Borage257
    2
Everything posted by Borage257
  1. My At-779UV does the red blinking light thing too. I just jiggle the mic cord and it resolves. Haven't had the audio issue described.
  2. Borage257
    Skip On GMRS
    Check this site out Tropospheric Ducting Forecast for VHF & UHF Radio & TV
  3. Aside from copper wire, I’ve used tape measures and rings from a trashed baby gate. If you use scrap, metal keep in mind, if it is coated in a white or light colored paint, your calculated measurements will be about 10%-15% bigger than what you need. This is because white paint has titanium dioxide in it. Titanium dioxide attenuates RF signal.
  4. Go to the website or GitHub to get the older releases
  5. Check out ANDFLMSG too
  6. To be fair that only happens in one region of the world regardless of the SWR...
  7. There’s a bunch of great content on YouTube. Some jeep channel has some stuff, ham radio crash course, ham radio 2.0 etc. all have gmrs content and some antenna stuff. You can get really in the weeds with some of the technical stuff. if you want training on how to use radios in different situations, you can search you tube for terms like “Pace plan” “soi” etc. TechPrepper has some good stuff on that, but you might look for some in person training since it’s hard to do that kind of thing by your self. GMRS is more based around bring your contacts than making new contacts with strange men.
  8. Man y’all need to get on Radio Mobile Online
  9. For what it’s worth, your numbers seem reasonable given the vegetation and topography. 42’ agl would yield an ideal radio horizon of about 8-12 miles. Now if you could get the antenna 42’ agl at the top of the hill….
  10. You can get 5ft antenna pole segments at Lowe’s/Home Depot that can be attached where the antenna is now. Get the antenna above the dish and get good coax The segments have a swaged end, so if the dish is mounted on a pole, you can simply set the segment into the dish mount.
  11. If you are using your satellite dish coax, you have an impedance mismatch. You are losing a TON of signal by using the wrong stuff. Screaming into a pillow in the garage expecting your friend a room or two over to hear you. Get some 50ohm coax, LMR400 or KMR400
  12. Randy has spoken
  13. You’re welcome! Pair it with a good LiFePo4 battery (20ah or more) and charger for emergency comms too!
  14. Ed fong gmrs collinear, any of the tram/comet etc collinear ground plane antenna.
  15. Another option would be to make a moxon antenna or yagi centered on 152.15 MHz or so
  16. N9taxlabs makes a dual band GMRS Murs roll up jpole. Quite easy to pull it up in to a tree with a throw weight and some line. I recommend get the 16’ cable and BNC connector options. BNC mod what ever HT you plan on using with the Jpole. 12lb test fishing line or higher will make getting the antenna into a tree easier. Tie the fishing line to your throw weight (or water bottle) heave it over a branch, cut it off the bottle and tie it to your paracord and pull it back over the branch with the antenna. https://n9taxlabs.com/shop/ols/products/dual-band-murs-gmrs-slim-jim-with-10-or-16-foot-cable
  17. Smileyantenna has a decent lineup of monoband antennas. Signalstick and Zbm2 industries has good dual band whips Those are all mom-and-pop companies based in the USA if that’s important
  18. They both have “gmrs only” counter parts. Rt95 and RB86
  19. Try jiggling the hand mic plug, mine will sometimes be special
  20. Rb86/th-8600, at-778uv, at-779uv/DB20G. could also try the db25g
  21. You don’t HAVE to wait…
  22. You can buy either a 12v or 15v. Both have adjustment screws to dial in your voltage.
  23. It’ll have to be wired up, but there’s this. https://a.co/d/05s7uRel
  24. Check out this video on sealing coax connections. I have found Temflex Rubber splicing tape with a layer of electrical tape over top to work well. 3M 3/4 in. x 22 ft. Temflex Splicing Tape, Gray 2155 - The Home Depot Generally more atmospheric moisture/humidity can cut signal range as much of it can be absorbed by the water. Alot of guys in my area see some degree of signal drop during and after rains as the pines pull the water into the needles.
  25. Might be good to enable a river beep on the repeater for your testing. I’d leave the squelch on 1. Get some friend (or family) to help you test various ranges too
