SteveShannon
    485
  1. Pardon the intrusion, Question 0: does the screen indicate the radio is transmitting when the PTT is pressed.
  2. From the Chirp page: Warnings from AntiVirus and AntiMalware software about CHIRP Users of CHIRP may experience false positives from their anti-virus/malware software, their browser, etc. Unfortunately, there are not easy solutions to this problem as CHIRP is a volunteer effort without the financial and legal resources to secure agreements with these companies. Further, CHIRP releases fixes and features very often, so that users get the latest stuff as soon as possible. That means the "reputation" for a given version of CHIRP may be lower, the newer it is. For more information about false positives and AntiVirus in general, see some if these articles: What are antivirus false positives? How to tell if a virus is actually a false positive Still paying for antivirus? Experts say you probably don't need it Below are some common examples of what you may see, and how to handle them. Recommendation: Tell your antivirus provider that the file is not a virus! They won't know if you don't tell them and especially if you're paying for their services, make them get it right. If you can report the file as safe, it helps the other users of CHIRP because it decreases the likelihood of them seeing a warning and improves the general "reputation" of the CHIRP project. (The webpage goes on, but due to advertising I didn’t copy it all. If you want to know more go to https://chirpmyradio.com/projects/chirp/wiki/AntiVirusWarnings
  3. Wrong on both counts. I have several seats of RT Software and there are some very serious bugs in those seats which manipulate linked tables of DMR zones and groups that can completely corrupt a codeplug. Having said that I will continue using RT Systems software, avoiding those features which corrupt memory. As far as Chirp goes although it is free, it is no sketchier than any other software I’ve used and the developer is very responsive. I’ll continue using it as well. As far as triggering malware detection software I’ve seen false positives on several different CPS programs by various antivirus programs. The reason is heuristic detection. It works by watching for snippets of software that resemble malware. Programs intended to program radios match that pattern, even though they don’t have actual malware embedded. That has been discussed before; it’s not new.
  4. I’ve not found a mic gain setting but there is an xmit inhibit setting. Which channel is it? Post your configuration file and let us look at it. There is a per channel checkbox for Compander, which just sounds bad on the db20. I recommend unchecking it. And Merry Christmas!
  5. Merry Christmas Lauren and welcome. I’ve reported your post to Rich (the administrator/owner). He’s very helpful.
  6. Export the channels from both and compare them.
  7. It’s not a digital radio.
  8. I don’t think that it’s as simple as that. According to this document PVC is more polarizable in the presence of RF and has a higher dielectric constant than other plastics and composite materials, especially at higher frequencies. This document discusses the materials which are more suitable for use as radioed: https://www.curbellplastics.com/wp-content/uploads/2022/11/Plastics-for-High-Performance-Radomes-White-Paper.pdf
  9. Here’s a quote from a post on RadioReference: I once did an experiment with a simple dipole on VHF. The dipole was made with #8 solid wire, and it's resonant frequency was measured. It was then encased in PVC and the resonant frequency was remeasured, and found to have moved over a MHz. That was at VHF. I expect the effect at 2.4 GHz would be worse. https://forums.radioreference.com/threads/protecting-yagi-with-pvc-or-other-material.298291/#:~:text=The issue is nopt necessarily,it'll work just fine.
  10. No, I don’t think there’s any way to tell if you’re not reaching the repeater, but there are signs that you’re reaching it, such as an ID or even a response. But if you hear Morse code in response to saying “test,” I believe you’re hitting the repeater. Many repeaters are set to ID themselves using Morse code and if it has been a while since the repeater has been used it will immediately ID itself in response to receiving your transmission. Instead of saying “test”, give your call sign and ask for a radio check: “This is wxyz123. Can I get a radio check?” No, you don’t need to have the receive tone set. In fact if you’re in a low traffic area it’s probably best not to set it.
  11. Exactly this^^^^
  12. Sorry, I don’t have first hand knowledge, but here’s a post on radio reference where the settings are discussed as having problems: https://forums.radioreference.com/threads/xpr-8400-cwid-problem.382441/ @Radioguy7268 has experience with these settings. Maybe he’s around.
  13. I would clean up the language. Anything more can still be done later if necessary.
  14. Yeah, I hadn’t read that before I responded here. I still hope Keith sticks around.
  15. The day is young.
  16. The scrambling is extremely easy for anyone to unscramble. It’s just phase inversion. Many cheap handhelds have that. All you have to do is turn it on and play with the level. As far as the frequency hopping, it depends on how it’s synchronized, but the statement the nobody will be able to decipher you is certainly not true and it doesn’t take one of the alphabet agencies, just someone with deep enough pockets to buy an AR5RM.
