so went and got 75ft of #6 bare copper wire to finish grounding my antenna mast and i went and took a look at the home meter and grounding rod and baaammm its not there....i tried todo this inline and im forum dumb or something....
so after seeing this im not sure what todo... (3 dots indicating more discussion, hell yea got to use it properly, thanks whoever that was)
here is the way the coax comes out of my room into a Nagoya h-20 arrestor, the ground strap is 1 inch braided tined copper strap. its clamped to a 1/2x8ft copper rod. 2 questions now. should i run the ground from the mast to the rod with the arrestor or run it to the conduit on the power box? i was originaly going to run the mast to station ground then station ground to house but not sure what todo anymore.
serrasalmus
https://drive.google.com/file/d/1XEUOBjhlqso4gLoduiAlwjfNxoVqpXLX/view?usp=sharing
https://drive.google.com/file/d/1CMBJSADjk6MInVXwPwdqLJNBBgd_UnaN/view?usp=sharing
6 answers to this question
