466
Here’s the website: https://nggmrs.org You must fill out an application before buying a membership. I looked for your call sign “WRUW910” in their roster but didn’t immediately find it. There’s also a spreadsheet on their site that lists repeaters, frequencies, and tones. Jasper doesn’t appear (at least when viewing on my phone).
I’m not sure what your question is. Do you know how to access repeater details on this site? Here’s the page with details for the repeater you asked about but based on attached comments it appears that the information you need to access it is only available through the association’s website. https://mygmrs.com/repeater/414
If you couldn’t hear the repeater until you removed the receive tone, chances are you had the wrong tone programmed. A receive tone acts a little like a bandpass filter. If you set a receive tone your squelch only opens up for transmissions that include that tone. If you remove the receive tone you receive all transmissions on that frequency, regardless of which tone they transmit. It’s like having three friends: Alice, Bob, and Charlie. Alice transmits and receives using tone A. Bob transmits and receives using tone B. Charlie transmits and receives using tone C. When you want to talk to Alice, you must transmit using tone A; neither Bob nor Charlie hear you. Likewise, if you transmit using tone B, only Bob hears you. Same for Charlie; he only hears what is transmitted using tone C. You can hear each one individually by setting your receiver to their individual tone, but if you want to hear all of them, you must leave your receiver set to no tone.
I doubt it’s that bleak. Just have someone familiar with that model play with it.
Welcome!
I haven’t used one for GMRS but I have used Yagi antennas for finding radio trackers. If you only want to reach in one direction, such as to a repeater, a Yagi is a good way to enhance gain, but it will be nearly deaf in other directions, so it might not be a good choice to talk to your friends on simplex. How would you picture yourself using it?
Actually nobody but you is still discussing it. You’re the only one who has posted since Friday. Maybe you have the responses sorted in order of votes rather than order of date and time. I’ve done that before.
If you’re having a true emergency you don’t wait for a net; you declare an emergency and break in. Break, Break, Break You are interrupting in the middle of communication because you have an emergency. The fact that a Net is being conducted actually helps ensure that someone will hear your transmission! Nets are held to allow people to learn about and practice radio etiquette. Every person who uses a two way radio should take it upon themselves to learn radio etiquette. I know some people don’t want GMRS to resemble amateur radio, but basic radio etiquette should still be learned and practiced. Here’s one of several sources of information that may help you to know how to break in with an emergency transmission: https://quality2wayradios.com/store/two-way-radio-etiquette
- 97 replies
- repeaters
- repeater build
(and 1 more)
Tagged with:
I buy the GMRS 9R and i got some confusion on setting.
SteveShannon replied to Luish19779's question in Technical Discussion
From this page: https://www.miklor.com/UV82/UV82-MenuDef.php R-TONE Repeater Tone - Used to activate those repeaters requiring a specific audible tone to be transmitted for access. - Sending tone requires first pressing the PTT, then pressing the [F] key. This is not to be confused with a sub-audible CTCSS or DCS code. -
CDM1550 + RT97s linking to network challenge
SteveShannon replied to HrXkb3UjmgFvBe's question in Technical Discussion
It looks like they used the RT97 image. -
Are there any lights that light up to indicate power? I assume you checked the fuses in the power cable and that the power cable is connected correctly polarity wise. Also, there is an internal fuse (page 19 of the service manual), password protection, and there’s an “ignition sense” option that turns on the radio when it senses that your car is started. Good luck. Here’s the operator manual: Here’s the service manual (you’ll have to do the whole Captcha thing):
Running Node on Raspberry Pi 4/Modifying Hamvoip
SteveShannon replied to FrostyFruits's question in Technical Discussion
Nice. Yes, you probably could run it once a day as a cron. If the pi is never restarted and if rc.updatenodelist just runs and sleeps then eventually you’ll have the same problem, but it may take nearly two years! The real question I have is if rc.updatenoelist runs to completion and breaks out of its loop or if it continues running. If it exits eventually then it shouldn’t be gobbling up memory and you could run it as a cron more frequently. It was only because you had like 544 instances running and sleeping that you had problems (that’s what I think anyway).- 39 replies
- raspberry pi
- raspberry pi 4
- (and 5 more)
I don’t think anything is wrong. You shouldn’t expect a handheld radio not to have its receiver circuitry overwhelmed by a high power transmitter nearby.
