Ian Posted September 21, 2020 Report Posted September 21, 2020 (edited) The Retevis RT76 is everything I hoped it would be, and no more. This pleases me greatly. What I wanted was a dumb-as-bricks radio I could hand to "limited users" (hereafter, "lusers") with little they could screw up but changing the channel unintentionally and turning the volume too low. As a result, I am very fond of this radio. It is … nearly perfect. Side-button 1 is limited to "alarm" and there's no scan mode I can bind instead; disabling the ability to start transmitting an alarm tone (AKA "jamming signal") with an unintended button press is possible, but it doesn't let you bind a function you want in its place -- and indeed, there is no scan function. This is the only thing separating this thing from perfection. The Retevis RT76P is… Not so pleasing. The menu doesn't function as the manual describes, the menu won't let you change wide-narrow in spite of letting you select it; hitting the "confirm" button causes the radio to say "Canceled". It has a scan function! But you still can't reprogram SK1 to scan. Until this thing gets a firmware update, it's hot garbage. Feels like a Baofeng missing a few buttons, and with worse translation in the menus. It looks like it had potential, but the potential was squandered. Still don't regret purchasing it, though; I have a spare charger and battery for my RT76 which I love. This one… I don't. Avoid. Edit: Just tried the programming software. Instead of flashing the codeplug I just created (not compatible with RT76 codeplugs, natch; this thing has nothing internally in common with the RT76, I'm sure) it unlocked the 2M amateur band and changed the CTCSS on channel 1 to 2100 Hz. This thing is in dire need of some day-1 DLC. Edit: As of February 2024, the most recent firmware for the RT76P (released quite a while ago, actually) is genuinely functional. It works with the CPS, it works with CHIRP, and the menu on the front panel works as intended. This has gone from a hard pass to a recommend for me. The one remaining pain point is that the top side-key is not programmable, and is hard locked to setting the S-code and sending an alarm tone. If anyone needs a cheap GMRS jammer, this thing here will do the deed… S-code is like some kind of poor man's trunking system. It'd be suitable for large worksites with a limited number of frequencies, but GMRS licensing is incompatible with those use-cases, so … this "feature" is still essentially useless. What I'd like to see in the next firmware revision is the option to drop both functions from SK1. This will open up SK2 for a monitor function, while still allowing you to activate both broadcast FM and weather radio modes, which are far more useful than the proprietary PTTID function. In addition, if you want a PTTID function, Retevis, may I suggest something that uses either audible or modulated-CTCSS tones to broadcast the user's callsign in fast Morse? Edited February 15, 2024 by Ian New firmware, new opinion. AdmiralCochrane 1 Quote
rdunajewski Posted September 21, 2020 Report Posted September 21, 2020 I sell them on the store but I don't have any in-hand. I'm testing the waters and shipping them from Retevis directly but was just about to place an order for some stock. Sounds like I should play around with one and provide feedback to them before placing the order! AdmiralCochrane 1 Quote
Ian Posted September 28, 2020 Author Report Posted September 28, 2020 Grab a couple to play with; let me know if you figure out how to make them work, I could have always have gotten a lemon. Quote
garbon2535 Posted October 16, 2020 Report Posted October 16, 2020 I purchased one for a friend. I am disappointed that I cant change DCS codes and CTCSS codes from the radios menu. I have the same issue with sections "canceling". I purchased the programing cable and after a lot of trail-and-error was able to program the radio the way I wanted. I have a Wouxun KG-805G that I use daily. The menus area a lot more simple and straight forward. Everything in the menus actually functions. After the price of the Retevis, shipping, and the programing cable, I'd suggest the Wouxun. It's more but not much more. jsouth 1 Quote
SUPERG900 Posted October 21, 2020 Report Posted October 21, 2020 Bought a pair of RT76P units directly from Retevis. Price was inexpensive at $36 - but the shipping charges added up. The delay time was quite long before they filled the order. Nobody has them in stock stateside. I'm very happy with the unit - 30 channels you can set up any way you like, and since it has a display - you can alpha name the channels - very handy for selecting different repeaters. It'll let you go into a "frequency mode" - where you can receive VHF/UHF frequencies. Pretty easy to use - great for a dedicated GMRS 5W handheld. My potshot guess is that this a a dual-band radio that has custom firmware specifically to limit it's TX capability to GMRS. Couldn't beat the price - $36 bucks. -gene- Quote