  17. You’re required to ID every 15 minutes when transmitting.
  18. Ahh, I see. Here is where it blew up overnight. As someone whose wife is confined to a wheelchair I can absolutely understand why a person with a kid in a wheelchair would feel upset about a comment that uses a kid in a wheelchair as a simile for being helpless. Until a loved one has been in that situation you might not get it, but having a loved one disabled does make us more sensitive about things we might otherwise have understood differently. But I don’t think that Randy went to the extent of finding out that your child was in a wheelchair and deliberately chose that as a way to goad you personally. I think it was just one of those insensitive comments that people make. I understand Ken being upset about the language also. How about we all go wrap gifts or something and take a mental health break. The unfortunate thing is you are people who might actually like each other in different circumstances, but because you’re only seeing that one sharp edge that’s being presented that’s where your focus is.
  19. You should be able to delete your repeaters if you’re getting rid of them, or at the very least mark them as closed or offline, whichever is correct. As far as your 869 posts, I don’t believe you can get rid of them, but I know at least two other former members left and had their accounts deleted, which changes the name on their posts to “Guest”. Still, wherever someone quoted their posts in the past remains with their old user name. It would be a huge mess to try to clean that up and honestly I hope your content remains. I learned from it. Only Rich can delete your account. @rdunajewski I would be sorry if you do leave. I don’t know what events caused you to feel this way, but stress is always higher this time of year and I understand how a person might need a break. I suggest mulling it over a few days. Take time for family and friends. I hope you have a nice holiday season no matter what.
  20. I’m sorry if I said something that confused you. When you transmit on the right repeater channel, your radios should each be transmitting on 467.650 MHz and receiving on 462.650 MHz and it sounds like that’s exactly what they’re doing. But you aren’t receiving the repeater’s output signal. So, when you tune the receiver on B to 467.650 MHz you receive the signal directly from the other handheld, but you’re still not receiving the signal from the repeater. So what we have to figure out is why. Is the repeater not receiving your signal on 467.650, which can happen if you’re too far away or on the wrong frequency? Or is the repeater receiving your signal on 467.650 but choosing not to retransmit it, which can happen if you have the wrong CTCSS tone? But I’m slightly confused by the channel number. I think 462.650 MHz is channel 27 (aka 19R or 19RP) on the GMRS channels, not channel 26 unless you programmed it that way.
  21. Merry Christmas! With the right adapter it could be even shorter
  22. Much simpler than my explanation. Good job!
  23. Eight frequencies have been designated in regulations for repeaters to transmit upon. They are the same eight frequencies used by both FRS and GMRS for simplex communications and they are numbers 15-22 in the FRS regulations: (a) 462 MHz main channels. Only mobile, hand-held portable, repeater, base and fixed stations may transmit on these 8 channels. The channel center frequencies are: 462.5500, 462.5750, 462.6000, 462.6250, 462.6500, 462.6750, 462.7000, and 462.7250 MHz. Eight other frequencies, 5 MHz higher in frequency, have been designated by regulation for transmission by stations wishing to transmit to a repeater for relay by the repeater: (c) 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz. All GMRS certified radios pair the eight channels in those two groups into repeater pairs. Thus, a radio transmitting to a repeater on 467.5500 MHz receives from that same repeater on 462.5500 MHz. The FCC did not assign channel numbers to the repeater pairs in the GMRS regulations, but they did assign numbers to the first 22 channels in the FRS regulations https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-B Because channels 15-22 (462 MHz main channels) are dual purpose, as shared simplex channels for FRS and GMRS and as repeater output channels, some manufacturers refer to the repeater pairs as RP15 - RP22. Others simply continue the numbering sequence by referring to the repeater pairs as channels 23-30. Other call them repeater channels 1-8. The best thing to do is to be aware of the frequencies allocated in regulation and learn what your radio manufacturer calls them.
  24. As you can see from my meter foible, I can not afford too much hubris. Good job figuring it out! On many occasions a good night’s sleep has yielded better results.
  25. Well, that’s embarrassing. The black lead was in the current reading A socket rather than the Com socket. Obviously it must be low impedance (perhaps just a fuse) between the two sockets, but it’s not right. Mea culpa, mea culpa, mea maxima culpa!
