Shriekmau
    12
Shriekmau last won the day on April 15 2014
Shriekmau had the most liked content!
About Shriekmau
  • Birthday 03/21/1985
Contact Methods
  • Skype
    jeremymonnot@gmail.com
    NW Florida
1165 profile views
Shriekmau's Achievements
Newbie
Newbie (1/14)
24
Reputation
  1. I believe you are correct on the model. That seems to ring a bell with my memory. It has been a very good antenna for me. I get a lot of compliments on my range with a mag mount. The antenna seems to work equally well on VHF and UHF. It also seems to be quite durable as I have smacked it on a couple low obstacles which resulted it the mag mount tipping over yet the antenna was unharmed.
  2. I am using a Larsen NMO mount dual band VHF/UHF. It works really well for GMRS and Amateur bands. I can't remember the exact model number since I ordered it nearly a year ago.
  3. Cross band repeat specifically means to broadcast a signal on one band that was received on another. GMRS only operates within one band, so to cross band repeat with GMRS would mean one side or the other would not be operating on GMRS.
  4. I have heard of duplexers being thrown out of tune due to extreme heat or cold. If you have a way of checking them, start there. Sometimes when they are thrown out of tune it doesn't recover on it's own and must be re-tuned.
  5. I believe the answer is "no". The station broadcasting would need both licenses. GMRS and Ham can relay, but I do not think they allow for cross band repeat between the two. Now, you could use cross band for something like MURS and GMRS as long as the repeater operator has a GMRS license and the MURS side did not transmit at more than 0.5 watts.
  6. Unit 460, Thanks for the heads up! I have had my Tech ticket since September and upgraded to General in November. I have been operating on 10, 12, 15, and 17. I hope to get a couple more antennas up so I can get into the 20, 40, and 80. I should be getting my Extra before the end of the year.
  7. Welcome to the forum! Those 1 watt radios work well for what they are and what they were intended to be used for. As long as the repeater you are trying to access isn't using the frequencies backwards (repeater input using the band plan output and repeater output using the band plan input) then they should work. Those bubble pack radios work with repeaters which are configured to the suggested frequencies, they will not work with any odd-ball configurations. The benefit to using equipment specifically part 95 or if you so choose part 90, is the ability to customize Tx and Rx frequencies, as well as CTCSS and DCS encodings (I like to leave squelch open just in case). These units also have higher Tx power options equaling those part 97 HTs you seem to be more familiar with (4 watts for UHF and 5 watts VHF, and yes a lot of part 90 HTs which are not technically for GMRS will transmit on VHF). Many of the Chinese HTs work really well (part 90). Many users here have had great success with Baofeng, I have used Wouxun with great success as well. Baofeng will typically run you anywhere from $30 to $50 depending on the seller. Wouxun will typically run you between $70 and $150, again depending on the seller. I still have a Wouxun KG-UV6D that I use as a beater radio. It works on FRS, GMRS, 70CM, 2M, Marine channels, etc. Keep in mind these radios are part 90 and the Tx is wide open (if you can dial it in on the LCD, then you can transmit), it is also technically against the rules to use these on GMRS part 95 but many, MANY people do. If you would like more information on these or my experiences with them, feel free to ask or PM me. I will help any way I can.
  8. Awesome! I will have to look into this software. I might be able to use it.
  9. Sam, I have never had any issues with Motorola equipment. While I am not familiar with that model, I have no problem assuming you will be pleased with that unit.
  10. Sam, You mentioned you wanted direct programming capabilities. I assume you mean the ability to key in the desired frequency directly from the radio keypad? If so, this is in violation of FCC part 95 regulations. Part 95 radios are not intended to be field programmable, that way they are restricted to the presets defined by their programming. A field programmable UHF radio would be considered part 90 and not authorized for use on GMRS by the FCC. If caught using GMRS on part 90 equipment and the agent wanted to enforce the law, there could be repercussions for the station operator. Only trying to be helpful. The FCC regulations are sometimes not very clear, I have found myself confused several times and had to re-read or ask for assistance on these forums.
  11. Understood, and that makes sense.
  12. I seem to remember a previous discussion around HIPPA and the transmission of patient information over radios. If I remember right, HIPPA did not reach to cover patient information transmitted over radio. I could be remembering incorrectly though.
  13. All HTs seem to run hot on long transmissions. I have had a Yaesu, Icom, and 2 Wouxun. All of these units run very warm when transmitting. The radios with a metal exterior run uncomfortably hot since the case is acting like a heat-sync. I have never experienced malfunction when this happens, but because of this I try to keep from long Tx on these units.
  14. Very nice! Thats a really good price!
  15. Even better. The only downside is you don't get to see their face when the FCC shows up.
