The Midland MXT500 GD VirtualComDrive does not install on Windows XP when I install the programming software
The GD VirtualComDrive does not install on Windows XP when I install the programming software. Under device manager I get a yellow icon indicating an error and when I install the software, the system tried to locate the MXT500 driver but fails.
I know that this is a really old version of Windows, but the machine is used for programming old radios that require Windows XP. The serial # of the radio begins with 25.
Any help would be appreciated.
Larry
3 answers to this question
8 minutes ago, nokones said:
The MXT500 programming software requires Windows 10 or 11 OS.
You're likely right. I just put an RTSystems package for a newer Yeasu radio on my W7 machine and it did exactly the same thing as the OP's setup. All their other software has run fine under 7. After RTFM/system requirements, I realized I had to put it on a W10 machine to locate/load the driver and program the radio.
  • -1
I'm suspecting that whomever just does not make a driver for an ancient OS that was pretty much win95 minus DOS underbelly. literally no one, save maybe the embedded industry, still develops for XP
