SteveShannon
    461
  1. The greater the current the more the voltage drops. Transmitting would consume more current so it’s possible you see a drop when transmitting. A battery doesn’t put out the full voltage that the alternator does, but testing with the engine off does get rid of the greatest source of RF noise under the hood ?. I think Midland stuff is probably as good as anything other than commercial radios. It’s certainly good enough. As you progress you might decide you want something else, but for now just enjoy it. Chasing that last watt or two can make you crazy without really being too meaningful. I would just make sure that your radio works well enough to converse with the people you want and reach the repeaters in your neck of the woods. I would be a little concerned about electrical noise on the power line when the engine is running. I think that you’d hear it though. That radio shop technician will know much more than me. Best wishes!
  2. 1. Make sure you’re using test equipment that’s high quality and accurately calibrated and appropriate for the frequency and power level you’re using. Make sure you’re testing at the specified voltage (13.8!) and using power cables that won’t cause voltage drop. It might help to visit a local radio shop. 2. That can depend on a lot of things. Is your power wiring noisy? How high quality is your coax? When it comes to antennas, everything affects everything and a noisy power cable parallel to the coax could cause problems.
  3. It’s because Your antenna is tuned better on the 467 MHz repeater frequencies than the 462 MHz simplex frequencies. It’s still good enough as BoxCar explained.
  4. All masts should be grounded and all fixed location antennas should be connected through a lightning arrester where they pass into the house. A lightning arrester grounds the shield of the coax and also helps protect the radio from static electricity buildup.
  5. In these forums there have been a few of those SW-102s which reported output power incorrectly from the factory. I would check it against a known good meter.
  6. 1. For any given antenna, SWR changes with frequency. A graph of SWR vs. frequency often looks like there’s a sharp dip at the resonant frequency. 2. Where are you measuring the output power? A dummy load will appear to the transmitter like an antenna that has a very low SWR at every frequency. Also, was your Jeep running and putting out 13.8 volts or were you on battery at a voltage of 12+ volts? On battery power the output power will sag slightly. Or it might just have been the radio you received. Many things can affect output power: input power, antenna cable, antenna, ground plane, etc. 3. Pretuned to center channel probably means that it’s tuned to midway between the 462 (used for simplex communications) and 467 MHz (which you transmit to a repeater) frequencies of the band, or about 465 MHz. 4. Tuning the antenna to have a lower SWR might get you more transmitted watts, but honestly a few watts isn’t detectable in actual use. I recommend either leaving the antenna alone or tuning it to the frequency you transmit on most often. A higher frequency means a shorter antenna element, but if you shorten it too much it’s hard to undo.
  7. You might want to review @OffRoaderXconclusions about using two KG1000 units. He has spoken about it here. I think he now uses a commercial repeater.
  8. In a sense it happened when you had to provide your call sign to join this site and it was verified against the FCC database before you were given full access. That’s one reason why the database exists and it’s also why we don’t need to carry our licenses with us.
  9. Another inexpensive way to listen to air frequencies (or just about any other frequencies between 25MHz-1750MHz and any analog mode) is to use one of the USB SDR dongles. https://www.nooelec.com/store/sdr/sdr-receivers/nesdr-mini.html
  10. There are places in the USA that stock NanoVNAs. Based on reviews on the Ham Radio 2.0 YouTube channel, here’s where I bought my NanoVNA. I got it in less than a week. http://www.randl.com/shop/catalog/index.php?manufacturers_id=142&osCsid=fu3f0ql3nieitil9ir623bmcb6 I’m a Volunteer Examiner for my local ham radio club. We’re part of the Laurel VE organization. We (three VEs grade each test) do in person testing and then our VEC (Volunteer Examiner Coordinator) submits the scores electronically using an online portal set up for that. Usually a person has access to their license file within 24 hours. I have a friend in Seattle who is also a VE. His group does virtual examinations. Except for using video conferencing software to watch the person taking the test, it’s the same process. Three VEs watch each person and grade their test and then their VEC submits electronically. I didn’t even know that the test results could still be done snail mail. It’s funny what you said about biometrics. When I was working, my boss (who was a very nice lady much younger than me) thought it would be “really cool” if we had fingerprint scanners to enter our secure facility and suggested that I look into it. The group I supervised managed the access control system. A cybersecurity auditor explained to me that they prefer not to see biometric forms of ID verification adopted because once someone has the ability to spoof your biometrics, your biometrics are worthless as an ID. You cannot easily change your fingerprints, facial structure, retinal pattern, etc, like you can a password, pass phrases, PIN, RFID chip based token, etc. So, we avoided biometrics. Do you use them for identification somewhere? If not, the data captured from a Zoom call probably isn’t a threat. Hopefully your license will appear in ULS at any moment.
