SteveShannon
    463
  1. The fact that your UV5R receives the XTS when the tone is cleared out but not when a receive tone of 136.5 is set strongly suggests that the XTS isn’t sending a 136.5 Hz tone. Same for the second paragraph. The fact that your XTS isn’t expecting a 136.5 Hz tone. Try using your UV5R to scan for the tone your XTS is actually sending. Randy has a good video explaining how to:
  2. That’s how it should be.
  3. So try clearing the receiver tone from the XTS to see if it receives.
  4. So your transmitter on the XTS is working fine. Now set the receive tone on the UV5R to match the repeater input tone. Try it again. If you don’t receive the transmission then your transmit tone is wrong on the XTS. If you receive the transmission then there’s nothing wrong with your transmission.
  5. It doesn’t seem to make sense that your radio works fine on simplex but fails on a repeater. Set your other radio to receive on the repeater input frequency but leave tones turned off and see if your transmission to the repeater is picked up by your other radio.
  6. Here’s the website: https://nggmrs.org You must fill out an application before buying a membership. I looked for your call sign “WRUW910” in their roster but didn’t immediately find it. There’s also a spreadsheet on their site that lists repeaters, frequencies, and tones. Jasper doesn’t appear (at least when viewing on my phone).
  7. I’m not sure what your question is. Do you know how to access repeater details on this site? Here’s the page with details for the repeater you asked about but based on attached comments it appears that the information you need to access it is only available through the association’s website. https://mygmrs.com/repeater/414
  8. If you couldn’t hear the repeater until you removed the receive tone, chances are you had the wrong tone programmed. A receive tone acts a little like a bandpass filter. If you set a receive tone your squelch only opens up for transmissions that include that tone. If you remove the receive tone you receive all transmissions on that frequency, regardless of which tone they transmit. It’s like having three friends: Alice, Bob, and Charlie. Alice transmits and receives using tone A. Bob transmits and receives using tone B. Charlie transmits and receives using tone C. When you want to talk to Alice, you must transmit using tone A; neither Bob nor Charlie hear you. Likewise, if you transmit using tone B, only Bob hears you. Same for Charlie; he only hears what is transmitted using tone C. You can hear each one individually by setting your receiver to their individual tone, but if you want to hear all of them, you must leave your receiver set to no tone.
  9. I doubt it’s that bleak. Just have someone familiar with that model play with it.
  10. Welcome!
  11. I haven’t used one for GMRS but I have used Yagi antennas for finding radio trackers. If you only want to reach in one direction, such as to a repeater, a Yagi is a good way to enhance gain, but it will be nearly deaf in other directions, so it might not be a good choice to talk to your friends on simplex. How would you picture yourself using it?
  12. Actually nobody but you is still discussing it. You’re the only one who has posted since Friday. Maybe you have the responses sorted in order of votes rather than order of date and time. I’ve done that before.
  13. If you’re having a true emergency you don’t wait for a net; you declare an emergency and break in. Break, Break, Break You are interrupting in the middle of communication because you have an emergency. The fact that a Net is being conducted actually helps ensure that someone will hear your transmission! Nets are held to allow people to learn about and practice radio etiquette. Every person who uses a two way radio should take it upon themselves to learn radio etiquette. I know some people don’t want GMRS to resemble amateur radio, but basic radio etiquette should still be learned and practiced. Here’s one of several sources of information that may help you to know how to break in with an emergency transmission: https://quality2wayradios.com/store/two-way-radio-etiquette
  14. From this page: https://www.miklor.com/UV82/UV82-MenuDef.php R-TONE Repeater Tone - Used to activate those repeaters requiring a specific audible tone to be transmitted for access. - Sending tone requires first pressing the PTT, then pressing the [F] key. This is not to be confused with a sub-audible CTCSS or DCS code.
  15. It looks like they used the RT97 image.
  16. Are there any lights that light up to indicate power? I assume you checked the fuses in the power cable and that the power cable is connected correctly polarity wise. Also, there is an internal fuse (page 19 of the service manual), password protection, and there’s an “ignition sense” option that turns on the radio when it senses that your car is started. Good luck. Here’s the operator manual: Here’s the service manual (you’ll have to do the whole Captcha thing):
  17. Nice. Yes, you probably could run it once a day as a cron. If the pi is never restarted and if rc.updatenodelist just runs and sleeps then eventually you’ll have the same problem, but it may take nearly two years! The real question I have is if rc.updatenoelist runs to completion and breaks out of its loop or if it continues running. If it exits eventually then it shouldn’t be gobbling up memory and you could run it as a cron more frequently. It was only because you had like 544 instances running and sleeping that you had problems (that’s what I think anyway).
  18. I don’t think anything is wrong. You shouldn’t expect a handheld radio not to have its receiver circuitry overwhelmed by a high power transmitter nearby.
  19. That seems like the best or at least only thing to do to keep from chewing through memory. Do any instances of rc.updatenodelist run at all? Are there any sleeping? I think I read somewhere that a module called “dial” might call it once. Is it possible there’s a problem in the extnodefile itself?
  20. Remove the antenna on your handheld. Does it still happen? Is the case correctly assembled to the repeater? What about the duplexer? Cables? I suspect your handheld is just not very good at rejecting interference from the repeater. Typically you’d never use a handheld in the same room as a repeater.
  21. Is there a transmit LED or display on the repeater (or even a wattmeter on the output) that indicates when the transmitter is transmitting? Does it stop if you power down the repeater? (I know that probably sounds like a dumb question and maybe it is. )
  22. Help me understand the proximities involved and the exact nature of your concern. When you’re in the same room as the repeater with one of your handhelds, no matter what channel you tune the handheld to you hear whatever the repeater transmits. Also, using an identical handheld, when you go farther away from the repeater the handheld only hears the repeater on the correct channel. Is that a correct description?
