Lscott Posted January 6, 2021 Report Posted January 6, 2021 I scored a rather rare Kenwood NX-340U-K2 radio version. It does both analog/NXDN and covers the frequency range of 400 MHz to 470 MHz, perfect for the Ham 70cm band. https://comms.kenwood.com/common/pdf/download/nx240_340_K.pdf I'm looking for a tutorial on programming this radio, or NXDN in general. I already have all of the operator and service manuals for the radio. In addition I have the technical doc's from the NXDN standards forum too. I registered for a NXDN ID at the same place I have my DMR ID. Just need to figure out what exactly all of the NXDN specific settings do. The help file for the software, KPG-169D V3.03, is rather brief. The license key I have for the software allows me to do both wide and narrow band FM on the analog channels. Quote
Radioguy7268 Posted January 9, 2021 Report Posted January 9, 2021 Kenwood's dealer site has a pretty good set of training videos under "Kenwood University", but if you're not able to access that, I'm not aware of any other training type videos. Even the official training videos are more of a high level overview, rather than drilling into specifics of particular setups. I've always been a Learn by Doing type of person - but it does help me get up to speed quicker when I've got a working template to go off of. Perhaps someone with NXDN experience could share a working codeplug for one of their systems as an example? Quote
Lscott Posted January 9, 2021 Author Report Posted January 9, 2021 This is the closest one to me. https://www.repeaterbook.com/repeaters/details.php?state_id=26&ID=390 Quote
WQQQ874 Posted February 28, 2021 Report Posted February 28, 2021 I own a NXDN 2 meter repeater in Newton Massachusetts and I’m involved in a few others in New England. Quote
Lscott Posted February 28, 2021 Author Report Posted February 28, 2021 I own a NXDN 2 meter repeater in Newton Massachusetts and I’m involved in a few others in New England.Cool. I’m looking for a basic write-up or how-to for programming a basic NXDN radio. The one in particular is a Kenwood NX-340U-K2. I got the radio very cheap since it turned out to be both read and write password protected. No way to reset back to factory defaults that I could find after a couple of weeks of intensive searching. I finally got a modified version of the programming software that allowed me to blow-by all of the password protections so I could write a blank code plug to the radio which disabled the old passwords. It works on any radio supported by that radio programming software version. I’ve downloaded all of the current NXDN tech docs, radio user manuals and service guides for it. It’s a lot of material to read through, most of which nobody cares about unless you’re writing communications software for NXDN. I’m just looking for an explanation for the typical settings the Kenwood needs, both for simplex and repeater ops.Right now I have the radio stored away until I get more info and time to play with it. I also have the DMR version of the above radio, TK-D340U. Quote
WQQQ874 Posted March 1, 2021 Report Posted March 1, 2021 Well programming a nxdn radio is fairly straightforward. The things you need to do program your ran (nxdn version of NAC) and talkgroups into the radio. One of the big things that kenwood's do is aliasing and newer icom's do that also. Aliasing is where the radio will transmit the radio alias instead of just the unit id number. If you plan on getting the radio onto the NXDN network you'll need to get a id assigned from radioid.net. As for settings for simplex and repeater ops. Just go into the NXDN setting page and program your id and talkgroups there. The NXDN network has a similar layout to DMR and P25NX systems. One useful source is http://www.nxdninfo.com/ they have a lot information on set up of radios. I own a bunch of kenwood and icom nxdn capable radios and I run a department where we maintain about a thousand radios system wide. There's really nothing scary in programming an nxdn radio. Quote
Lscott Posted March 1, 2021 Author Report Posted March 1, 2021 Thanks. I did apply and received an NXDN ID from the source you pointed out. Same place I got my DMR ID. Quote
WSEL735 Posted October 12 Report Posted October 12 I JUST set up my Kenwood NX-210G to our simple company voting reciever 4 site infrastructure....pretty straight forward but no ¿talk groups?. I would really like to understand THAT feature.??? Quote
SteveShannon Posted October 12 Report Posted October 12 4 minutes ago, WSEL735 said: I JUST set up my Kenwood NX-210G to our simple company voting reciever 4 site infrastructure....pretty straight forward but no ¿talk groups?. I would really like to understand THAT feature.??? Do you mean you want to understand what a talk group is? A talk group is simply an ID number. It can be used as an individual ID or used to allow people to share in a conversation as part of a group. They can be very wide or very narrow. Quote
Lscott Posted October 12 Author Report Posted October 12 7 hours ago, WSEL735 said: I JUST set up my Kenwood NX-210G to our simple company voting reciever 4 site infrastructure....pretty straight forward but no ¿talk groups?. I would really like to understand THAT feature.??? You might like a copy of this document. At times the Kenwood help file isn’t detailed enough. NX-200_210_300_410_411_700_800_900_901 Function Reference.pdf Quote
Lscott Posted October 12 Author Report Posted October 12 7 hours ago, WSEL735 said: I JUST set up my Kenwood NX-210G to our simple company voting reciever 4 site infrastructure....pretty straight forward but no ¿talk groups?. I would really like to understand THAT feature.??? This is a later version of that manual. NX-200_210_300_410 Function Reference.pdf BoxCar and onemanparty 1 1 Quote
