WRQI583
Everything posted by WRQI583
I think what you are looking for is what many companies used back in the day and probably still use today. It requires one radio with what they called Remote bases or remotes stations. The picture shown here is called an extended local remote. The draw back is that you cannot generally change the channel in your situation but if you are looking to monitor one repeater or simplex channel, this is about the closest I can come to what you are looking to do. I worked for a newspaper company when I was younger and they had these spread throughout the building for their radio. To the best of my knowledge, they require one radio, not two.
Believe it or not, I have heard many hams over the years and probably more so regular civilians, tell me that if you have a ham radio license, you are authorized to transmit on ANY frequencies in an emergency, public safety included. When I went for my ham ticket back in 1996, that's not the way I read the rules. The way I read them is that in an emergency, I may use any HAM frequencies, but only during that emergency and related to that emergency. If there was an emergency and one of my radios could transmit out of band, I wouldn't dare call over public safety. I would use a cell phone and if that didn't work, I would use my brain to devise a plan to rectify the situation. I've heard of people using public safety frequencies on an out of band radio in a real valid emergency and getting in trouble for it. If you do happen to do that, it had better be that you are using actual public safety radios and the staff in possession of them are down and out and you are rescuing them by using their radios to call for help.
After I posted this, I noticed the same thing - repeaters going up everywhere. Its a good thing though and I really appreciate the hard work of those that are doing so. I actually just ordered my radio for the house just before I hopped on here. The antenna and coax is up and ready to go. Thats a really nice way of keeping track of the repeaters. I sort of did the same thing using google maps documents. I have a ways to go as far as working on it. Been pretty busy lately.
I have that exact same radio and it transmits 136-174 and 400-480. I have used it briefly on GMRS to test something and it got out fine. As far as the receive is concerned, well, that leaves a lot to be desired. Seems as though unless you have an ultra powerful signal coming from the tower, the squelch doesn't want to open up. You must have something set wrong.
What's a good NMO mount GMRS antenna?
WRQI583 replied to WRPCinci's question in Technical Discussion
A quarter wave will work good in the city areas or for close range. If you go out into the rurals and especially if you have hills or mountains and your repeater is a good distance away, that NMO 72 will just about cut it. I am actually running a Tram 1181 that is basically the same as the NMO 72 and is good on the SWR across 2 meters, MURS, 70cm, and GMRS. I live in the rurals of Maine and from what I noticed, at least on the receive, that antenna just about does the job. A larger antenna that I know will work better is a Larsen NMO450C. I used to work for a Medical transportation company in CT that covered most of the eastern side of the state. The Larsens did much better than a 1/4 wave. Its all about what distance you are looking for. -
Help needed with setting up my GMRS radio, please?
WRQI583 replied to WROZ317's question in Technical Discussion
If ever you wanted to go with another antenna, possibly a little larger, such as a whip antenna, if there is a bit of distance between you and another radio or repeater such as in a rural setting, from experience, you will want to go with something like a MUF4505S GMRS antenna type of antenna. I worked for a medical transportation company many years ago and while most of the vehicles had these style antennas, a few had quarter wave antennas for UHF and the quarter wave antennas performed horribly. Receive was about 1/4 of the larger antennas. The transmit range wasn't as bad but it was diminished due to the antenna size. Our coverage area was covered by moderate size hills between 300-500 feet above sea level with flatter ground surrounding them. I had a low profile antenna similar to what you are running and it worked well in more suburban or urban areas. When you get in the more rural areas, the larger antennas are better. If your coverage is going to be short or in the city, the low profiles work well. -
UV-9G, turn off secondary (B) display?
WRQI583 replied to WRPS283's question in Technical Discussion
Unfortunately, the only setting I am seeing on here that has to do with keeping it on one band is [Menu 60] where you can mute the sub-band (the one you are not listening to) and keep it focused on just the one band. I have an Ailunce HD-1 and it has a similar setting and I always keep the sub-band muted when operating it. I find for people that are non-radio (my wife ha ha) its easier to mute the sub-band and then lock the radio on the main band and it operates just like a mono-band radio. No issues at all. Hope that helps. -
Yes you are correct except for areas that have very tall hills/mountains. I have lived in areas with anything from 500 foot hills to well over 2,000 feet. I have done it on accident and I have known others (especially on Ham Repeaters) where we are transmitting on the repeater we are using with a tone, and one without a tone (which you dont tend to find much anymore for obvious reasons) a good enough distance away inadvertently gets keyed up by us while we are up at a high elevation travelling down a certain road. So, is it required? No. Using common sense will come into play in this case. If it was me, and this is only me, If I had a repeater, I would probably set a PL tone on it and set it to 141.3 which I believe is a common one I believe for those travelling? Many years ago when repeaters weren't as common as they are today, running one without a tone probably wouldn't be an issue.
GMRS is the only Paid option for general repeater use.
