Midland Universal Hood and Trunk Lip Mount with NMO Connector - ground?
7 answers to this question
Neither. The set screws should pierce the paint and get ground on the hood.
What is the best way to tell if you've gotten a good ground?
I have one of these, and I don't think I pierced the paint.. yiopes!
Use a VOM multimeter.
35 minutes ago, WRNA884 said:
I would not use that mount and damage your paint in anyway. That'll turn into a rust spot.
That is the downside to those lip mounts.  When they work well it's because you've successfully gone through the paint into bare metal for good conductivity.
On 4/12/2021 at 10:06 PM, brasda91 said:
I am mounting this to my hood. Am I supposed to run a ground wire from the antenna or mount to the vehicle body?
@brasda91, I have this mount being used on both my 2010 Subaru and my 2016 Impala. On the Subaru, I have it mounted on the right side hood. On the Impala, I have it mounted to the right side trunk. On both applications, it has held up really great. While on the road, there is not jiggling of any kind. When I installed, I did make an effort to pierce the paint. It is torqued, but not a ridiculous amount. Just enough to break through, but not enough to stab the metal. The edges of the trunk and hood have extra soldering when being manufactured, that is why I felt comfortable using this mount.
