But if you look at what's available that is hand crank powered, it's LED lights and small broadcast radios. If you start reading the specifications for those items, you will find that 10 minutes of cranking will get you no much more in listening or operating time on the little AM radios. The LED lights are a bit better, but LED lights are very low loads. If there was a direct USB crank charger, consider the time it takes to charge a phone or a portable radio with USB charge. Even at fast charge, that is going to take an hour if the battery is depleted. So that's an hour of cranking. Having several solar charged USB power banks to set in the light would be a better option. They will free you up to do other things in a bad situation.
  4. You are far better off to build something like a stationary bike with a generator / alternator on it than anything that's 'hand crank'. The amount of power generated vs the amount of physical energy expended on hand crank anything is not worth it, especially in a bad situation. It comes down to charge rate. If you can charge a battery with 10 amps for 30 minutes with a stationary bike, a hand crank anything is only going to be half that current or less. Requiring a longer period of time cranking. And you are using muscles that aren't as powerful. My opinion is you need to consider energy conservation. Personal energy conservation. And a stationary bike needs to really be a tool of last resort. Solar and wind are going to work without your physical effort. Yes, they are only semi portable, same as the bike. But it's a solution for a home base of operations for sure. My advice is a bike on a stand with a belt on the back rim connected to a generator. Get a bike with multiple gears to at least figure out to optimal ratio for generating power and not killing yourself doing it. Remember that alternators (from a car) will require some amount of voltage to get the field coil going. So a generator would be better but are harder to find. But any small amount of voltage is enough to start the field and get you rolling. Or you can modify the alternator with some magnets to jump start that process. People are doing that sort of thing all the time with DIY wind generators. Might be a good place to start looking at what's needed. And if you really want it to be hand crank. Mount the bike in a way that you can hand crank it and just modify the pedal for hand use. Or you might try a kids bike with a smaller rear wheel. Automotive alternators spin at 4 times the crank speed. So if the engine is turning 2000 RPM the alternator is going 8000 RPM. Bear that in mind with the design as well.
  5. What Steve said tongue and cheek is actually right and why we are going to see a ham test for at LEAST the next 10 years even if the requirements are relaxed by the FCC. I am 53 and got licensed when I was 22. Not long after the creation of the "No Code Tech" license. We only had allocation for voice above 50Mhz so we couldn't do too much damage. But others will tell you we were lepers, the bane of ham radio. We were going to bring about the end of ham radio and the hobby would be gone. That was the Fud's opinion of it anyway. The ARRL isn't going to be able to allow a test-less ham license because the old guys that are now older and much more opinionated will raise 9 kinds of hell at them for even thinking about it. Nut that mentality will fade as those guys shuffle off their mortal coil and begin fertilizing the flowers at the local cemetery. But I will say this. The test ain't that hard. And there are some here that if you put 1/10 the effort into studying for the test that they do in winding people up in here and beating dead horses, you would have your license in no time.
  6. Getting ready to do something very similar in my Suburban but both are going to be High Power radios. Have ham license and both radios have every ham repeater they are compatible with in the State of Ohio. Also have the simplex stuff and Some FM satellite stuff. I am debating how I am going to mount the control heads though. I might break down and build a console for the truck and put them in it, but I am also thinking about O3 hand held control heads. But I need to figure it out before it gets too cold and I put it off another year. But this looks good.
