OldRadioGuy Posted February 26, 2021 Report Posted February 26, 2021 I ran across this Wouxun Bluetooth adapter that's kind of interesting. https://powerwerx.com/wouxun-radio-bluetooth-adapter I have the Powerwerx speaker mics and they work great with my 805G's so I assume this would also be compatible. I'm thinking you could hoist an 805G up a tree or lash it to a pole with a Nagoya 771 or Smiley Superstick antenna.(If you hoist your 805 up a tree make sure you have a "pull down" rope so it doesn't get stuck.)Could make an interesting base station for camp situations.I'm not very experienced with bluetooth so don't know what the range would be. Anyhow, this could be a cool (but expensive) accessory. Vince Quote
MozartMan Posted February 26, 2021 Report Posted February 26, 2021 On 2/26/2021 at 5:24 PM, OldRadioGuy said: I'm not very experienced with bluetooth so don't know what the range would be. Vince Here is good article about Bluetooth range. https://www.scienceabc.com/innovation/what-is-the-range-of-bluetooth-and-how-can-it-be-extended.html Quote
MacJack Posted February 27, 2021 Report Posted February 27, 2021 This is very interesting OldRadioGuy. $125 cost more then the KG-805G... Bluetooth on a day can go 20-50 feet based on how good the units are. Like my Apple Ear buds II can go though walls and floors. I would like to hear from someone who has this and how well it works. I interest if at $70. I did save the link in my Christmas for 2021.Jack On 2/26/2021 at 5:24 PM, OldRadioGuy said: I ran across this Wouxun Bluetooth adapter that's kind of interesting. https://powerwerx.com/wouxun-radio-bluetooth-adapter I have the Powerwerx speaker mics and they work great with my 805G's so I assume this would also be compatible. I'm thinking you could hoist an 805G up a tree or lash it to a pole with a Nagoya 771 or Smiley Superstick antenna.(If you hoist your 805 up a tree make sure you have a "pull down" rope so it doesn't get stuck.)Could make an interesting base station for camp situations.I'm not very experienced with bluetooth so don't know what the range would be. Anyhow, this could be a cool (but expensive) accessory. Vince Quote
OldRadioGuy Posted February 28, 2021 Author Report Posted February 28, 2021 Yeah JackA speaker mic with a long extender cable is way cheaper :-) The problem though is that you need a more expensive radio.Then the bluetooth adapter will not seem so expensive :-) Vince Quote
Linus Posted February 28, 2021 Report Posted February 28, 2021 HYS makes a Bluetooth connector for Wouxun Radios. I have a set for the Wouxun KG-805G. They cost as much as the radio. Do not expect any support from HYS. I had to return one due to an issue with pairing. I use them for sporting applications. They are okay, but see my warning above on support -- it is non-existent. Hold onto the manual, it is not available online. Search for the following. HYS Bluetooth Headset with PTT Rechargeable Wireless Finger PTT and Ear Piece with Mic for Baofeng Kenwood 2Pin Connector Suitable for Cycling and Outdoor Sports Quote
