Danny Posted October 30, 2020 Author Report Posted October 30, 2020 Yes, FSJ4-50B 25 feet. PNMNM . Its about the same thickness of LMR400 and its fairly flexible compared to the LDF4 heliax, which is basically like wrestling with an anaconda... Attached is a picture of LMR400, left most, FSJ4-50B heliax, center, and LDF4-50A heliax (mini anaconda) G. EDIT: What length do you need? Probably 75' or even 100' to be on the safe side Quote
gman1971 Posted October 30, 2020 Report Posted October 30, 2020 Well, 75' to 100' is a large difference, remember that crimping heliax is not easy without the right tools... I know this b/c I botched it before... with the tool is a lot easier. Use a string to find out the exact length, then find the next cable in size. For a 100' run I think its probably better to ask here, pretty certain others can sell you a 100' FSJ4-50B with crimped N connectors on both ends, and even a sweep of such cable. G. AdmiralCochrane and kidphc 2 Quote
gortex2 Posted November 2, 2020 Report Posted November 2, 2020 If your going for 100' Id probably move to the LDF and not the FSJ. gman1971 1 Quote
Danny Posted November 2, 2020 Author Report Posted November 2, 2020 Looking closer 75' would meet the needs. I'll keep looking for FSJ4 cable on Ebay. I'm not finding much right now but I'll keep looking. Quote
gman1971 Posted November 2, 2020 Report Posted November 2, 2020 What he said, for a 100 foot run its certainly worth considering LDF (aka. Anaconda coaxial) If your going for 100' Id probably move to the LDF and not the FSJ. Quote
JohnE Posted November 2, 2020 Report Posted November 2, 2020 https://forums.mygmrs.com/topic/252-cable-types-and-losses/?p=2165 Quote
gman1971 Posted November 3, 2020 Report Posted November 3, 2020 I was prey to the cable loss BS scam, apparently the low loss cable myth seems to be targeted towards beginners just to sell them low performance LMR400, misleading them into believing that a .3 dB loss is going to render your radio useless. Not so. FYI, I currently have a 2.3 dB insertion loss between my preselector and the 3 TX/RX bandpass cavities combined on my house base setup, even with a 2.3 dB I can easily reach 20 miles on 25W base to mobile... again, don't fall for the cable loss BS. A 1 dB loss is not going to hurt anything. Go with Heliax, and not b/c of the lower loss, but for the lower noise, which means better signal to noise ratio, since with LMR400 chances are the noise floor will increase by a few dB, which will certainly hurt things a lot more than losing a 0.3 dB of your signal. Again, don't use UHF chrome connectors, use N trimetal. Impedance mismatch and PIM will also ruin your range too... and will be an absolute witch hunt to find them. G. https://forums.mygmrs.com/topic/252-cable-types-and-losses/?p=2165 JohnE and berkinet 2 Quote
Danny Posted November 9, 2020 Author Report Posted November 9, 2020 Thanks all for this information. I will keep searching on Ebay until I find a cable that appears. Quote
1URFE57 Posted November 9, 2020 Report Posted November 9, 2020 Bough all my radio and cable needs from them...DX Engineering and HRO-Ham Radio Outlet. AdmiralCochrane 1 Quote
BobTeague Posted February 13 Report Posted February 13 Whats the best way to ruan a coax cable in a jeep when the antenna is attached to the front pillar? i currently have it spooled up in the side of the dash. Quote
OffRoaderX Posted February 14 Report Posted February 14 53 minutes ago, BobTeague said: Whats the best way to ruan a coax cable in a jeep when the antenna is attached to the front pillar? Depends on what model and year it is. AdmiralCochrane and SteveShannon 2 Quote