WRQI583 replied to WRFS771's topic in Family Radio Service (FRS)
Oh I wonder that myself. I kid you not, one day I turned the CB on 38 lower and was doing some stuff and at one point, I heard such professionalism, I thought I was listening to an HF contest. It is DEFINITELY not always like that but I have noticed a change. Personally I love hearing some of those guys (few and hard to find) that use nice microphones and it sounds like you are listening to FM broadcast. My ears are not that good to try to understand an annoying echo. -
I thought that way for a short period time and It was probably because of the ham crowd that I hung around with. When you look at any radio service out there, it's not the radio service that's the problem. It's the people involved in it. Ham radio can be the same way at times depending on the band. Sadly, I've heard stuff come over ham that made me cringe, because I have always operated it in a professional manner and always viewed it as a highly respected radio service. -
Up here in Maine there is a repeater 13 miles from me and one that is 65 miles from me. I live in an RF toilet bowl ( one of the lowest points in my area surrounded by tall hills) and I can hit the one 65 miles away, but I can't hit the one 13 miles away, all with a portable radio. UHF is more line of site with little curvature of the signal, meaning that, you can't have a lot of obstructions or you won't hit the repeater. In the same way, the repeater, the higher up it is, the farther away the signal will reach. Also note too, on this site, I have come across many repeaters that claim a large area but in reality they may only reach that long in only a few directions due to terrain. Sadly, this site only shows a big circle around each site, not an actual specific mapped out area showing dead zones also. That's where some studying of the repeater signal will come into play. I do it with ham repeaters all the time and then just make a mental note of where the dead zones are. It helps if you are having a Convo mobile. You can pause your Convo until you get out of the dead zone.
I am new to GMRS (finally), and have mobile and portable communications as of right now. Hoping to have a base set up before the end of summer. I have a UHF base antenna. I just need to get the coax and radio and get my antennas mounted permanently. I currently monitor all 8 GMRS channels on my scanner at home in addition to some Ham radio repeaters local to me and simplex calling channels. I have the same ability when I am mobile. I try to stay prepared if anyone uses them for help. I have not noticed any active repeaters except for Woodstock, Belfast, and there is one other local to the Belfast area but I cant remember what the frequency is off the top of my head. WRQI583 - GMRS N1YFA - HAM RADIO
I wouldn't say they don't care, I think its more that they don't do as much as those in other areas of the country. They definitely don't make their presence known in the community. In the county I live in, they have an EOC and there is a lot being done as far as emergency preparedness but the public doesn't hear about it or know about it. Where I used to live, hams were out in the community much more doing activities and also sharing in the emergency preparedness. Road races, bike races, walkathons, and many other events had a truck or booth or something with Ham Radio. Aside from a few events that happen up here, there really isn't much going on. I've read about hams in other states such as Texas or Florida or even the mid section of the states where Hams are heavily involved in local stuff. What I notice a lot of is, if Hams utilize the VHF and UHF bands, they are more likely actively doing local stuff. In areas where most Hams went and upgraded their license and went down to HF and sat there and never came back up, you wont find them doing local stuff because their focus in the hobby is international stuff, not local. I've actually totaled up all the hams in just my county and the amount you hear active on repeaters and simplex vs the amount you don't is drastic. I also am in an area where there are more older hams than young so that could have a lot to do with activity. That's why I am really forced to do solitary things with radio, which is fine because I love doing propagation work figuring out dead zones and distances transmitters will go. Its not totally dead because ive had a conversation or two with some real nice guys, but busy enough for the community to notice? it is pretty dead. -
I've never heard of a CERT team near me. The really sad part, most people around me have never heard of ham radio. Most people ask me what division of the state police or sheriff's department I am. Or the famous one..... what fire department. I mention ham radio and their heads spin in circles. They do have active hams with the local county EOC and they do have a very nice gentleman who is also a liason of sorts to GMRS in addition to ham radio operator but ham radio presence in my area is low enough to where people don't know what it is or does for the community. At least back in my home state I could mention ham radio and most people knew of it through the community, a relative, or a friend. Ham radio was also included in most outdoor events where communication was needed. So I think location and how active the hams are in the community make a world of difference. Also, what bands they are active on. Hams are noticed more when they have vehicles with antennas and carry radios on their sides vs. Those that sit home and only operate HF. If you are visible to the public, then the public knows you and what you're about. -
Well I have to say, I don't bash any service of radio. Ham radio as a whole has a lot to offer. Its some of the people that are into it that make issues, or in some cases, dont exist in emergency situations. When I first got licensed as a ham back in the 90's the following things really intrigued me and I tried so hard to get into them - Emergency communication, VHF/UHF radio work (all modes and different things involved), building antennas for on the go type situations, maintaining a portable station where I could be out in the middle of nowhere and still operate, Skywarn, and many other things associated with off grid/emergency type communications. In the end all I got was "are you going to upgrade your license and join us on HF?" I even got the ol chuckle from those in public safety when mentioning how ham radio had a whole emergency communications aspect to it. What am I supposed to take all that as? It doesn't seem as though anyone really cares about ham radio or its ability in disaster situations. Maybe its the area I live in. Up here in the northeast most just rely on the national guard if something hit the fan, and now where I live in Maine, most people already live prepared for an emergency (which almost never happens) so no one really seems to care about communication. They all have cell phones. I know in other parts of the country, Ham Radio is used heavily in many types of emergencies, so I may be spouting my mouth off about only my little area. Going by what I have observed with my own eyes and ears, it honestly scares me if I relied fully on Ham radio for emergency communication. How I have seen Ham radio used in other areas of the country during the slightest of emergencies vs. how its been used in areas I have lived is a big difference. The lack of enthusiasm for the emergency communication aspect in addition to many other things is what caused me to take a back seat with Ham Radio. I still keep my equipment and license just in case and I still do experimenting on my own but I leave it as "It's there in case I need it". I still like to be prepared just in case. -