  7. Oh,, I 100% agree, it's done gone and needs to be forgotten. The BS nonsense crap of 'CHANGE.ORG' is a TOTAL joke though. It's so pointless it's not funny any more. Yeah, I tossed out a word wall to address the ACTUAL issues with it. But the point of that was NOT to actually get the change to occur, but to MAYBE,,,,, just MAYBE get people to SHUT UP about this damn topic and move on. I too am tired of hearing about it. And whats more I have actually posted IN DETAIL now, what it would take to get it done. Do you think anyone will read it, learn from it and actually do it. F NO... they are gonna continue to get in here and continue to post BS about it and how the FCC sucks and the rules still don't ban it and all the other drivel they seem to come up with about it. Personally I think the moderators need to just start banning people if they create topics pertaining to linking until there is a rule change and they post about that. But I don't have a say in it. Now, specific to YOUR comments. Yes, it's allowed in Amateur Radio. But this is NOT that service. You trying to draw comparisons to the two different services is dumb. Part 90 commercial allows for it as well. But I don't see anyone comparing those two services. Far as the 'coordination' of frequencies. So me what regulation in Part 97 where is specifies the FCC has ANYTHING to do with coordination of ham frequencies at all. The FCC took pieces of the RF spectrum and handed it to the hammies and said 'here you go, deal with it'. Yes, there are coordination bodies for ham repeaters. They have ZERO actual authority outside of what we have in GMRS. That being the ability of filing a complaint with the FCC pertaining to interference. Which ANYONE has. That's all they have, same as here. They can't DEMAND anything of a repeater owner that's not in the FCC regulations just like on here. They can imply they do, and saber rattle all the want. The FCC is the only ENFORCEMENT body for anything RF related. The ARRL, frequency coordinators, and other SAD HAM's have ZERO power to cite you, pull your license or even issue a legal warning with any teeth to it at all. And how anyone thinks any different only tells me they have NO CLUE about what the F they are talking about. So again, saber rattling and narcissistic ramblings that amount to NOTHING. And anyone that KNOWS how it really works can tell them to get off their lawn. Then you bring up my very favorite BS topic for GMRS. D M R. Can't happen and more over be careful for what you wish for. Because it could. And this would truly be a mess for the reason I posted above as it would pertain to radio ID management. Do you think anyone will read it, learn from it and actually do it. F NO... they are gonna continue to get in here and continue to post BS about it and how the FCC sucks and the rules still don't ban it and all the other drivel they seem to come up with about it. NO one will take on the responsibility of creating a database and issuing radio ID's for DMR on GMRS. So every clown that ever heard the Rush album will want 2112 for their ID. Or their birthday, or their GF's chest measurement until she moves on and they will then want a DIFFERENT ID. How many ID's do you issue to a single person? With ham you get ONE. Ham License is exclusive personal use, so you get ONE ID per call sign. FCC has GMRS as a family licensed service, so one license can have multiple radios and users requiring multiple ID's for said radios. Who's managing that? The ham's don't manage the ID system for ham radio. A company that is in the business of selling and supporting DMR on ham radio runs the database. And what do you gain with DMR on GMRS? the repeaters can't be linked, since we are actually discussing that. So what do you gain? Another talk path via the second time slot. The requirement to buy a new radio and figure out the programming of that radio if you choose to go down that path. And you get TONS of interference in the analog repeaters that are preexisting. The on /off RF switching that DMR does causes an otherwise unintelligible signal if it were FM that can't be captured in an analog receiver to interfere with analog communications. Channels will fill with pulsed noise floors that would render the service unusable by others. And if you think that the lack of frequency coordination causes issues with GMRS now. DMR on GMRS would really create issues with the machine gun noise that DMR creates, from repeaters much farther away than what we see with analog wide band transmissions now. And how do you travel with DMR on GMRS. Lets say that it comes to pass and we get DMR on the service. The individual repeater owners are task with managing ID's. How do you get in a car and travel with DMR? Not only would you need to know the group call ID's for the repeater systems you want to communicate on but you would need a unique ID for that system. And the next system down the road has different group calls and ID's so then you need that info. And guess what? not all radios support multiple radio ID's (Motorola) so you have to reprogram the radio for each system that you want to communicate on. Yes, there are radios that support multiple ID's but they are the cheap import junk, not the Part 90 stuff that everyone wants. So you are stuck with a DMR Baofeng, or reprogramming your Motorola out on the road as you pass through the coverage area of various repeaters. Take it a step further, and say the FCC allows linking of DMR. Now you have Brandmeister / DMR-MARC for GMRS. And we come back to who is gonna manage the ID's group calls and repeater ID's for the system? There are 650 thousand ham's in the US. so that's a total of 650K ID's that COULD be issued. What's the family unit size for the possible number of required ID's? Grandparents, Parents and kids... lets call it 10 radios per call sign. All with individual ID's. 336K GMRS operators licensed is the number I found. Not sure on the number of GMRS repeaters out there that would all need an ID. But these are BIG numbers. And a BIG database. So I don't see it working and the ones asking for it have no idea what they are really asking for and would never be a part of dealing with the aftermath of getting it.
