2 GRMS Repeaters on the Same Frequency.
I don't need to be told about the law with the FCC please.
Would 2 GRMS (RT97L)repeaters work if they where about 4 miles apart and both set on the same frequency like 462.6000 tone 100.0.
We are looking to extend our coverage in the dense woods and maybe our range.
Thanks for your help.
21 answers to this question
Would they "work"?: YES
Would they "work" the way you want/the way you are wishing they would to extend each other's coverage?: NO
39 minutes ago, GreggInFL said:
Sorry, I was just joking around. The FCC recently made clear that linking GMRS stations over the Internet was against the regs.
And yet, there is a group near me that has almost 20 repeaters linked to the 'net...and even have a zello channel. I'm beginning to think that the FCC's doesn't really enforce anything.
They probably respond to complaints, and they aren't getting any.
I don't know if you can still download GMRS Live or not. I know the website is still up but for information only. It is basically a GMRS version of Allstar Link.
GMRS Live pretty much shut everything down on their website when the FCC stated that linking GMRS repeaters was verboten.
IF it was me, I would run both repeaters on a different channel if you plan on linking them.
I have to agree with @SteveShannon on this. You would be better off with a single repeater and use a good quality commercial antenna. The trick is getting the antenna(s) up as high as you can. You should be able to get a 30-50 mile radius of coverage if you can get the antenna(s) up high enough and if the repeater is located on one of the highest points in your area. Hilly terrain and forested areas will cut down on the range if the antennas are not high enough.
I did a search and could not find anywhere to even download the GMRS Live software. So that looks like a bust. The only other option is finding someone that can rewrite the Allstar Link software to work on GMRS. Another issue is if the UHF SA818 module will work well enough on GMRS frequencies. I haven't looked into that myself.
Again, best is to use a good quality commercial antenna up as high as you can get it with a single repeater.
Yes GMRS Live has been shut down and also why you can't download the software anymore.
If you really do not care about the FCC rules then you can always try and get an Allstar node with a UHF SA818 radio to work for GMRS. But good luck with that one since Allstar Link and Allmon3 are written specifically for use on amateur bands.
You are overcomplicating things and also are going to spend more money than needed. Just go with a single repeater along with a good commercial antenna. And get the antenna up as high as you can get it. Also make sure to use quality coax to connect the repeater and antenna.
30 Mile LOS requires a 600 ft elevation approx.  Pretty sure that's not going to happen with him.
100' which is reasonable is still only about 12-15 miles.
