ljones135 Posted July 25, 2019 Report Posted July 25, 2019 Does anyone know if this radio accepts split codes and able to store them into memory? And whether or not you can Tx as well as Rx in the MURS band? I'm thinking so, just trying to make sure before I place an order. Quote
Elkhunter521 Posted July 25, 2019 Report Posted July 25, 2019 Ljones, Hi, yes the raido is capable of split tones. They stay until you change them. No, you cannot transmit on MURS. Quote
berkinet Posted July 25, 2019 Report Posted July 25, 2019 Well, looking at the specs on this radio from BTech, it will Tx and Rx from 136 to 174 on VHF. Since MURS runs from 151.82 to 154.60, it would be covered. Note however, MURS radios must be certified (Part95-J) and this radio is only certified under Part-15. See the official FCC certification report for more information. To answer your second question, If you look at page 22 in the manual (also available on the BTech web site) it looks like Receive and Transmit CTCSS are set independently. Also note: while they proudly claim BTECH Radios are Designed in the USA. while it is not, per-se a problem, the radio is most certainly not manufactured in the USA. Also, it is very likely the term designed refers to the software/firmware and not the radio hardware. And... If you are not already familiar with miklor.com, you should check them out. I am not convinced their reviews are impartial. But, they do provide good information and are an excellent resource. They have a review of the UV-50X2 from 2017. ljones135 1 Quote
Elkhunter521 Posted July 25, 2019 Report Posted July 25, 2019 Oops, I misread the radio model number. Please disregard my previous post. Quote
ljones135 Posted July 25, 2019 Author Report Posted July 25, 2019 Hey Berkinet, Thanks for the info. Is it possible to program the UV-50X1 with more GMRS channel configurations than just 30. The manual isn't quite clear enough for me on the programming of memory slots. What I'd like to be able to do is store into memory all of the repeaters that I come cross in my travels across the country, some of which are 2 CTCSS coded. I currently have a Midland MXT400, while I like that radio, I don't want a duplicate. Quote
berkinet Posted July 25, 2019 Report Posted July 25, 2019 Hey Berkinet, Thanks for the info. Is it possible to program the UV-50X1 with more GMRS channel configurations than just 30. The manual isn't quite clear enough for me on the programming of memory slots. What I'd like to be able to do is store into memory all of the repeaters that I come cross in my travels across the country, some of which are 2 CTCSS coded. I currently have a Midland MXT400, while I like that radio, I don't want a duplicate. Sorry. That question is above my pay grade as I don't own that radio. Although, based on the GMRSV1 I would guess that there are only a specific number of channels that can be programmed for Tx & Rx. I am sure @marcspaz or someone else with hands on experience will have the answer. ljones135 1 Quote
BoxCar Posted July 25, 2019 Report Posted July 25, 2019 I have the 25X2 and you can store multiple configurations for repeaters. The problem comes with trying to keep them all straight in your mind. Naming the different configurations isn't difficult, names are easy using CHIRP and even the front panel method isn't too onerous. I just wonder how many you plan on storing. If the frequencies are for cities and areas you frequently visit there is a good possibility there may be multiple sites within the same general location. You would do best to only pick one site per area based on the amount of traffic carried by repeaters in that general area. ljones135 1 Quote
ljones135 Posted July 26, 2019 Author Report Posted July 26, 2019 Box Car, I only have about 10 to program in. If they weren't running split codes, I wouldn't bother with the UV-50X2, I'd just use my Midland MXT400. And as I have not attempted to use the repeaters in the Rocky Mountains before, I'm not sure which one I'll be able to hit. If I don't run into any trouble on the old mining roads in the mountains, I won't need any repeater. That's the true goal! LOL! Quote
WSCR658 Posted October 29 Report Posted October 29 Hello I have just purchased a BTECH UV50X2 radio. I have successfully programmed the channels I want in it. I have been unable to figure out how to have the display show my my channels and display the name at the same time. Any advice with simple instructions would be great. John WSCR658 Quote
JBRPong Posted October 30 Report Posted October 30 I have the UV-25x2, but the manual shows same for the 50x2. Sync Display Channels To sync channels on the display (simultaneously display channel name and frequency), follow these steps: 1. Press the key to enter the menu. 2. Enter 32 on your numeric keypad to come to the Sync Menu 3. Press key to select. 4. Use the and keys to select: a. AB –To sync A/B Displays b. CD – To sync C/D Displays c. AB+CD – To sync both A/B and C/D Displays 5. Press to confirm and save. 6. Press to exit the menu. SteveShannon 1 Quote