  8. OK, I have a minute to type this all out. Again. According to the statements made by the FCC regarding the issues created with linking multiple repeaters together are as follows. First is the inability to 'monitor' the frequency before transmitting. This is a carry over from Part 90 regulations when you have an FB2 commercial repeater pair. There is a requirement that you monitor the repeater output frequency in CSQ (no PL/DPL) before transmitting to verify that the frequency is not in use by another entity that's also assigned the frequency for their repeater / base station. FB2 frequencies are shared (issued to multiple entities) in a specific geographical location. They are NOT exclusive use frequencies like an FB6, FB8 of 'market frequency' meaning you 'own' that frequency in your geographical location. With an FB6 you can key up at any time and NOT monitor but can't transmit continuously. For a TRUNKED radio system the control channel has to be an FB8. With that designation, you can transmit 24/7/365 on that frequency. Same with a market frequency. The FBx designation sets a standard distance from the transmitter in kilometers that you can operate in. Market frequencies are similar but the 'allowed coverage' are is much larger. These were a carryover from the days of pagers where a paging company had a market area of operation and that market area was covered with a single frequency with total saturation (strong signal). To eliminate interference, a market frequency was only used once in some states and may not be available in any neighboring state depending on distances between transmitters. Power levels for the transmitters would exceed 1 kilowatt and ERP could be in the 10's of kilowatts depending on the antenna system. We don't have ANY of that with GMRS. We have 8 pairs that are NOT assigned or coordinated in any way that we can select from for a repeater and share (like an FB2) with other users. Since we WERE doing this, I can be specific. My repeater was in the Columbus Ohio area linked to others. But I will only discuss one repeater in Indiana for simplicity. I can't possibly hear any traffic NOT on the repeater I am linked to in Indiana, unless it's traffic on that specific repeater I am linked to. And likewise, users in Indiana can't hear a repeater in Columbus that I am sharing the frequency with before they key up. When they key the repeater in Indiana I am linked to, my repeater also begins to transmit and causes interference in Columbus with the local repeater I share the frequency with. And that's the problem that the FCC has issue with pertaining to interference. So how can it be addressed? Easiest way to address it is the repeater linking controller (Raspberry Pi) could have an input from a second receiver that monitors for traffic on the repeater output frequency in CSQ that would inhibit the transmit line from keying the local repeater it's connected to IF there was local traffic on the frequency. If a minimum height of the antenna for that receiver was established at no less than 50% of the height of the transmit antenna, then it would actually be BETTER than the user of the local repeater listening from their location since they aren't going to hear another user that's on the other side of the repeater in questions coverage area. This would 100% eliminate the concern of interference from a remote repeater keying on other users in the coverage are of that remote repeater. Over utilization of pairs is also a concern. And is easily addressed with requirements of how linking is done and WHERE it's done. Meaning, if a repeater owner has a linked repeater in a geographical location, that linked group can have no more than ONE repeater in that linked group in that area. If coverage infill is needed (addressing of poor coverage spots within the major coverage area of the repeater) it would have to be done with simulcast on a single frequency or not at all. That leaves other pairs open for other users. And an additional requirement that the repeater owner / linked system owner doesn't allow for others in a given geographical area to link to a running system where coverage is already established. Meaning if I have a repeater linked to a system in Columbus Ohio, that is the ONLY repeater / frequency / channel allowed to be linked to that system in Columbus. If another repeater owner wants to link their equipment to that system, they have to link to me, since I am established, with a same frequency simulcast setup or not link to that system. Of course if it's in another geographical location, that's not covered, like Cleveland for example, then they would be allowed to link to the system. But that repeater would be the ONLY one in Cleveland linked to the specific system in question. This would address the over utilization of the 8 repeater pairs we have for use in the GMRS service. That addresses the two major concerns with the FCC. Now we get into the PSTN / WIRE LINE control issues. This is pure and simple a rule change or better definition of each and what's allowed and what's not. There is an argument that the rule regrading linking to the PSTN was purely a 'phone patch' regulation. Back when that rule was set, long distance fee's were a thing. And long distance fee's were NOT applied to wire line (dry pair) connections for radio service, only telephone calls from a telephone customer to another customer outside of their exchange. It's believed that the phone companies were concerned about loosing out on revenue from long distance calls that could be made from a GMRS radio to a repeater in another exchange that had phone patch capabilities so they petitioned the FCC to ban that, and they did. There is nothing in the regulations specifically about 'wire line' control outside of remote control (telemetry) for GMRS, and I think the wire line thing is someones interpretation of the PSTN link, calling it wire line when they are two different things. Yes, this would need to be clarified / a rule change to get this dealt with. But again, not impossible to address, just one