Mrsig Posted 22 hours ago Report Posted 22 hours ago I don't need to be told about the law with the FCC please. Would 2 GRMS (RT97L)repeaters work if they where about 4 miles apart and both set on the same frequency like 462.6000 tone 100.0. We are looking to extend our coverage in the dense woods and maybe our range. Thanks for your help. Quote
0 OffRoaderX Posted 22 hours ago Report Posted 22 hours ago 42 minutes ago, Mrsig said: Would 2 GRMS (RT97L)repeaters work if they where about 4 miles apart and both set on the same frequency like 462.6000 tone 100.0. We are looking to extend our coverage in the dense woods and maybe our range. Would they "work"?: YES Would they "work" the way you want/the way you are wishing they would to extend each other's coverage?: NO AdmiralCochrane and SteveShannon 2 Quote
0 GreggInFL Posted 20 hours ago Report Posted 20 hours ago A repeater can't "repeat" to another repeater, because the output frequency from one repeater (462) won't match the input frequency (467) of the other repeater. Obviously, they need to be linked. amaff 1 Quote
0 GreggInFL Posted 20 hours ago Report Posted 20 hours ago Just now, Mrsig said: How would I link them? Sorry, I was just joking around. The FCC recently made clear that linking GMRS stations over the Internet was against the regs. Quote
0 WSJI648 Posted 20 hours ago Report Posted 20 hours ago 39 minutes ago, GreggInFL said: Sorry, I was just joking around. The FCC recently made clear that linking GMRS stations over the Internet was against the regs. And yet, there is a group near me that has almost 20 repeaters linked to the 'net...and even have a zello channel. I'm beginning to think that the FCC's doesn't really enforce anything. Quote
0 OffRoaderX Posted 19 hours ago Report Posted 19 hours ago 23 minutes ago, WSJI648 said: I'm beginning to think that the FCC's doesn't really enforce anything. Its cute that it's taken you this long to realize this fact. Davichko5650, WSAA635 and TrikeRadio 3 Quote
0 GreggInFL Posted 19 hours ago Report Posted 19 hours ago 24 minutes ago, WSJI648 said: And yet, there is a group near me that has almost 20 repeaters linked to the 'net...and even have a zello channel. I'm beginning to think that the FCC's doesn't really enforce anything. They probably respond to complaints, and they aren't getting any. Quote
0 amaff Posted 19 hours ago Report Posted 19 hours ago 1 minute ago, GreggInFL said: They probably respond to complaints, and they aren't getting any. Riiiiiiiiiiiiiiiiiiiiiiiiiiiight. TrikeRadio and OffRoaderX 1 1 Quote
0 OffRoaderX Posted 19 hours ago Report Posted 19 hours ago 14 minutes ago, GreggInFL said: They probably respond to complaints Oh sweet summer child.... GreggInFL, AdmiralCochrane and TrikeRadio 1 2 Quote
0 GreggInFL Posted 18 hours ago Report Posted 18 hours ago Okay, they eventually sometimes maybe respond, but don't count on it. Quote
0 Mrsig Posted 8 hours ago Author Report Posted 8 hours ago Can any one tell me how to link them? Quote
0 SteveShannon Posted 8 hours ago Report Posted 8 hours ago 27 minutes ago, Mrsig said: Can any one tell me how to link them? Quote
0 WRYZ926 Posted 4 hours ago Report Posted 4 hours ago I don't know if you can still download GMRS Live or not. I know the website is still up but for information only. It is basically a GMRS version of Allstar Link. GMRS Live pretty much shut everything down on their website when the FCC stated that linking GMRS repeaters was verboten. IF it was me, I would run both repeaters on a different channel if you plan on linking them. SteveShannon 1 Quote
0 SteveShannon Posted 3 hours ago Report Posted 3 hours ago 1 hour ago, Mrsig said: Thanks. But really, you have two repeaters that are only 4 miles apart in the flattest state in the union and they’re on the same frequency. They’re going to interfere with each other. Use just one and get the antenna up another 40 feet. WRTC928, WSAA635, WRXL702 and 3 others 6 Quote
0 WRYZ926 Posted 3 hours ago Report Posted 3 hours ago I have to agree with @SteveShannon on this. You would be better off with a single repeater and use a good quality commercial antenna. The trick is getting the antenna(s) up as high as you can. You should be able to get a 30-50 mile radius of coverage if you can get the antenna(s) up high enough and if the repeater is located on one of the highest points in your area. Hilly terrain and forested areas will cut down on the range if the antennas are not high enough. I did a search and could not find anywhere to even download the GMRS Live software. So that looks like a bust. The only other option is finding someone that can rewrite the Allstar Link software to work on GMRS. Another issue is if the UHF SA818 module will work well enough on GMRS frequencies. I haven't looked into that myself. Again, best is to use a good quality commercial antenna up as high as you can get it with a single repeater. SteveShannon 1 Quote
0 Mrsig Posted 3 hours ago Author Report Posted 3 hours ago They shut down. https://www.youtube.com/watch?v=VuKoknU2ewg Quote
0 SteveShannon Posted 2 hours ago Report Posted 2 hours ago 49 minutes ago, Mrsig said: They shut down. https://www.youtube.com/watch?v=VuKoknU2ewg We know, but you told us that you didn’t need to be told about the FCC rules. OffRoaderX, WRXL702, amaff and 1 other 1 1 2 Quote
0 WRYZ926 Posted 28 minutes ago Report Posted 28 minutes ago Yes GMRS Live has been shut down and also why you can't download the software anymore. If you really do not care about the FCC rules then you can always try and get an Allstar node with a UHF SA818 radio to work for GMRS. But good luck with that one since Allstar Link and Allmon3 are written specifically for use on amateur bands. You are overcomplicating things and also are going to spend more money than needed. Just go with a single repeater along with a good commercial antenna. And get the antenna up as high as you can get it. Also make sure to use quality coax to connect the repeater and antenna. SteveShannon 1 Quote
0 Mrsig Posted 18 minutes ago Author Report Posted 18 minutes ago Thanks guys. I guess I will have to work on getting my tower taller. Quote
Mrsig
20 answers to this question
