bd348
Everything posted by bd348
Here in suburbia, we have a dedicated weather radio, which can supposedly customize the alerts to only trigger if they're for our own area. We hardly use it, though, because once the storms approach we get a new alarm every minute or so. Thunderstorm warning for each cell coming through, flood warnings, hail warnings, tornado watches, wind advisories, marine warnings, etc. For all over the suburban area including stuff far away from us. They issue warnings for five counties at a time, for example, so we hear them all even though we told it to limit to our own area. The area radar map and the local tornado sirens can both be useful, though.
Use a handheld connected to a base antenna in the 2nd story window. 5W gets to the 20 mile repeater just fine. Once I tried the low power setting, which is 1/2W. It still got through but they said it was a bit scratchy.
This may work to mount a non-ground plane antenna onto the root with a mag mount, assuming you can find a flat spot 4" across. Remove for travel. TAF DISC3.5 They have other sizes for mag mount and also through mount. You could use one of the larger ones for a ground plane if you are willing to drill a hole.
Well mine doesn't look so impressive from a distance. It's only when you get close and look underneath that you see the armor bits and sway bar disconnects and LT-E tires, etc. My kid thinks I should get a decal for the hood: "Curbicon". So you can go to the mall with CONfidence! (Que up the "Honest Jeep Commercial". Look it up.)
Seeking suggestions for first base/home station setup in a city
bd348 replied to WRZI798's question in Technical Discussion
Try a base antenna near a window, with a short coax to the radio. Use a setup where you can shift the base antenna's position a few inches this way or that, because in an urban environment with multi-path bouncing signals a few inches left or right can make a huge difference. Mine is mounted to a microphone stand. Once you find a good spot, keep it there. If using a hand held radio, you can run an 18 inch piece of thin coax from the radio to the thick stuff. This provides strain relief for the radio's antenna port, and lets you move it around a little. You can order some with the correct connectors on each end. Add a speaker microphone and you don't have to touch the radio. -
Jeep JT pickup, Sport model, stock height, 32" LT-E all-terrain tires, various control arm and shock skids, aluminum engine and transfer case skids, hitch skid, bed skids, the wider Mopar HD rock rails with step assist, Apex Autolynx sway bar disconnects, Bilstein 5100 shocks, Timbren SES rear bump stops due to bed cap and towing hitch weight, Timbren offroad front bump stops (not yet installed), bed cap, Midland 275 GMRS behind the dash under the steering wheel, 1/4 wave mag mount on the hood on a sticky plate, upgraded coax, Garmin Inreach Mini 2. We tow a hard-sided popup and get decent fuel mileage as we cross the country from the midwest to get anywhere interesting. Did some Ouray and Moab, plus a bit of VA out east. With the engine/transfer case skids sticking down a bit, and no lift, it can scrape a little on two track. On the other hand, it's awesome for carving up twisty mountain roads. Like many others here, I have to get my family to and from some pretty distant places, so I can't take "might break something" risks. But a single trip blew the stock front shocks, and the skids got some scrapes, so I'm not totally babying it either. I used the InReach a few times just to update the family while they're back home or in camp. I used GMRS once while they were in the trailer a few miles away with a mountain ridge between us. Made a thread here about how the signal was probably going along the valley, bouncing off the mountain at the end, then up the next valley to the trailer. I had the 1/4 wave on the Jeep, the family had a half wave on the handheld in the trailer. Heard some groups on GMRS while on the trails out west. Heard some locals in various areas during cross-country travel. GMRS is out there in rural America, usually being used w/o call signs.
I get clear reports into a repeater 30 miles away with a 5W handheld and a base antenna near the second story window. In fact it still gets in, with static, with one half of a single Watt, as well. You may not have to bother with the attic. You can run serious coax to the base antenna, then a little thin stub the last 18 inches or so, to make it much easier to keep the handheld upright. And consider a plug-in speaker microphone.
Bonus points if you ID afterwards. "This accident brought to you by WABC123."
How to attract more young people into the Amateur Radio Hobby
bd348 replied to WRUE951's topic in General Discussion
I blame surface mount electronics and cheap products from over seas. (Halfway joking, here.) Used to be that electronics were these neat parts with through-hole leads which you would wire up with solder or wire wrap and you got a cool product as a result. Like a crystal diode radio or a light sensor. Starting around age 8-10 with the old Radio Shack electronics kits with spring connectors. Now it's tiny black specks of plastic melted onto a PC board, and there is probably a better $20 product already available on the shelf. Now days, fortunately, there are Arduino or R-Pi with soldered or wire wrap I/O, so there is still some hope. And it gets programming into the mix too. (I also find it hard to interest people in learning manual transmission these days. Sigh.) -
Once you get to Chicago-land there will be plenty to listen to. Check the repeater map.
Mobile Antenna - Length, Gain, Range Questions
bd348 replied to WRWF513's question in Technical Discussion
You could also get an adhesive metal disc and put a small mag mount further onto the hood. Looking at the above photo with the high-lift on the hood, mine is mounted approximately half way between the antenna in the photo and the end of the high lift jack. I.e. about an inch or two forward of the back edge of the hood, and in line with the edge of the plastic cowl piece. This gives several inches of metal forward, left, and right, and I ran a grounded wire towards the wind shield for the backward direction, similar to a radial. That wire may or may not make much of a difference. Anyhow, a quarter wave mag mount on the adhesive disc works pretty well there, and it doesn't stick up too much to be annoying in the field of vision, it doesn't get knocked off by trees, and a quarter wave works pretty well in mountains with varying elevations. To reach your distant repeater you probably want something with more gain. Adhesive mag mount disc: TAF DISC3.5 Larger size also available, but you need a flat surface for this, which turns out to be not so easy to find on a modern hood. -
We were at Okefenokee Swamp, GA. The state park there has camping sites out in the swamp on platforms, and a big campground on land. There is a big tower at the headquarters. I don't know if they give campers radios, but the boat guides had some. It'd be nice if the folks on the platforms could talk to the headquarters and campers on land. Years ago in the boundary waters in Minn they gave canoe campers these walkie talkies with big antennas, not to be used unless an emergency. These days they are probably given Garmin Inreach or similar.