more small thing to address. Last issue is providing local coverage to an area covered by a linked repeater. Simple enough. Set a requirement to the owner of any linked repeater that a repeater of similar coverage that was NOT linked be available to users of that area. Meaning if there is a repeater owned by others, that is publicly available and OPEN to all licensed users and NOT for private use only, then you can just put up your repeater and link it without doing anything else. If such a repeater does NOT exist in the coverage area of your proposed repeater, you as the linked repeater owner should be required to provide that local repeater as well. And it be open for use with no more access requirement than the linked repeater has. Meaning fee's or club membership requirements. So yes, it's gonna take some rule changes, and it's NOT gonna be the 'wild west' like it was. And in truth, I think this would create usable linked systems that could co-exist with non-linked repeaters and GMRS users that would contribute to the service as a whole.
  9. Not going to work. Why???? Read my signature. That will work. This will not. It doesn't give a fix for the issues, just makes an unreasonable demand.
  10. I was thinking about this more and something that was mentioned but not really explained about having the PROPER test equipment when doing this. A standard watt meter is going to measure the power on ALL frequencies passing through it. Meaning if I connect a watt meter to a 10 channel combiner that has 3dB of loss in each port to the output, and I connect ten 100 watt radios to that combiner and key them all up I will see 500 watts of output in that watt meter. The meter is NOT specific enough to see the different frequencies, it only see's the TOTAL power passing through it. Why is that important? These CCR's are notorious for generating spurs on transmit. This can't really been seen with a watt meter, you have to have a spectrum analyzer to see them. But if there are 10 spurs at .5 watts each and a center carrier frequency of 5 watts. The radio is ONLY producing 5 watts on the frequency of operation, the other 5 watts of signal being produced is effectively noise. This is how the CB guys would get the big silly power numbers out of a CB radio back in the day. THe meter being used was seeing the primary carrier AND the second harmonic at double the frequency that was a couple watts. The meter just put in on the display. This is why a BIRD watt meter is more accurate. THe slugs are specific to frequency range. Outside that range, they don't work well and don't display the spurs. Of course no CB shops had spectrum analyzers that were actually in use, because they would show this and someone knowledgeable would see their BS for what it was. Same thing here with the 15 watts out of a portable radio. It might show it on the meter, but it's probably not all on the correct frequency, and the radio will NOT operate like that for very long.
  11. really????? here we go again.
  12. In addition to what Steve said. Mind you I didn't watch the video. But does it more than DOUBLE the power output? Doubling power output is an increase of 3dB. To change a standard S-meter fro S-1 to S-2 is a change of 6dB. Which of course isn't a real big change on the receiver end far as being able to hear a signal. My point is that you are not accomplishing much even doubling the output signal. So when you apply the stuff Steve said above to the whole discussion, it's really kind of pointless to do it.
  13. Well, You really need someone that is familiar with communications to work with you to figure all this out. With GMRS, every member not related to another member needs to have a license. So if a father son / sons are involved, they could all operate under one license. But no one else can. With ham it's specific to the individual to have a license with the correct allocations for the frequencies in use. This is typically not an issue any more. But a Novice license holder would not be able to operate in the VHF / UHF spectrum until they upgraded to a technician license. But your best bet is a statewide part 90 itinerant license with a repeater pair and a simplex frequency. You would be using part 90 radios that could be used for ham OR GMRS with the correct programming. The other possibility is getting an MOU from the agencies you will be service and having their assigned frequencies for SAR deployments programmed into the radios so you would have direct communications with Incident Command. Of course, you NEED to have an MOU, don't just start putting public safety frequencies in your radio thinking it will be ok. If your group is established and recognized by public safety agencies and you get calls from them requiring assistance on a search, then they may well want you to have their frequencies programmed so that they are getting real time information AND so when a search is called for weather, or the individual is located, they would want to pull everyone back in without needing to track a group leader down for each group to call back searchers. SAR during an activation is considered first responders in many states. For that length of time you are technically recognized as public safety. That's what I would be looking for, not what cheap radio service can I throw together some radios and use cheaply as humanly possible. Look at it like this. IF you are doing high angle (rope) rescue. You can get proper harnesses and ropes that are specifically designed to be used in that capacity. Or you can go to the hardware store and get whatever they have available that has a minimum break strength above what your heaviest guy is. It will work after all right? Same thing with radios. You send people out into the wilderness to search for someone, that radio is their lifeline back to the world. If they fall and get injured then that radio will bring them help. What would you want to be out in the boonies with? A good quality commercial radio, or a 15 dollar import that you bought because it was the cheapest thing you could find?
