WRTC928 Posted May 17, 2025 Posted May 17, 2025 I bought the antenna a couple of months ago and didn't open the package until yesterday. I was surprised to find there were no ground plane radials included. Is this normal, or did I just get unlucky? It wasn't too big a deal, because I bought some 10" pieces of all-thread which should work just fine. The thread size is M5-0.8, in case you're interested. It seems to me that the radials are something which should be included. Maybe mine just slipped through that part of the assembly line. Quote
MSnow Posted May 18, 2025 Posted May 18, 2025 2 hours ago, WRTC928 said: I bought the antenna a couple of months ago and didn't open the package until yesterday. I was surprised to find there were no ground plane radials included. Is this normal, or did I just get unlucky? It wasn't too big a deal, because I bought some 10" pieces of all-thread which should work just fine. The thread size is M5-0.8, in case you're interested. It seems to me that the radials are something which should be included. Maybe mine just slipped through that part of the assembly line. Mine came with them in the bag. Maybe email them and let them know they were missing and see if they will send you new ones. WRUU653 and WRTC928 2 Quote
WRTC928 Posted May 18, 2025 Author Posted May 18, 2025 3 hours ago, Socalgmrs said: You just got a bad box. They may have fallen out ect… comet sent me replacements for my 712efc, 6nc and 9nc for free when I moved I lost the box I had them stored In. Yeah, I figured it was probably something like that. I found an easy work-around, so I guess it's okay. Quote
WRTC928 Posted May 18, 2025 Author Posted May 18, 2025 1 hour ago, MSnow said: Mine came with them in the bag. Maybe email them and let them know they were missing and see if they will send you new ones. I thought it was probably just an oversight, but I figured I'd ask if this was normal. I found an easy solution and I don't want to wait on radials. I'll probably email them anyway so I have spares. Quote
LeoG Posted May 18, 2025 Posted May 18, 2025 The originals are stainless steel. Always stinks to have delays. But... do it right, do it once. RoadApple, Raybestos and WRYZ926 3 Quote
WRYZ926 Posted May 18, 2025 Posted May 18, 2025 2 minutes ago, LeoG said: The originals are stainless steel. Always stinks to have delays. But... do it right, do it once. I agree, go with the correct radials made from stainless steel. Cheap all-thread will rust and seize in the antenna housing. RoadApple and Raybestos 2 Quote
WRUE951 Posted May 18, 2025 Posted May 18, 2025 10 hours ago, LeoG said: The originals are stainless steel. Always stinks to have delays. But... do it right, do it once. Hmmm. As cheap as they sell the Comet i'm thinking the radias are made of threaded aluminium rod or tube. Quote
LeoG Posted May 18, 2025 Posted May 18, 2025 Nope, probably cheap chynese SS. I still have a 712 in it's bag. Maybe later today or tomorrow when I'm back at the shop I'll take a look. 95% sure it's not aluminum, too heavy. Quote
WRYZ926 Posted May 18, 2025 Posted May 18, 2025 Either way, bad things can happen when dissimilar metals are put together and exposed to the environment over time. WRUE951 and RoadApple 2 Quote
WRTC928 Posted May 18, 2025 Author Posted May 18, 2025 11 hours ago, LeoG said: The originals are stainless steel. Always stinks to have delays. But... do it right, do it once. The rods I got are also stainless steel. I'm going to email Comet, but I'll use what I have until the new ones arrive. Quote
LeoG Posted May 18, 2025 Posted May 18, 2025 If you have easy access to your antenna I say go for it. In my case my antenna is only accessible by bucket truck at my house. Trying to be one and done but that didn't work because I had water infiltration on my last setup. No idea how, I waterproofed the heck out of it and when I took it down I saw no signs of water. Yet since my setup worked at 26ºF and stopped at 32ºF I can only conclude it was water and when it froze it let things be right. Quote
WRTC928 Posted May 18, 2025 Author Posted May 18, 2025 1 minute ago, LeoG said: If you have easy access to your antenna I say go for it. In my case my antenna is only accessible by bucket truck at my house. Trying to be one and done but that didn't work because I had water infiltration on my last setup. No idea how, I waterproofed the heck out of it and when I took it down I saw no signs of water. Yet since my setup worked at 26ºF and stopped at 32ºF I can only conclude it was water and when it froze it let things be right. Access is just a matter of tipping the mast up and securing it to a post with hose clamps. I just now emailed Comet about the radials. In the meantime, I'm going to stand it up and do some tests with the improvised radials. It will be easy enough to tip it back down and change them when the "correct" ones arrive. SteveShannon 1 Quote
LeoG Posted May 18, 2025 Posted May 18, 2025 Then do that. If you have a tipping mast then there is no real down side to using the temp ground plane. WRTC928 1 Quote
WRUE951 Posted May 18, 2025 Posted May 18, 2025 1 hour ago, WRYZ926 said: Either way, bad things can happen when dissimilar metals are put together and exposed to the environment over time. exactly what i was thinking Quote
WRTC928 Posted May 19, 2025 Author Posted May 19, 2025 21 hours ago, WRUE951 said: exactly what i was thinking That's true, but the Comet radials are stainless steel, and so are my temporary substitutes. Comet apparently doesn't think the stainless steel/aluminum interface is a problem. It may be a slightly different composition of stainless steel, but I doubt it's enough to cause problems before Comet sends me some. Meanwhile, I'm doing some testing and trial runs. At any rate, Comet isn't kidding when they say "pre-tuned". SWR < 1.2:1 across the entire GMRS band. Quote
