Riktar Posted June 26, 2024 Report Posted June 26, 2024 19 hours ago, GreggInFL said: Being new to GMRS I'm hoping to eventually collect HTs, a mobile and a base station/repeater. I have the HTs and am looking at a mobile with a mag mount antenna, which will be a lot shorter than the Comet. This is the combo I'd like to test in the attic; curious how much attenuation will occur. Yeah, my attic, like most, is too short for the Comet so it will eventually go outside. Be aware that most mag mount moble antennas use the vehicle chassis as a ground plane. If you experiment with this make sure you have some type of 'groundplane' to attach the mag mount to. A large baking pan or pizza pan should suffice. I don't recall the minimum diameter you should use but I am pretty confident a 12" pizza pan should work. Quote
dosw Posted June 26, 2024 Report Posted June 26, 2024 2 hours ago, Riktar said: Be aware that most mag mount moble antennas use the vehicle chassis as a ground plane. If you experiment with this make sure you have some type of 'groundplane' to attach the mag mount to. A large baking pan or pizza pan should suffice. I don't recall the minimum diameter you should use but I am pretty confident a 12" pizza pan should work. A 1/4 wavelength at 462MHz is a touch under 6.4 inches. Any ground plane is better than no ground plane, I imagine, but using a 14 inch pizza pan would be better. Quote
GreggInFL Posted June 26, 2024 Report Posted June 26, 2024 6 hours ago, WRQW589 said: A 1/4 wavelength at 462MHz is a touch under 6.4 inches. Any ground plane is better than no ground plane, I imagine, but using a 14 inch pizza pan would be better. Found a 16" pizza pan and a Nagoya UT-72G. Time to hit the attic (which must be 140*). Quote
Riktar Posted June 27, 2024 Report Posted June 27, 2024 3 hours ago, GreggInFL said: Found a 16" pizza pan and a Nagoya UT-72G. Time to hit the attic (which must be 140*). I went through this a few summers ago in my former residence. It was 120+ degrees and I spent almost a whole day (This place had a BIG attic) finding the best position to put my antenna. Felt like I sweated a gallon of water before the day was through. Good Luck! GreggInFL 1 Quote
WSGF688 Posted January 11 Report Posted January 11 On 6/26/2024 at 3:43 PM, GreggInFL said: Found a 16" pizza pan and a Nagoya UT-72G. Time to hit the attic (which must be 140*). I know this is an old post, but how did the Nagoya UT-72G in that attic turn out? Quote
GreggInFL Posted January 11 Report Posted January 11 15 hours ago, WSGF688 said: I know this is an old post, but how did the Nagoya UT-72G in that attic turn out? I haven't tried it yet. It's my mobile antenna and the idea of running cable with adapters for something that will eventually go back in the vehicle makes little sense. Presently looking for an antenna I can park in the attic as a permanent base antenna. Any recommendations? 5' - 6' max height. Quote
SteveShannon Posted January 11 Report Posted January 11 24 minutes ago, GreggInFL said: I haven't tried it yet. It's my mobile antenna and the idea of running cable with adapters for something that will eventually go back in the vehicle makes little sense. Presently looking for an antenna I can park in the attic as a permanent base antenna. Any recommendations? 5' - 6' max height. Comet CA-GMRS https://www.gigaparts.com/comet-ca-gmrs-base-antenna.html?utm_term=sku-zcm-ca-gmrs&gad_source=1&gbraid=0AAAAAD_py5EKZQxij1cmldY7F8FS3Vn42&gclid=Cj0KCQiAyoi8BhDvARIsAO_CDsBPolyUSP6EAjfHgLTgAmTPj__UDbKhG2y8DMvRLwgdMx9xjiUbKR8aAgAQEALw_wcB WRYZ926 and WRUU653 1 1 Quote
GreggInFL Posted January 11 Report Posted January 11 19 hours ago, SteveShannon said: Comet CA-GMRS https://www.gigaparts.com/comet-ca-gmrs-base-antenna.html?utm_term=sku-zcm-ca-gmrs&gad_source=1&gbraid=0AAAAAD_py5EKZQxij1cmldY7F8FS3Vn42&gclid=Cj0KCQiAyoi8BhDvARIsAO_CDsBPolyUSP6EAjfHgLTgAmTPj__UDbKhG2y8DMvRLwgdMx9xjiUbKR8aAgAQEALw_wcB Aha, 42". Should have known Steve would nail it. Thank you, sir! SteveShannon and WRUU653 1 1 Quote
Riktar Posted January 25 Report Posted January 25 Just to toss in what I am using, a DB404 would fit nicely in your attic. Quote