  14. More than that. Even if it was Part95E labeled for GMRS operation. Getting it to operate outside of the GMRS allocation would require a modification to the radio (software or hardware mod) which immediately invalidates the type acceptance of the radio, or ANY RADIO that you are modifying to operate out of the design parameters of the radio when it was new. To the OP What you have done is no different than putting 'extra channels' in a CB radio above CH40 and below CH1. You can't operate there either. And understand that getting caught doing that is gonna get your GMRS license revoked.
  15. Well, you need to remember that HAM operations for EMCOMM are done for a served agency. And ARES is a 'by request only' group. Meaning if the local authorities / EMA doesn't request their services, they aren't required or wanted. Driving around after a tornado or other significant event isn't really the safest thing to be doing. Especially if you aren't fully trained for doing it. Downed lines, tree's in the road, flooding, or other issues can possibly strand or injure you and then all of a sudden you are a victim in need of emergency services for rescue. The situation is created by someone's personal need to go out into an area with damage and assess that damage. So are you trained in damage assessment? Are you part of Public safety? Have you even been to a CERT training? Who are you reporting the damage to? Have they requested damage reports? I understand the want, need and desire to be able to contact family in a time of crisis. The knowledge they are ok, and all is well can be important for your mental well being. GMRS will do you well for accomplishing that goal. If there is either LOS between your houses, or there is a repeater / repeaters that you both have access to that will bridge that gap. Remember that if you are using another owners repeater that others may well be trying to do the same thing. So keep communications brief. Establish the health and welfare of all parties. Make plans to communicate again at a specific time and clear the airways for others to use the repeater. Try to have multiple paths of communication available, and TEST those paths at least monthly.
  16. Oh no,,,, not number of ham repeaters. Here we have a FULL dance card. I got the LAST available 2 meter pair for my P25 repeater and lucked into a UHF pair that a friend had and was abandoning that the repeater council transferred to me because the site I have has such good coverage. My UHF repeater see's some use. More than most but less than a few. The VHF repeater, as well as all the rest of the VHF repeaters in this area are stone silent. The VHF repeater does see some traffic from a south eastern ham net that is P25 and other digital modes I have that repeater linked to. But I haven't seen any local activity on that repeater at all on analog or P25.
  17. That ship sailed in 1994 when I got my Tech ticket. KB8VUL I have actively tried, and continue to try to bring old hams back and convince interested folks to become new hams. But you have to want to get into ham for the right reasons. If you aren't looking to expand your technical knowledge, and use ham radio as it was meant to be, then why bother.
  18. Except people to talk to. The FM bands are dead.
  19. Actually I have, multiple times. It's just htat no one actually listens to what anyone is saying on this topic because they have some preconceived notion that it's just more of the same. And in truth, much of it is. Go back and look at my posts about NOT having more than one repeater that's linked to a system in any given operating area. Read the part about a requirement that ANY linked repeater owner MUST insure that a non-linked repeater with similar coverage footprint must exist where they have a linked repeater. While that is a certainty that 2 pairs will be consumed, it also ensures that a local repeater will exist for the locals to use that's not just some garage repeater with a 40 foot high antenna while the linked repeater covers 4 counties. And part of that requirement is the local repeater should have similar or greater public access. The interference thing is simple enough to deal with. Receivers at the transmit sites of the linked repeaters keeping them from transmitting if the frequency is in use locally. Simple enough to do. My take is to build it better, not just toss something on the air and hide behind the 'equal use' regulations about repeater frequencies. But I agree, it can't be 3 or 4 repeaters in a single area on different frequencies all linked together. Hell I even put in that the only way to do infill for coverage is true simulcast transmit on a single frequency, or don't do it at all. But, that's not gonna happen either. None of the linking will come back.... you have a better chance of winning the lottery than seeing the FCC change it's tune on this. And for the record. I never ask for a DIME to access any of my repeaters, linked or otherwise. And argued the point with others about charging. SO that don't fly with me either.
