Antenna with great SWR readings, does that mean it is a good antenna?
So I found an antenna that is testing great with several radios and several different bands. I realize its placement and the limitations of its size and design type are considerations but wanted to know if good SWR results are something I should be happy with? It is the size and format that I want and am getting these readings with my VR-N7500. Similar results with the UV PRO, AR-5RM and VX6R
GMRS
1.5
Marine
1.01
VHF
1.06
UHF
1.56
MURS
1.32
5 answers to this question
GMRS
1.5
Marine
1.01
VHF
1.06
UHF
1.56
MURS
1.32
Those SWR readings are good, but SWR readings alone do not make an antenna good.  Also, measuring SWR at the radio end of a lossy coax cable will always give SWR readings that are artificially low.
here are the frequencies used. It tested similarly on two different mounts, a magnet mount and a hood mount.
GMRS
462.562
1.5
Marine
156.8
1.01
VHF
443.45
1.06
UHF
146.73
1.56
MURS
151.82
1.32
How are you measuring SWR?
How sensitive is the measurement device to reflected power?
What kind of coax are you using?
How long is that coax?
What power are you testing at?
Where are you measuring the SWR?
All of those questions must be considered in order to understand what you’re actually measuring.
But again, a low SWR doesn’t mean an antenna is good for transmitting or receiving.  A good dummy load will always provide a good SWR measurement. Nor does a slightly high SWR measurement mean an antenna is bad.  A high SWR antenna with no transmission line still gets the power out.
What kind of antenna is it?
How does it work in actual real-world tests involving transmitting and receiving? Try it.
Probably, and in most cases, yes - but as @SteveShannon pointed out, there are many other factors - and, as he also mentioned, you need to try it in the real world - and you should listen to him because he is an official & licensed H.E.R.D.
In medicine, we use the term "necessary but not sufficient" to mean a finding has to be present in order to make a diagnosis, but by itself, it's not enough. I think of an acceptable SWR as necessary but not sufficient to a good antenna. (I'm not going to get into what SWR level is "acceptable"; that's a whole conversation by itself.) The antenna may have very good SWRs but it's just kinda crappy at transmitting. What you know from the SWR is that the antenna isn't likely to damage your radio, but it doesn't prove you can get a good signal out. A higher-gain antenna will typically be resonant on fewer frequencies than a low-gain or no-gain antenna. I have 3 antennas with similar SWR readings to yours (except for marine -- I haven't tested for that), but they're all about 18" high and provide essentially no gain. For my purposes, that doesn't matter because I use them for repeaters in the local area. I have a couple more that knock it out of the park in terms of range, but they're only resonant on 2-3 bands. I have a massive 10' tall GMRS-only antenna that could probably talk to Easter Island, but it's useless outside the GMRS frequencies. You may find that your antenna is just fine for your local area but doesn't provide enough punch for the distances you want to use it for. There may be some instrument for testing that, but the easiest way to find out is to use it and see what you get.