rdunajewski Posted October 25, 2020 Report Posted October 25, 2020 Bought a pair of RT76P units directly from Retevis. Price was inexpensive at $36 - but the shipping charges added up. The delay time was quite long before they filled the order. Nobody has them in stock stateside. I'm very happy with the unit - 30 channels you can set up any way you like, and since it has a display - you can alpha name the channels - very handy for selecting different repeaters. It'll let you go into a "frequency mode" - where you can receive VHF/UHF frequencies. Pretty easy to use - great for a dedicated GMRS 5W handheld. My potshot guess is that this a a dual-band radio that has custom firmware specifically to limit it's TX capability to GMRS. Couldn't beat the price - $36 bucks. -gene- I got a small batch of them in, but they all sold out (have one left) in only a few days. I placed a larger order so there will be a bunch more coming in. Don't have an ETA yet. Retevis wasn't even stocking them in their US warehouse yet, so I think I'm the only US dealer for the RT76P at the moment. They sell them on eBay but they're shipping out of China. Quote
bulletpoints Posted December 16, 2020 Report Posted December 16, 2020 I purchased one for a friend. I am disappointed that I cant change DCS codes and CTCSS codes from the radios menu. I have the same issue with sections "canceling". I purchased the programing cable and after a lot of trail-and-error was able to program the radio the way I wanted. I have a Wouxun KG-805G that I use daily. The menus area a lot more simple and straight forward. Everything in the menus actually functions. After the price of the Retevis, shipping, and the programing cable, I'd suggest the Wouxun. It's more but not much more.I change the DCS and CTCSS codes all the time from the front screen on my 76P. Extreme 1 Quote
bulletpoints Posted December 16, 2020 Report Posted December 16, 2020 Here is my review of the 76P. Ergonomically I slightly prefer it over my other radios. It definitely has potential. The problem is the software. It is supposed to be easily programmable through their software and cable. It is not! The password-less software is password protected. Even Retevis customer service does not have the password. I have gone back and forth with CS and they do respond in a timely fashion, but they gave me several passwords to try and they do not work. All I want to do is program channel names into the radio so it is easier for my family to change frequencies. The channel number is tiny and in a corner and hard to see. The GMRS V-1 is light years ahead in programming. The radio itself is good. ajk170 1 Quote
ajk170 Posted December 16, 2020 Report Posted December 16, 2020 @bulletpoints - since I'm brand new to the world of GMRS I am not sure if updating radios out of the box is noraml like it is with digital computer equipment. I am hoping to learn if you had to update the firmware when you first purchased your RT76Ps? On mine, I cannot change the CTCSS codes or get the NOAA stations. So now I am trying to figure out how to to get the NOAA and the Retevis C/S is telling me that I have to update the firmware. Once I do so, I am told I will be able to change the CTCSS codes and receive the NOAA stations. However, Retevis tells me that the firmware is not support by iOS and I have no PCs to conduct the update with so I maybe SOL. I just purchased these from Amazon so maybe it's old stock? But I agree the Customer Support is really responsive and they said they sent out a firmware cable in order to make the update. Quote
scorpion1200 Posted January 21, 2021 Report Posted January 21, 2021 Retevis RT76p, now you can get the firmware from the website. I emailed them and got a response from “Lucy” the download was not working. From the keypad you can now change the tones. I didn’t check the weather stations; I currently use that button for the scan. You still can’t change the bandwidth and power level from the keypad. I used the software for that and customize my unit. It works like a champ. I’m very happy now. Especially the price. Quote
SUPERG900 Posted January 22, 2021 Report Posted January 22, 2021 Retevis RT76p, now you can get the firmware from the website. I emailed them and got a response from “Lucy” the download was not working. From the keypad you can now change the tones. I didn’t check the weather stations; I currently use that button for the scan. You still can’t change the bandwidth and power level from the keypad. I used the software for that and customize my unit. It works like a champ. I’m very happy now. Especially the price. They're trying to keep the radio part95 E legitimate. If they would let you mess with the bandwidth and/or power level from the keypad - they'd have to add enough smarts to the radio's firmware to properly follow the GMRS/FRS bandwidth and power levels rules depending on the frequency. (It's probably doable - but not likely worth the OEM's time. GMRS is a small market, afterall.) It's way easier to process GMRS rules logic in the CPS software. Basically - everything that would break GMRS rules has been disabled in these radios. That's ok. For those who would like more flexibility in their radios - the simple solution is to upgrade to an amateur license. Quote
