WRUI365
Everything posted by WRUI365
  1. Problem is because of the way a skidsteer operates, there is only 1 mounting solution which is the roof cab of the skidsteer in which will be hard pressed for anything to survive up there with falling debris. Dozer and Hoes have different operations for which hardly anything goes over the cab. How do I know this? You work for United Rentals long enough and you learn the intricacies of the equipment you deliver and set up.
  2. Or you can just go here and look . Welcome to RT Systems, Inc. - Radio Programming Made Easy!
  3. Math plays a big part in frequencies. That's like saying you paid $15,000,000.00 for something that is only $15,000.00
  4. iIf you have one radio in your left hand hitting the transmit button, and you have 2nd radio in your right hand hoping to here the transmission from your left hand and you don't. The radios are to close and you experienced something called de-sense. The radios are to close to one another. As the song goes "you have to keep them seperated"
  5. Don't forget at least a 25watt solar panel to keep said battery charged
  6. Diamond has 2 mounts that are very useful, K400 and K412 in which the K412 has a 3 axis position adjustment and the K400 is 2. I have both and they both work good.
  7. Darn it, I'm going to miss working all next week, freezing my butt off in cold weather to fix things on job sites. "NOT!!!"
  8. And remember this one important thing. Not all radios are the same. Some like my Moto R7 will try to enhance the received signal with processing to make it clearer if need be. It all depends on the equipment you using at the time.
  9. Already have D75A, waiting for Kenwood triband mobile to come out next year.
  10. Sometimes you need a outside source to help you make decisions on what you going to do. Maybe this will help or maybe not.
  11. Amateur radio 23CM 1240mhz to 1300 mhz, it could have been a DSTAR signal which Icom has radios that do dstar in 23cm. january_2016_spectrum_wall_chart_0.pdf
  12. Does that mean I have to stop talking with myself when I have a internal conversation in my mind?
  13. Man you people don't want to know what I have at hand. ,Some mad in Malaysia, Some in Japan, and yes one made in the U.S.
  14. There is the Motorola XPR route like the XPR7580 which is 800/900 mhz analog and dmr
  15. First became one when I took a little AM radio apart when I was 12 years old and put it back together again. It has culminated into my addiction over the decades, including having to enlist in the Army, MOS being 064C and it ballooned after that. Some costing thousands. Then things took a turn around when you mix computers and radios together, oh boy!! Who would of thought? People looking at my antenna as it goes up and down sometimes as I band hop. Just the look on there faces. I'm a radio Dork and there is no cure except more more more.
  16. Actually, APRS is more then just throwing out a position report for which the BTech Pro is doing for which only other BTech Pro users can see. Though APRS is used primarily in VHF at 144.390mhz US at 1200 baud, can be used at 9600 baud UHF, and 300 Baud HF. Position reporting, weather, telemetry, messaging, and other uses like IGATE, Digipeaters relaying others beacons and messages over airwaves and thru the internet back to airwaves world wide. So people might be getting confused about the terms and what can be done with it. APRS in Amateur radio is just another form of packet radio that is used in the spectrum area of VHF that can be used for AX.25 packet protocol. Position reporting is one thing, heck my Harris XG100P can give and receive position reports from other Harris users on P25 protocol which is called SA"situation awareness" just by keying up mic button. That is just postion reporting, not APRS. So people have to realize that there are huge differences with certain gear and should not confuse the terms.
  17. Also most if not all Alternators on current vehicles, there voltage output is controlled by the pcm, not by how fast the rpm is going. If you hook up a diagnostic tool and look at the voltage a alternator is putting out. You would think something is wrong.
  18. whatever you do, don't use the muffler bearings from China
  19. Check out the diamond K412 series mounts, nmo, uhf. Diamond® Antenna ~ K412S Trunk Lip Mount (diamondantenna.net)
  20. Don't even get into the QRP side of HF, depending on atmospheric conditions, you could reach out quite a distance.
  21. People going to start calling me a smarty pants smartass. I aced this thing, I got nothing right and still got my license. Now to take over the world with a penny and a pen.
  22. The radio in question doesn't have the circuitry in it to drive the ATAS120 motor to tune it, so the answer is a big no.
  23. I have 2 Motorola's that I use for GMRS and HAM 70cm myself, they are the XPR7550E and XPR5550E. Handheld and mobile which both also do dmr along with analog. Just a thought if you go that route. Also have a Harris XG100pP which covers vhf/uhf and scan the 700/800 bands along with vhf/uhf trunk frequencies.