This is exactly the argument I have had with many hams. I have been in the ham world since the 90's and what I have found is that the direction that is accepted most by the ham community is that you get your Tech license and then you upgrade ASAP so you can get into HF and disappear into the worldwide bands. Allegedly, if anything hit the fan, HF is how they will communicate because all those nasty icky repeaters would be down. I have heard more disgust for repeaters and specifically the VHF and UHF bands because allegedly, they only have repeater operation (even though there is a group of guys around my area that utilize simplex on 2 meters every night....hmmm). So, what happens is that most hams run, get their higher class license, hop on HF and do what they do on CB radio - contesting (basically). Calling CQ over and over and collecting contacts. Hardly what would happen in an emergency. I am not bashing this because its part of the hobby and its one of the neat things you can do. But when it comes to being prepared for an emergency, you need to delve into another part of the radio hobby. Theoretically, could ham radio be useful in an emergency? Absolutely! You have capability to communicate locally and internationally. The reality? How is anyone going to do that when they have spent most of their Ham Radio life doing POTA or SOTA or any other OTA? How are they going to do that when they haven't trained? Law enforcement of every type trains for the positions they are in at least twice a year if not more (Correct me if I am wrong). Military is constantly training. Hams? Most are unfortunately doing OTA activations. They have a training once a year for a few hours that happens and then they go back to their normal ham lives. The reality is that if cell service went down, panic will ensue. People, if they are prepared will run and grab a radio. What radio will that be? Not Ham. It will be a GMRS/FRS type radio. If the majority of people will be there, why stick only with Ham Radio where only a select group of people will be? I've seen some scary situations where ham radio failed and it could have costed lives. My take on it is to be prepared with your local bands and if you can have a Ham and GMRS license, do so. But I would imagine, to help your locals, GMRS/FRS will be where you need to be. -
Show me any legal GMRS radios,there are none.
I've posted this before on other sites but when it comes to emergency communications and being notified, I trust my cell phone above any radio I have. A summer or two ago I was sitting in my back yard with my wife and a bad storm was approaching from the northwest and west and as it came towards me, it spawned 2 tornadoes just south of me. All I saw was a normal summer storm, but my cell phone emergency alert went off warning me to take cover because tornadoes had touched down and were spotted. Confused, I turned on my Ham Radio and tuned to the local repeater that carries Skywarn and heard nothing. I checked the DMR network and tuned into several talk groups including Skywarn, Again, Nothing! I continued to monitor all of them and................ you guessed it...........NOTHING. This is a common occurrence. Simply put, Cell phones are probably what they want us to use to receive our emergency alerts and communicate with. Quite honestly, Ham radio goes down more often than cell phones from my experience and that's coming from someone who lives in the rurals where cell service is spotty and who should be relying on radio in an emergency. GMRS repeaters should be installed at certain cell sites as a back up seeing how you can pick up these radios a dime a dozen and throw money at the FCC and, bam. you have a license. It would help the public out. -
I know, since this post, Ham Radio now costs for the license, but Ham Radio itself is NOT cheap, unless you go with a Chinese radio and stick with repeaters. If you upgrade and get into HF you are looking at thousands of dollars just to effectively communicate and run with the big boys. Its one of many things that turn me off about HF. The big thing about Ham Radio tests for people who just want to talk is that they don't want to have to learn all that technical radio stuff. They just want to use repeaters and talk. Of course, if you live in many areas, especially like I do in the northeast, repeaters are dead so getting into Ham Radio makes no sense unless you want to jump on HF and activate OTA stations. Seems like that's all Ham Radio is now. CONTESTS. We're doomed if that's the case. If they behave like they have around me when bad weather pops up and Skywarn is supposed to be activated, You're better off tucking your head between your legs and kissing your butt goodbye. I have personally witnessed times where Ham Radio should have been used and it wasn't and it could have costed lives. Thanks to our reliable cell phone networks, people were properly warned. Ham radio is a hobby for contesting and experimenting. Its something for people who want to learn about radio and if it is left as that without the rotten politics that consume it, Its a real fun hobby because it covers just about every sort of radio communication with the exception of trunking and encryption. There is a lot to learn and many wonderful knowledgeable Hams to teach people. Emergency communication, national security, etc? It will never happen. That's what GMRS/FRS is for. More people can throw money at the FCC and get a license than can throw money at the FCC AND take a test on theory they dont care about. FRS radios can be found at any corner store and GMRS radios are found all over Ebay, Bridgecom, and many other sites. GMRS/FRS is the service that preppers and other survivalists are drawn to more. Its got your short range you want and you are able to operate repeaters if you want (licensed of course).
