I  programed the BTech-50v2 radio with chirp and the offset on the radio is not staying programmed from the software when I upload it to the radio am I doing something wrong ???
10 answers to this question
Post which channels you are programming and we can then dianose the problem. You may be trying to set a simplex only channel to repeater use and theradio's firmwre is blocking you.
On 5/5/2025 at 7:42 AM, SteveShannon said:
Program the Dayton tones into channel 23 and the Tipp DTCS code into channel 26 and see if it works.
Ok thanks I will try that 👍🏻
On 5/5/2025 at 8:07 AM, tcp2525 said:
Are you saving the file after editing it? You might try saving your edited files prior to uploading to the radio.
