Flameout
Everything posted by Flameout
I'm hoping that you're not really serious??
I made a PVC type "hanger" for my slim jim. Was supposed to be temporary, but it's been there for over a year now. It's the arrow in the photo (sorry, it's the only photo I had available, but you can see what I mean)
I bought one of these cheap, Chinese spectrum analyzers and I was pretty successful in tuning the flat pack duplexers. I tried tuning one, then took ot to a local guy that had REAL equipment and he was surprised at how close I had it tuned. They are a pain to work with though! https://www.ebay.com/itm/353219998270?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=_4IuJVqfS0m&sssrc=4429486&ssuid=0zihXCkJQWG&var=&widget_ver=artemis&media=COPY This will give you an idea of what it looks like while tuning
What am I missing? I don't get the joke about using Andrew Heliax coax
Just pulled the trigger on a Comet GP-9NC, wish me luck 😅
Flameout replied to SvenMarbles's topic in General Discussion
Hmm, now you have me thinking. I'm currently using the 712efc, 60 feet up, and that thing really bends with the wind. I'm wondering if the 9nc would hold up OK, being 60' up. I do have a Commscope DB404, but it's awful compared to the 712efc -
They are old, but an Icom IC-FR4000 has all of those options. Or maybe a Motorola MTR2000? Sometimes new isn't necessarily better
That sounds exactly like someone in my area. He started getting upset because people were actually using it! I somewhat understand why some repeater owners are like that, but no one owns those frequencies I operate a repeater in my area and wish more people would use it. I have had well over 100 requests and if there are a handful of regular users, I'd be exaggerating. I certainly don't have one of those elaborate systems where I'm paying tower rental, but do have some expenses. Between my 50' tower, hardline, good N connectors, repeater(s), duplexer and antenna, I have well over $1,000 into it, but I actually want people to use it
You can't go by that. If you requested access, the repeater owner is notified via email immediately. I'm obviously logged in and this is what shows up for me
I kind of lean towards the Comet 712EFC myself. I took down my Commscope DB404 and replaced it with the Comet (up about 65') I'm at 1250' asl with the lowest elevation in my area being 700' (Ohio, Allegheny and Monongahela rivers)
Which antenna design should I go with for 2 repeaters I have?
Flameout replied to WRTA578's question in Technical Discussion
I bought that Commscope DB404b and wish that I hadn't. I just thought "it's expensive, so it MUST be good". Was a waste of money. I went with a Comet 712efc instead and it performs much better than that db404 Using an Icom IC-FR4000 repeater, TX/RX Systems 28-70-09 duplexer (pretty much the same as the one you listed, but older) and 1/2" hardline -
What do you all use for antennas at home?
Flameout replied to WRYC373's question in Technical Discussion
Using 2 Comet 712 EFC's (one for repeater, one for base) GAP Titan DX, Comet GP6, N9TAX Slim jim and MFJ-2012 OCF dipole. If you look closely, they are all in the photo. I also have a Commscope DB404 sitting in the garage. I replaced it with on of the 712's -
The Comet 712efc's are a great antenna for the price. I actually replaced my Commscope DB404 with one, and right now it's up over 50' on 4 of those fence top rails (of course with guy wires) Sounds like you'll have a nice setup
Which Is Better Or You Prefer, LMR600 Or Andrews Heliax?
Flameout replied to tcp2525's question in Technical Discussion
From everything I've read, the Andrew Heliax is better if you're running a repeater. For just a GMRS base station radio, either would be fine, with LMR600 being a bit of overkill, unless it's a really long run to the antenna. This is just my opinion and my observations If wanting it for a repeater, this may help a bit https://www.bridgecomsystems.com/blogs/bridgecom-official-blog/how-to-select-feedline-for-a-repeate -
Hey, whatever works!! Anytime a tower goes up for sale in my area, they get snatched up pretty quickly, so for now, I have been using those 1-3/8" galvanized top rail for fencing. I have 25' on my roof with my Comet 712 EFC (Top of antenna is about 50') and 40' of top rail for my Commscope DB404 (top of antenna is also around 50')Of course I had to add guy wires, but so far so good. This was supposed to be "temporary" but I said that about 9 months ago. So far they survived high winds and lightning
TXM Super Flex 1/2" Cable - FSJ4-50B
Flameout replied to Flameout's question in Technical Discussion
Before purchasing, I emailed them and asked if my Commscope/Andrew fittings that work on my Commscope fsj4-50b cable would work on theirs, and they assured me their cables were the the same specifications. On this TXM cable, you just have to be damn sure to to thread the fitting too tightly. I got things working and everything tests OK, but I'll stick with good USA made cable from now on -
I used the Commscope MCPT-1412. It did a good job prepping the cable, it's just when I threaded on the N connector, it tore up that cheap copper. I always use good fittings too. Was using an Andrew F4PNMV2-HC -
I do have some good LMR400 going to my GAP Titan DX HF antenna. I was 'hoping' that this TXM cable would be similar to the Andrew Heliax FSJ4-50b hardline to use on my repeater. I do have some abs industries 25400f on a repeater and it works great. The TXM sure is nothing like this good Andrew Heliax FSJ4 -
Motorola XPR-4550 radios for GMRS repeater, will they work?
Flameout replied to WSS's question in Technical Discussion
My XPR5550 works great on GMRS. No idea how to use them for repeaters, but I would think they should be able to be configured for it -
After messing around with this coax, I'd recommend to avoid it. It's like the cheap Chinese copper is thinner than the good USA made FSJ4-50B coax. Attaching a connector, it just shredded the copper.I finally got my connectors on and tests are ok, but I'd still never buy it again -
What is the best commercial radio for GMRS use?
Flameout replied to TheNevilleKid's topic in General Discussion
I have a few TK880's and some Motorolas. For me, I prefer my Motorola XPR5550e over the TK880's. Of course the 5550 is a bit newer than the Kenwood 880. For my HT, I either carry my Wouxoun KG-UV9Px or my Motorola XPR7550. The 7550 receives weaker signals that the UV9P doesn't, but the TX side is about the same -
Well, I just ordered 50', so since no one here has ever used it, I'll try to post my review of it after I get it installed -
I'd like to eliminate my 2-25' sections of coax (One section is Andrew Heliax LDF4-50a and the other Andrew Heliax FSJ4-50b connected with good N connectors) and searching, I came across the TXM cable, which I have never heard of. The specs are about identical to the Andrew FSJ4-50b but a lot less money so I was wondering if anyone here has used or is currently using it on their repeater setup, and how it's working out. https://www.txmstore.com/1-2-super-flexible-50-ohm-coax-cable-per-foot-compare-to-commscope-fsj4-50b-spf12/ It will feed my Commscope DB404 from my Motorola Radius GR500 repeater
That repeater is about 10 miles from me and I have never been able to hit it (he is the same guy running the DMR gmrs repeater, that I also have never been able to hit). BTW, mine is the Observatory Hill repeater just west of that WN2XFO repeater
Repeater antenna db gain vs altitude
Flameout replied to VETCOMMS's question in Technical Discussion
I'd try the Comet 712 EFC over the DB404. I was using the Comet on my repeater setup and thought I could improve coverage/performance with the DB404, so I bought one. The Comet performs MUCH better than my Commscope DB404