I wish that parks and such without cell service but which already have a tower would put up a GMRS repeater for the masses. Or at least a simplex radio always on at the park headquarters.
I am using a base antenna indoors next to the window of a second story house and it reaches the local repeaters just fine. Try the stock antenna, stuck in the middle of a metal baking sheet, placed up high somewhere close to the window inside. Doesn't even have to be outdoors. It may work fine just like that. You may have to move it a few inches this way or that depending on the repeater and any multipath propagation in the area.
That thin cable is just so they can fit it into a smaller box for the retail shelf. It isn't doing Midland any favors otherwise, as it does cut the transmit and receive quite a bit through cable losses. The antenna is fine, it's the cable which is the problem. You could shorten the cable to the required length and add a connector, but the thin cable is hard to work with. By the time you get the stripping and crimping tools, you may as well have just gotten a different antenna with a better cable. I do use that antenna, but I cut the cable to one foot in length, enough to reach under the hood, and connected it to a better cable cut to about a 6 foot length to go the rest of the way into the cab to the radio. It works great. I did this because the little antenna has that little metal disc which sticks to the aluminum hood, and if not using it I can open the hood and tuck the antenna underneath the cowl. Meanwhile, the little quarter wave antenna is in theory better off road on slopes or where the other party is at a different altitude. And any antenna with a larger base would require a larger metal disc for the aluminum hood, and there isn't much straight and level metal near the edge of this hood. So the antenna is actually in the field of view about six inches from the edge of the hood, but it doesn't stick up very high, so it isn't too obnoxious. Midland might be able to sell these with eight feet of better cable, as a solution to get an antenna into a tight space. But I bet the base isn't designed for thicker cable.
My mobile is 15W and it does fine. For comparison, using a handheld with a base antenna in a second story window, I can get 30 miles to the repeater and back with a half watt, which is the low power setting on the otherwise 5W handheld. In most cases, it really is more about the antenna.
IT PAYS TO BE PREPARED WITH GMRS FOR EMERGENCIES
bd348 replied to nokones's topic in General Discussion
If routinely in areas w/o cell it starts to make sense to have a satellite SOS box. -
Looking for two-way radios to use while driving in the mountains.
bd348 replied to a topic in Guest Forum
Anything which allows an external speaker mike would be fine. It's just easier to pick up and use a microphone with a single big button and a dedicated clip on the dashboard than it is an entire radio. A more expensive speaker microphone may also sound better. It's also nice to use when connected to a base station antenna. You're just picking up the microphone instead of the radio plus antenna cable. I happen to have some Wouxun S-88G handhelds and one of their speaker microphones, but in the Jeep I use a Midland 275 which hides under the dash near the steering wheel. Only the microphone is visible outside, and I can disconnect it. It's only 15W but there is a nice antenna on the hood and it does well. If I lived in the deep woods a 50W unit might be better. -
Using a Browning clone with an HT. Second story window, in suburbia. Compared to the HT with handheld antenna, one real advantage is you can position the antenna just right. I find that moving a few inches left or right makes a big difference with multipath signals here in suburbia, so the base antenna fixed in the right position is great, using a flex cable the last two feet to the HT. In fact, using the HT with a 1/2 wave antenna is fine if you can find and hold the right position while you talk. 30 miles to the repeater, clear signal. Also while on the sidewalk the signal comes and goes every few feet, and again if I stop in the right position I can hit the repeaters. So maybe play with the exact mounting position of your antenna and see if it gets better or worse.
If using a handheld, it's nice to add a speaker mike and clip for dashboard if possible. -
The Smileys are flexible vs the stiff OEM which came with my radio.
You may be able to carry the radio upside down when not using it. Then the antenna just hangs there.
This was Tray Mountain Road, near Helen, GA. And the good stuff further north was closed...!
I was able to communicate with the family at camp over most of this road as I traveled north ( blue dot ). At this point there is quite a ridge in the way. As the miles grew to the north I was losing them, around four trail miles north of that intersection just south of the blue dot. I think I was still talking to them at that lodge, for example, despite the ridge in the way. Given the positions shown here, was the UHF signal perhaps going along the valley north-east from the blue dot, bouncing off a mountain, then going down the other valley south to the green dot? It was pretty impressive no matter what. If it matters: Midland MTX-275 15W mobile with a quarter wave on the Jeep hood, going to/from a Wouxun KG-S88G 5W handheld with a half wave in the trailer. If I keep this up I may put a better antenna on the trailer.
I hope to move the antenna to the attic some day, but for now it's a 43" or so fiberglass encased antenna. 3dbd gain, on a little stand next to the window in the same room as the radio. 30 to 35 miles to the repeater, good audio reports with 5W. For the antenna, I chose one with an N-female connector, and premade RG8 coax with N to 259 at each end, and a little 18" 259 to SMA adapter cable. I got a cheaper brand of antenna but probably should have gotten a more expensive version for better internal connections. Really, you might do just fine with a short coax to the antenna in the same room instead of going across the house to gain 5' of height. You also don't have to worry about grounding and weather and mounting. And the exact antenna placement matters. In a busy suburban area, a few inches left or right makes a big difference due to multipath. Easier to adjust if the antenna is indoors.