Extreme Posted February 2, 2021 Report Posted February 2, 2021 Retevis RT76p, now you can get the firmware from the website. I emailed them and got a response from “Lucy” the download was not working. From the keypad you can now change the tones. I didn’t check the weather stations; I currently use that button for the scan. You still can’t change the bandwidth and power level from the keypad. I used the software for that and customize my unit. It works like a champ. I’m very happy noiWhich software and cable did you use? I got a butt-kickin' with Chirp trying to get it to connect "radio not responding". Fiddled with it to get it programmed but didn't see many of the options you list. Quote
WRCY896 Posted February 27, 2021 Report Posted February 27, 2021 I ordered a RT76P today. I also inquired into the 20 watt mobile radio which they show for sale but has yet to receive FCC certification. Will see how this goes when I get it. I am also interested in the 97 repeater. I have two GMRS V1 radios which I use on a regular basis as well as a couple Cobra FRS radios and a couple Cobra GMRS handhelds which are several years old. Will see how it goes. Quote
csinbow Posted February 27, 2021 Report Posted February 27, 2021 anyone know how to help revive a bricked rt76p? many thanks to Rich @ mygmrs.com for the solution to my problem. He generously replaced it. regarding the radio... does ok. a new antenna helps but leaves the post vulnerable. you need a deep well sma male or fill in the gap with rubber washers. replace the antenna by removing the set screw on the base. Quote
WRCY896 Posted March 13, 2021 Report Posted March 13, 2021 I received my radio today. I am able to change the tones through the menu in the radio. I do not have a cable to program for channel names. So far, I have found I can change the bandwidth but it does not stay after I exit that menu. I have only has the radio for a couple hours, so there will be plenty of time to get used to it. I did eliminate the voice and beep as well. Controls are similar to my Btech GMRS V1 Quote
Extreme Posted March 14, 2021 Report Posted March 14, 2021 https://forums.mygmrs.com/topic/2305-retevis-rt76p-programming/page-2 Download the older version of the software in post #35 in the link above and you should be able to change and keep bandwidth settings. Quote
Extreme Posted March 14, 2021 Report Posted March 14, 2021 Download old Retevis v1.45 software in Post #35 of this link. That's what I had to do to get the W/N bandwidth to hold the settings. Can't remember but it might solve other settings issues as well. https://forums.mygmrs.com/topic/2305-retevis-rt76p-programming/page-2 Quote
WRCY896 Posted March 14, 2021 Report Posted March 14, 2021 One thing I noticed as well, is that the radio does not like to receive on the mid channels. I have messed with the squelch, tested with my GMRS V1 and my Cobra FRS radios as well. I can transmit, but not receive. I can use the 462 channels as well as the repeater channels and hit all loud and clear and Receive loud and clear. Not sure what it is with 8 to 14. Quote
Extreme Posted March 14, 2021 Report Posted March 14, 2021 Are your CTCSS codes matched up between radios (TX/RX)? I just tried my 76 with an 805G on Ch. 9 and it worked fine both directions. One thing I noticed as well, is that the radio does not like to receive on the mid channels.I have messed with the squelch, tested with my GMRS V1 and my Cobra FRS radios as well. I can transmit, but not receive. I can use the 462 channels as well as the repeater channels and hit all loud and clear and Receive loud and clear.Not sure what it is with 8 to 14. Quote
WRCY896 Posted March 14, 2021 Report Posted March 14, 2021 Yes. I have double and triple checked. Sometimes it will open up after a couple seconds, but most of the time will not open up at all. It's like there isn't enough power going into the radio to open the tone. (My description of what it seems like, may not be an appropriate term). I might try a no tone receive and see what happens. Quote
Extreme Posted March 14, 2021 Report Posted March 14, 2021 Since there's sparse usage of GMRS in my area, I run w/o any PL tones, except repeaters, of course.Yes. I have double and triple checked. Sometimes it will open up after a couple seconds, but most of the time will not open up at all.It's like there isn't enough power going into the radio to open the tone. (My description of what it seems like, may not be an appropriate term). I might try a no tone receive and see what happens. Quote
WRCY896 Posted March 14, 2021 Report Posted March 14, 2021 I could probably do the same. I have a local channel which has the same tones as the repeater. And I use the 467 channels for talking around my property with my kids. We use the 462 channels and repeater channels when in the hills. Quote
WRCY896 Posted March 15, 2021 Report Posted March 15, 2021 So I messed around some more. I went to channel 9 instead of using 8 and it works wonderfully. I must have hit a menu selection which I keep skipping over for channel 8. All the channels I use work fine now. (After switching over to 9 from 8) Quote