  20. And that will probably be the end of propane fired anything on those grounds. Insurance companies tend to react to anything like this and tell policy holders that they will not continue their policies if they allow whatever source of a loss was to continue to be used at a facility. While there are several different 'reasons' stated for the removal of corporal punishment in schools, a bit of research will show you that the insurance companies, after paying out on a couple schools being sued, they put a stop to it by refusing to insure any school that still used that method of punishment.
  21. Well, he certainly called out NotARubicon on that. The parties over. Lets leave this to die. There are other options. But no one seems to want to go that route. Easiest is change frequencies and bring the nodes up on ham. Ham repeaters can be closed, as in if you don't have a valid GMRS license and were part of the GMRS linked groups, your not allowed on the new ham repeaters.
  22. 102 dB of path loss isn't actually that bad. If a repeater is putting out 40 watts that's 46dBm. so 46 - 102= -56dBm. That friend is a SCREAMING hot receive signal and will lay the needle in the needle in the corner so to speak. When you get down to a -115 dBm signal level, then you will start to hear noise in most receivers. By -119dBm the signal is going to be noticeably noisy and broken. This doesn't take into account, antenna gain at either end OR cable loss at either end. But, if you know antenna gain, tower height (for cable length). The type of cable. The duplexer used, and you have a verified accurate antenna system with known cable loss and gain of the antenna. You can calculate the RF power level being transmitted at the site. And be fairly close, like within ten watts.
  23. Center of the radiation source. Neither the tip or the base. However, with UHF antenna's int NOT going to make much difference. If this was an AM radio station and the tower was the driven element as many of them are. The tower might be 600 feet in height, but the center of radiation is the middle of the tower, or 300 feet. You can cee how that would make a difference
  24. Ahhh, you youngin's are just getting your toes wet. Since this is about GMRS, I will leave the number of VHF radios I have out of it. XPR6550 - I know of 18 that are in 6 bank chargers. There are more floating around, those are the ones I am sure of. XPR4550 - Again, I have 6 for sure that I can point out. Probably 10 to 12 total. I sold off most all of the CDM's I had. But there was once 20 plus of them before a trip to Hamfest sent them away. I kept 6 of them for console radios and for repeater setups in the CDR repeater units. Couple XTS5000 portables 6 XTL5000 mid power mobiles one XTL5000 high power mobile One XTS3000 portable One APX 7000 portable (has VHF too) One Harris xg-100P (tri-band with VHF and 800) ONE APX8500 (popped final in the UHF section, needs fixed. Will get around to that. three MTR2000 repeaters two MTR3000 repeaters two Quantar repeaters three or four (can't remember how many got sold) XPR8400/8300 repeaters I did buy some CCR Quansheng portable because it's suppose to cover from 18Mhz to 1.3 Ghz. Firmware updated it and then lost interest in it. It's sitting here too. Don't know what else. Probably a few Kenwood mobiles.
  25. It IS a wireline line by definition of wireline. Wireline, at least in the commercial radio field is any audio / telemetry that is sourced outside of the transmitter site. The method of transport isn't relevant. It can be microwave, phone lines, Ethernet, Satellite, or any other type of transport you what to bring up. If you are at location A and the transmitter is at location B, even across your yard, it's wireline. I understand you don't want that to be the case. You want to find some loophole that you can wave in the FCC's face and tell them to kick rocks. Part 95 doesn't define wireline. It defined elsewhere in CFR 47. I want it to not be this way too. I would be glad to put my repeater back up and link it so I can chat with others all over the place. But the FCC has decided that's not to be. Stop sitting here and complaining. I have already said how to go about getting it changed. Go do that and quit with this beating of a now mutilated dead horse.
