WRUI365
Everything posted by WRUI365
  1. BTech Pro only sends a position report with your call sign, no messages. It is more like a MDC function then APRS. I'm also a APRS user going all the way back to my first which was a Kenwood TH-D7A(G) along with a TM-D700A
  2. W6XRL is a legimate callsign, someone might have mistakenly put a 4 in and yes it is in aprs.fi/w6xrl
  3. Got home and tweaked my codeplug for the incoming radio to load up on also.
  4. Can't use encryption on amateur frequencies.
  5. I'm planning on getting the D75A. Does do DSTAR on both vfos simultaneously, and the only one that can do it 220.
  6. Actually, check out the Toro Dingo, and yes you can get a dozer blade for it also. TORO® DINGO™ COMPACT UTILITY LOADERS Now I see it's a old post
  7. "Clowns to the left of me, jokers to the right, here I am stuck in the middle with you" Could not pass that up, a little Steelers Wheel
  8. I'm both, so I get to argue with myself. That would be fun to watch!
  9. I'm a ham also, use more then one radio when in the car. Also have FTM400XDR, FT5D, Kenwood THD74A, Raddioddity DB20, Anytone 878UVII+. and a SDRPlay R1A . Always have options
  10. Make sure Radio Certification Type is set to none in the cps. I learn unless it is a certain type of battery, the radio goes into a hissy fit if it is set to UL
  11. I bought my battery PMNN4493A 3000mAh 22.2 Wh for my XPR7550E from North Georgia Communications. Might want to check them out.
  12. My First was a Radioddity GM30, my current one is a Motorla XPR7550E
