Need help contacting a repeater with a Midland 115 mobile radio
I am using a local repeater on 462.600. Works fine with my Baofeng HTs. Input and output tones are DCTS 246. I programmed the Baofengs with CHIRP. The Midland cannot be programmed. You have to use the menus on the unit. I turned on the repeater settings using the Midland menu. I can hear traffic from my HT through the repeater. I can talk from my Baofeng to the Midland just fine. But I cannot  transmit to the Baofeng from the Midland. I set the DCS Privacy number to 90 which corresponds to DCS code 246 according to the chart in the Midland manual.
I am pretty new to GMRS. Anyone know what I'm doing wrong?
Thanks,
David
16 answers to this question
Thanks,
David
Are you using a repeater channel?
39 minutes ago, OffRoaderX said:
How close is the Baofeng to the Midland when you are testing?
Very close. I also moved back about 20 feet and still nothing.
3 minutes ago, WRUQ683 said:
Yes, I am. The Midland does see it as a repeater channel because it has an 'rp' next the channel number.
Make sure you do as @OffRoaderX suggests to prevent desense.
Also, with DCS there’s both a normal and inverted codes. Make sure you use the right one. If it doesn’t have an I after the code it’s assumed N.
Finally, I recommend leaving the receive squelch tone or code unprogrammed at first. That way you hear everything.
1 hour ago, OffRoaderX said:
Get back 100 feet and try again..
I took a drive around the block. No luck. I can easily Tx from the HT to the mobile on the repeater channel but not the other way round.
I took a drive around the block. No luck. I can easily Tx from the HT to the mobile on the repeater channel but not the other way round.  I haven't touched the squelch but I'll look at that next.
I know about the normal and inverted codes. But there is no option for that on the Midland radio. I opened a help ticket with Midland but of course it will be nexr week before anyone will get back to me.
Posted (edited)
First do a, "Factory Function" (reset) on the Midland and then re-enter all the pertaining setup fields like:
Rep - select "ON," etc.
Set "TALK" - OFF
Now go to CH.Rp 17 (467.600) and listen for someone to communicate on it.
Personally, I would wait on putting the privacy tone in until I actually hear the repeater operating myself.  Then input the privacy tone 90, if that is what you need.
Edited by H8SPVMT
Include the Talk function to OFF so as NOT to "talk around the repeater"
This is at least one of your problems.
Imagine sitting next to a window air conditioner while your wife is talking to you at normal speaking voice from another room. Without the AC you would probably hear her. But with the AC, even though her voice is no quieter, the AC is making it very hard to hear her, because it's dominating your hearing.
The radio that is transmitting TO the repeater is transmitting at maybe 5 to 15w. That's a very loud window air conditioner, to follow this example. The repeater is the quiet voice in another room. Your receiving radio is sitting next to the window air conditioner, in this example. It cannot "hear" the repeater because there's a very strong signal next to it.
This is called de-sensing. The listening radio is desensitized by the overwhelming output of the nearby transmitting radio, preventing it from hearing the very distant radio (the repeater).
I drove around the block and it still would not work at that distance. The HT can talk to the Midland mobile however. So it receives just fine. But the HT is not hearing the Tx from the mobile even at distance. Midland is researching the problem with their engineers now.
Been working on this with Midland support. So far nothing has worked. They asked that I send the unit back. They want to do a firmware update. It's on its way back to them now. Turns out that I am not hitting the repeater with the Baofengs either. I assumed I was because I could talk from one Baofeng to the other. But once I got beyond 6 miles there was nothing. The repeater has a est. 50 mile range. I sent a picture of my CHIRP settings on the Baofengs to the repeater operators asking for help. Have not heard from them. So all in all, not going well, except for non-repeater traffic.
It sounds like you’re consistently making a similar mistake, maybe even exactly the same mistake.
Transmitting through a normal repeater requires that the following be correctly configured:
1A. Transmission on the correct frequency in the 467 MHz main channel list.
1B. Inclusion of the correct tone (CTCSS) or code (DTCSS) which is called the Input tone relative to the repeater.
Receiving from a repeater requires only that you are tuned to the correct frequency as listed below:
2A. Reception on the correct frequency in the 462 MHz main channel list. Note that these frequencies are almost always exactly 5.000 MHz lower than the frequencies you transmit on to the repeater. That difference is referred to as the Offset.
2B. You don’t need to have a receive tone or code in your radio in order to hear the repeater, but if you do include a tone or code it must match what the repeater outputs. If you don’t use a tone or code on the receive side you will receive everything transmitted on that same frequency.
29 minutes ago, OffRoaderX said:
Just for clarification: Not almost always, for GMRS its just plain ALWAYS .
Except for at least one GMRS repeater in Florida that changes the offset in order to avoid a conflict with maritime communications. 😁
That’s the only reason I didn’t say ALWAYS.
