C7 antenna install
On 5/1/2025 at 5:30 PM, nokones said:
If the OP elects to go with a NMO mount, one thought is maybe a NMO lip-mount on the edge of the hood. I sold all my  Corvettes last year, except my racecar, so I kinda don't remember if there is a suitable edge on the rear hatch or not to mount a lip-mount.
In anycase, whatever type of mounts he uses, he needs to make sure that the mount has continuity to chassis ground.
This is exactly the problem I've been chewing on all week. I appreciate you working through it with me.
Halo is aluminum so magnets are out. Halo to hatch lip panel gap is extremely narrow making targa top interface non viable without routing. That brings me to glass mount and hood mount. There is a no drill weather stripping bypass near the body line intersection of the a pillar for the coax pass through which makes me think lip mount on the aft passenger side edge of the hood is viable. For the grounding strap I was looking at using the R/H side of the firewall to pick up continuity.
There are a few ways I was thinking of making the ghost antenna working but they modifying the car in some way, shape, or form. Being that the Z06 hood is a prohibitively expensive item they all go out of the window. One idea that I was thinking could be cool is to scarf in a ground plane with a through connection on the lower surface.
Am I missing anything? It is a little difficult thinking through modification and install without all of the parts and car present. Sunday is the day though fingers crossed it all goes smoothly and I'm ready to roll.
Check out this guys solution. He says he uses a no ground plane antenna for vhf/uhf ham. Found one similar here although it says it's a tunable CB antenna from Firestik.
 image.jpeg.d26f134e58496ffc00dfc04783ba3f3a.jpegimage.jpeg.c4770bfead136b4145f41bb055d9b495.jpeg
Then I saw this, it looks like maybe a glass mount or lip, I don't know. He's going to fast around Nurburgring to see it very well
I don't know if any of these are options you would consider but it was fun looking at what people have done. Good luck.
Seems they found a working solution for them that puts the text book junkies to shame. Funny how things work in the real world when you put the books down.
1 hour ago, WRTC928 said:
My concern would be that the flexing of the antenna would cause the composite material to crack over time. Personally, I wouldn't do it. Metal is a lot more forgiving than either fiberglass or carbon fiber.
Fiberglass is considered stronger than steel when comparing their strength-to-weight ratios, meaning fiberglass can provide similar strength while being much lighter. Carbon Fiber is even greater in strength than steel compared to to strength-to weight ratios and less in weight compared to to fiberglass.  And then consider some vehicles are now made with aluminum, which is great for strength but offers poor flexibility and impact resistance which would be a poorer choice of mounting an antenna too.
2 hours ago, BoxCar said:
$190 is awfully high for a piece of steel and an NGP antenna. I'd look into making my own with a piece of stainless epoxied in place.
I agree, but then again when you consider you’d be putting it on a car that cost about 150 grand brand new it seems like a drop in the bucket. 🤷‍♂️
It's not about strength. Steel will flex and even stretch under stress but fiberglass and carbon fiber won't; they crack instead.
you are talking about 'stencil' strenght and fiberglass and carbon fiber far exceeds that of steel.  Many studies out there,, Google it!..    Pretty much the reason they use Fiberglass to manufacture boats, which have no issues with flexing and or cracking.  Using steel would require greater thickness to achieve the same strength resulting in greater weight..   Steel works great in conditions needing high compression strength, stiffness and heat resistance.
  • -2
4 hours ago, Wheaticus said:
Looking to install midland ghost antenna on c7 z06 corvette. If anyone has any tips to get the antenna in a good spot maybe near the halo or b pillar to keep it up high please chime in.
Scrap the idea of using Midland garbage and go with a 1/4 wave NMO mount antenna and drill it in. On the inside of the car gain access to the underneath area of the fiberglass and place a piece of copper foil by using 3M spray adhesive. Make sure your NMO is in good contact with the foil. You won't even see that 1/4 wave whip.