  11. Check your FCC online record. VEs work with VECs, who typically submit electronically. Also, the FCC doesn’t send anything to you via snail mail. Your license file is accessed electronically. You are responsible for printing it.
  12. I hope you love it and feel a greater connection to your dad!
  13. I absolutely understand, but many clubs now have a barebones website (thanks to WRTJ887 for posting the link) and use Facebook for their announcements and conversations. Hopefully you’ll have a great time with them.
  14. The Oklahoma GMRS Facebook group has 470 members and seems somewhat active. https://www.facebook.com/groups/338406913899977/?ref=share Also, Repeaterbook lists two GMRS repeaters in Tulsa: https://www.repeaterbook.com/gmrs/location_search.php?state_id=40&type=city&loc=Tulsa
  15. Great point!
  16. Congratulations! I think you’ll enjoy it. This thread by another forum user makes the Tram 1486 antenna sound good: It really depends on how you want to use your radios. If you only want to talk between work and your house, a directional antenna like a Yagi, on a mast at your house and pointed at your place of work might be just what you want. If you want to be able to travel in any direction around your house, you’ll want an omnidirectional antenna like the Tram. People even use magnetic mount vehicle antennas on steel pizza pans. Half the fun is figuring it all out.
  17. When you use a transceiver at a fixed location to communicate to a mobile radio through a repeater, it is functioning as a control station. Please note that it “May also” be used to control the repeater. It’s not a requirement that a control station be able to fully control every function of the repeater and communicating through a repeater could be considered a level of control because you are causing the repeater to relay your transmissions. If you use that same transceiver to communicate directly to a mobile radio, it is functioning as a base station. The difference is in usage. Referring to a radio as a base station doesn’t prohibit it from being used to communicate through a repeater.
  18. Be undepressed! I used the Advanced Search function and received 25 repeaters in Kentucky. You should be able to see what parameter I used from this screen shot. All I did was enter the name of the state. Only a few of them fit in the screen shot, but you can perform the same search. Only ten appear per page.
  19. An overly technical wandering data dump like this does nothing to help the guy. Also, some jobs prohibit cell phones in order to minimize internet surfing, prevent photography, or control wifi devices. Although I’m curious what the situation is, the OP has no obligation to explain the reasons to me or you.
  20. No. If you leave no tone set you’ll receive everything transmitted on that frequency. If you set a receive tone you’ll only hear things transmitted using that tone, but while you’re troubleshooting problems that’s not helpful.
  21. I had to use the older version of the software on my Win7 computer. The update didn’t work. The duplexer doesn’t change the frequency of your signals if it’s not tuned correctly. You just don’t get enough filtering to prevent the very strong transmitter signal from entering the receiver section, so I wouldn’t classify it as interference.
  22. I thought that was probably what that cylindrical socket was on the lower right of the panel. Let us know how the proof of concept works and what you might do differently on V2.0.
  23. That looks like it would be very convenient. One reason mounting the panel on the end like that might not be popular is because that’s the end that gets beaten up if using the box as a portable power supply, but if you’re not moving it around that’s not a concern. How did you propose to connect the repeater to the power box? I would suggest Anderson Power Poles as a way to connect to the box.
  24. Yes, both the Midland Mxt500 or the Wouxun KG1000 will work just fine with the KG905. Whether they can communicate over that distance is subject to a lot of different variables, like I mentioned earlier. Because I have no personal experience with base station antennas I cannot make a recommendation, but there are lots of threads here that discuss base station antennas. It sounds like you have two or more KG905 radios. If that’s true, have you tried them talking to each other to see what kind of range you get? Then, do some research to see what might exist for repeaters. I’ll post this and then go look at the repeater listing for San Antonio. Repeaters are usually set atop a hill or elsewhere with their antennas raised up where they can be “seen” from a wide area. If there’s a repeater in your area that you can reach from your workplace and from your home, that would possibly allow you to communicate without needing a base station or base station antenna. Of course that doesn’t mean you should not get a base station, but anything that makes communicating more reliable is a good thing. I’ll add whatever I find about repeaters here: It appears there’s a vibrant community of repeaters (at least five different repeaters) in your area. Here’s a website the community maintains: http://1510.node.gmrslive.com/supermon/ Best wishes as you learn about this.