That seems like the best or at least only thing to do to keep from chewing through memory. Do any instances of rc.updatenodelist run at all? Are there any sleeping? I think I read somewhere that a module called “dial” might call it once. Is it possible there’s a problem in the extnodefile itself?- 39 replies
- raspberry pi
- raspberry pi 4
- (and 5 more)
Remove the antenna on your handheld. Does it still happen? Is the case correctly assembled to the repeater? What about the duplexer? Cables? I suspect your handheld is just not very good at rejecting interference from the repeater. Typically you’d never use a handheld in the same room as a repeater.
Is there a transmit LED or display on the repeater (or even a wattmeter on the output) that indicates when the transmitter is transmitting? Does it stop if you power down the repeater? (I know that probably sounds like a dumb question and maybe it is. )
Help me understand the proximities involved and the exact nature of your concern. When you’re in the same room as the repeater with one of your handhelds, no matter what channel you tune the handheld to you hear whatever the repeater transmits. Also, using an identical handheld, when you go farther away from the repeater the handheld only hears the repeater on the correct channel. Is that a correct description?
Why no state issued GMRS call sign license plates?
SteveShannon replied to Lscott's topic in General Discussion
Thanks! -
Also, DCS is what most companies call it. DPL is just what Motorola calls theirs.
Are you sure you haven’t changed anything in the code? In particular look at the post immediately above your first post where WRLJ719 talks about the call to rc.updatenodelist. Also, his post appears to have a misspelling “rc.updatenodeist” rather than “rc.updatenodelist”. Nothing makes a person more aware of spelling than programming. It looks like cron is spawning new instances of “rc.updatenodelist” which runs and then goes to sleep, over and over and over, each time eating up valuable resources until there are none left. I suspect either rc.updatenodelist needs to exit gracefully, rather than sleeping, or something needs to be fixed in crontab. I doubt it needs to run very frequently anyway, but it should exit each time. That link to the stackoverflow question that I pasted above has other suggestions for diagnosis. You probably do have the 3b+ but that shouldn’t matter. So, look at where you were when you followed this instruction: ”Change your crontab -e to run rc.updatenodelist” and make sure you did it correctly and that you included the asterisk as pointed out by WRLJ719.- 39 replies
- raspberry pi
- raspberry pi 4
- (and 5 more)
My rule on metal roofs is to get on them as seldom as possible and to rope off if the pitch is uncomfortable. At that height, and running the cable the way you have to you’re possibly going to lose a lot of signal just in the coax. Be sure to use the best coax you can. Here’s a website that has several charts showing coax losses. Be sure to look at the 450 MHz values: https://www.w4rp.com/ref/coax.html Second, I’m not sure that either of those antennas will get you the performance you might hope. Try putting that mag mount with either Nagoya onto a metal pie plate on a painters pole out in your yard first, or even on the roof of your car. Does it work well enough? If so, then maybe get on the roof. If it doesn’t work then you’ve saved yourself a trip.
Antenna Issues- Confusing performance
SteveShannon replied to WRED210's question in Technical Discussion
I was wrong to focus on problems like shorts or opens. KAF6045 is correct. With RG58 you lose half of your power every thirty feet. Sometimes you can up for that by placing a decent quality antenna up in the air, but with a bad antenna, a bad cable, or a weak signal lack of quality will really bite you. Borrowing a VNA from someone can tell you if you have the kind of problem I was overly fixated on before (opens and shorts), but won’t tell you if your antenna has lousy performance. If an HT with a Nagoya has good performance but an antenna up in the air doesn’t you have every right to be suspicious of both the antenna and the cable. I’ll include a link to a website with performance charts for various cables. Be sure to look at the frequency you’re using. The closest frequency will probably be 450 MHz. Because GMRS is slightly higher, the losses through cable at GMRS frequencies will be even worse, but not a lot. Every 3dB loss means half of the remaining power, so 10.6 dB loss costs about 90% of the power. That’s for 100 feet. At 35 feet you lose over 3.7 dB so you probably lose 55% of the signal each direction. That’s substantial and enough to make it difficult to know if the antenna works or not. Of course everything adds up. It helps to start with something you know works and then try one thing at a time to see where you can get some improvements. Coax losses site I mentioned: https://www.w4rp.com/ref/coax.html -
You really can rule out almost everything by swapping things out. It’s a quick and easy way to troubleshoot.
