jwilkers
    18
jwilkers last won the day on June 14 2023
jwilkers had the most liked content!
1 Follower
About jwilkers
  • Birthday 03/14/1965
Contact Methods
  • Skype
    jlwilkers
    John Wilkerson
    Columbus, Ohio
  • Interests
    Amateur Radio: KD8DVR
    GMRS: WRNL832
1584 profile views
jwilkers's Achievements
  1. No good buddy beeps unless you want to find yourself with no one to talk to. Sent from my SM-S911U1 using Tapatalk
  2. DPMR 446 operates in the 70cm amateur band in the USA. An amateur radio license is required to operate there. Sent from my SM-S911U1 using Tapatalk
  3. ISM radios are limited by power and antenna type. You'll have about 3/4 of a mile coverage. Sent from my SM-S911U1 using Tapatalk
  4. Leave it as is. You'll be fine. Sent from my SM-S911U1 using Tapatalk
  5. You require a DMR ID to access amateur radio networks. Sent from my SM-S911U1 using Tapatalk
  6. The BTECH 25x4 uses HT finals, overdriven to 20 watts or so. My UHF went out on mine. I still use it for 220. It also has memory issues now, that I finally got ironed out. Sent from my SM-S911U1 using Tapatalk
  7. You cannot use ham repeaters without a ham license, period. You must reprogram the radio to frequencies you are legally licensed to use. Sent from my SM-S911U1 using Tapatalk
  8. Mine has been working great over 2 years. I'd write btech for an exchange if it doesn't work after a cool down. Sent from my SM-S911U1 using Tapatalk
  9. No. Totally different companies Sent from my SM-S911U1 using Tapatalk
  10. True Sent from my SM-S911U1 using Tapatalk
  11. They do. But some older commercial equipment got both part 90 and part 95 certified. Now manufacturers are too lazy to get both. Sent from my SM-S911U1 using Tapatalk
  12. Frs is handheld only Sent from my SM-S911U1 using Tapatalk
  13. There is no such thing Sent from my SM-S911U1 using Tapatalk
  14. Most repeater owners and users will tell.you to turn off the beep. Its annoying and unnecessary. Sent from my SM-S911U1 using Tapatalk
  15. My radio of choice is the BTECH GMRS-20V2. Fully Programmable channels with unlimited flexibility. Sent from my SM-S911U1 using Tapatalk