WRUE951 Posted May 19, 2025 Posted May 19, 2025 2 minutes ago, WRTC928 said: That's true, but the Comet radials are stainless steel, and so are my temporary substitutes. Comet apparently doesn't think the stainless steel/aluminum interface is a problem. It may be a slightly different composition of stainless steel, but I doubt it's enough to cause problems before Comet sends me some. Meanwhile, I'm doing some testing and trial runs. At any rate, Comet isn't kidding when they say "pre-tuned". SWR < 1.2:1 across the entire GMRS band. I have never used a Comet antenna so i can't attest to their product. I have read good things though. I do find it odd they would use stainless steel radials compared to aluminum, mostly because of cost difference of material and the low cost Comet sells at. Is Comet also using a stainless steel base for the radial? if so, there wouldn't be an issue with dissimilar metals. Quote
tcp2525 Posted May 19, 2025 Posted May 19, 2025 3 minutes ago, WRUE951 said: I have never used a Comet antenna so i can't attest to their product. I have read good things though. I do find it odd they would use stainless steel radials compared to aluminum, mostly because of cost difference of material and the low cost Comet sells at. Is Comet also using a stainless steel base for the radial? if so, there wouldn't be an issue with dissimilar metals. The stainless steel radials aren't screwing into aluminum. Even if it were, it's a non-issue anyway. Nothing to worry about. Just buy the antenna, assemble, mount and enjoy for many years. Quote
WRUE951 Posted May 19, 2025 Posted May 19, 2025 21 minutes ago, tcp2525 said: The stainless steel radials aren't screwing into aluminum. Even if it were, it's a non-issue anyway. Nothing to worry about. Just buy the antenna, assemble, mount and enjoy for many years. no arguments on the quality or performance of the Comet Antenna..in fact im a bit impressed they arent taking shortcuts in material quality... Quote
LeoG Posted May 19, 2025 Posted May 19, 2025 44 minutes ago, WRTC928 said: That's true, but the Comet radials are stainless steel, and so are my temporary substitutes. Comet apparently doesn't think the stainless steel/aluminum interface is a problem. It may be a slightly different composition of stainless steel, but I doubt it's enough to cause problems before Comet sends me some. Meanwhile, I'm doing some testing and trial runs. At any rate, Comet isn't kidding when they say "pre-tuned". SWR < 1.2:1 across the entire GMRS band. Mine doesn't go over 1.02 across the whole band including the 467 repeater channels. Quote
LeoG Posted May 19, 2025 Posted May 19, 2025 4 minutes ago, WRUE951 said: no arguments on the quality or performance of the Comet Antenna..in fact im a bit impressed they arent taking shortcuts in material quality... The aluminum tube that hides the coax and mounts to their 2 struts is aluminum, so are the struts. The U bolts that secure the antenna to the mast are SS also. I assume most masts are some sort of steel but there are aluminum masts out there. So there can be some dissimilar metal issues over time between the aluminum and SS components. SS is much better over time in the weather than aluminum is. Time will tell. WRUE951 1 Quote
WRUE951 Posted May 19, 2025 Posted May 19, 2025 4 minutes ago, LeoG said: The aluminum tube that hides the coax and mounts to their 2 struts is aluminum, so are the struts. The U bolts that secure the antenna to the mast are SS also. I assume most masts are some sort of steel but there are aluminum masts out there. So there can be some dissimilar metal issues over time between the aluminum and SS components. SS is much better over time in the weather than aluminum is. Time will tell. most antennas i'm aware of use aluminum for the radials and it's mouting and use SS for the actual antenna mouting hardwae, wo what you report makes sense. Quote
WRYZ926 Posted May 19, 2025 Posted May 19, 2025 Stainless steel and aluminum won't interact as much as carbon steel and aluminum will. Though you do take the chance of galvanization anytime you mix any type of steel and aluminum. I use to hate working on vehicles with aluminum rims when previous owners/repair shops would not use anti-seize on the rims. The aluminum rims would seize to the steel if one did not rotate tires on a regular basis. HHD1, WRUE951 and SteveShannon 3 Quote
WRTC928 Posted May 19, 2025 Author Posted May 19, 2025 3 hours ago, LeoG said: Mine doesn't go over 1.02 across the whole band including the 467 repeater channels. I'll recheck it when I have the antenna stood up. I hung it a few feet off the ground for the initial test. I wanted to be sure there wasn't anything to address before I got it 40' in the air. SteveShannon 1 Quote
WRTC928 Posted May 19, 2025 Author Posted May 19, 2025 4 hours ago, tcp2525 said: The stainless steel radials aren't screwing into aluminum. TBH, I'm not sure. It has that dull sheen like aluminum, but that could just be the finish. I don't have a magnet handy, but a lot of stainless steel isn't very magnetic anyway. I think the whole "dissimilar metals" things is a bit overblown anyway. Cars and motorcycles bolt aluminum to steel all the time. If it were a part that carries a current, it might be different, but I've seen lots of aluminum wire secured to an outlet with steel screws for decades without any issue, so maybe not even then. Quote
WSHH887 Posted May 21, 2025 Posted May 21, 2025 Depending on the alloy stainless steel can be highly magnetic or not. After being burnt, literally, by Chinese stainless steel that wasn't what it said it was my first quick check was a magnet. The alloy we used in chemical piping should not have been magnetic. After that incident, the piping came from an ISO manufacturer, I specified US or European manufacturer only. All Chinese metal is mystery metal as far as I'm concerned. Raybestos 1 Quote
