WRVH403 Posted May 20 Report Posted May 20 If I select "Tone", I can get the Input tone but not the Output tone. If I select Tone, I can enter 131.8 but the output tone defaults to 67.0 hz. However, if I use T-Sql, I can set the input and output to 131.8. Which is correct? Tone or T-Sql? I am using RT Systems programmer, btw..... Jeff W Waldrop WRVH403 Quote
WRVH403 Posted May 20 Author Report Posted May 20 I found my answer. What I can't find is how to delete my post.... Jeff Quote
SteveShannon Posted May 20 Report Posted May 20 56 minutes ago, WRVH403 said: I found my answer. What I can't find is how to delete my post.... Jeff You can’t unless you’re a premium member. Don’t worry about it though. T-sql requires a tone on receive. Tone doesn’t. You can hear a repeater in T-sql IFF (IFF = if and only if) you have the correct rx tone programmed. If you use Tone you will hear everything on a frequency, regardless of if it includes a tone. WRYZ926 1 Quote
nokones Posted May 21 Report Posted May 21 The RT Systems CPS is another "Less Than Simple" programming software application just as that "Less Than Simple" programming software application called Chirp. With Kenwood proprietary CPS, at least there are only two tone/code settings, one for receive (decode) and one transmit (encode) in the CPS. With Motorola, you have to tell it CSQ for no tone/code, PL, or DPL and then select the appropriate tone/code for receive (Decode); and and I believe it is None, PL, or DPL and then select the appropriate tone/DPL for transmit (Encode). WRVH403 1 Quote
Jaay Posted May 21 Report Posted May 21 5 hours ago, nokones said: The RT Systems CPS is another "Less Than Simple" programming software application just as that "Less Than Simple" programming software application called Chirp. With Kenwood proprietary CPS, at least there are only two tone/code settings, one for receive (decode) and one transmit (encode) in the CPS. With Motorola, you have to tell it CSQ for no tone/code, PL, or DPL and then select the appropriate tone/code for receive (Decode); and and I believe it is None, PL, or DPL and then select the appropriate tone/DPL for transmit (Encode). RT Systems is SO easy to use, a Caveman can do it ! SteveShannon 1 Quote
HHD1 Posted May 21 Report Posted May 21 On 5/20/2025 at 11:05 AM, SteveShannon said: T-sql requires a tone on receive. Tone doesn’t. You can hear a repeater in T-sql IFF (IFF = if and only if) you have the correct rx tone programmed. If you use Tone you will hear everything on a frequency, regardless of if it includes a tone. Interesting. I did not know that. So if I program my HT's with T-sql, anyone on that frequency must have that same t-sql set or they won't hear us? Quote
SteveShannon Posted May 21 Report Posted May 21 46 minutes ago, HHD1 said: Interesting. I did not know that. So if I program my HT's with T-sql, anyone on that frequency must have that same t-sql set or they won't hear us? No, if you program your radio with TSQL, you won’t hear anyone else unless they are transmitting using the RX tone or code you have programmed. Anyone listening using Tone will hear your transmissions. Squelch mode only affects your own radio reception. WRUU653 and HHD1 2 Quote
HHD1 Posted May 21 Report Posted May 21 4 minutes ago, SteveShannon said: No, if you program your radio with TSQL, you won’t hear anyone else unless they are transmitting using the RX tone or code you have programmed. Anyone listening using Tone will hear your transmissions. Squelch mode only affects your own radio reception. Ok, that's what I thought. I misunderstood. Thank you. SteveShannon 1 Quote
GrouserPad Posted May 22 Report Posted May 22 Tsql is for a repeater that uses the same tones in and out Quote
HHD1 Posted May 22 Report Posted May 22 19 hours ago, HHD1 said: Anyone listening using Tone will hear your transmissions. Won't anyone listening on that frequency with no tone set, hear ? Quote
BoxCar Posted May 22 Report Posted May 22 3 hours ago, HHD1 said: So tone is TX. And tone Squelch is TX and RX? You got it! WSIL439 and HHD1 2 Quote
