Lscott Posted October 4, 2021 Report Posted October 4, 2021 Most Linux distro's have a VM function. If it isn't installed then you can add it. If you don't want to go that route then you can get the VirtualBox add-in for Linux here. https://www.virtualbox.org/wiki/Linux_Downloads Your next stop is to pick up a copy of Windows. An older version will likely work just fine for your needs. Look here. https://winworldpc.com/product/windows-nt-2000/final CHIRP will run on Linux. Some instructions are found here. https://chirp.danplanet.com/projects/chirp/wiki/Running_Under_Linux Good luck. Quote
wayoverthere Posted October 4, 2021 Report Posted October 4, 2021 1 hour ago, Lscott said: CHIRP will run on Linux. Some instructions are found here. https://chirp.danplanet.com/projects/chirp/wiki/Running_Under_Linux Good luck. No retevis gear here, but other than getting the comm port set, chirp has worked great for me on Linux mint with my baofeng/BTech stuff (the actual Linux version, not via wine). Have also done some limited testing with wouxun cps in wine, and seems to work fine. Quote
WyoJoe Posted October 5, 2021 Report Posted October 5, 2021 There are many different versions of Linux Mint, and there are different ways to install and run Chirp depending on the version you're using. On the older versions, you could just add the application from the Software Manager. On newer versions, you need to install it as a "Flatpak." To install it on the newer versions of Mint, you'll need to use the Software Manager to install the Flatpak application, and if it doesn't also include Flatpak-builder, you might want to install that, too. I'm not sure about the necessity of the second application, but it's installed on my Mint 20 desktop and works well for me. Lastly, you'll want to download the latest version of Chirp (in Flatpak format) from the download section at chirp.danplanet.com and install it from the command line with the following command: sudo flatpak install ~/Downloads/chirp-daily-20210930.flatpak The command assumes your download was saved in the Downloads directory within your Home directory. If not, you'll need to point the installer to the correct path. Finally, replace "chirp-daily-20210930.flatpak" with the name of the file you downloaded. Quote
WyoJoe Posted October 5, 2021 Report Posted October 5, 2021 By the way, I'm not sure which model of Retevis radio you're using, but Chirp supports many of them. As a bonus, Chirp is easier to use than many of the manufacturer's programming software. wayoverthere 1 Quote
WyoJoe Posted October 5, 2021 Report Posted October 5, 2021 2 hours ago, WyoJoe said: By the way, I'm not sure which model of Retevis radio you're using, but Chirp supports many of them. As a bonus, Chirp is easier to use than many of the manufacturer's programming software. I just noticed in another post that you have a Retevis RT-76 radio. This is a model that's supported by Chirp, so you should be able to program it with Chirp. One thing to keep in mind is that you should download from the radio, and save the downloaded file as "RT-76_original" or something similar, then save it again with a different name, and use the second file to change the programming and upload that to the radio. Quote
WSCU465 Posted June 1, 2024 Report Posted June 1, 2024 I have it running my Ubuntu Linux. Just go to the respiratory of your OS and install. There may be an apt install method. It's easy, just a few commands. Quote
dosw Posted June 1, 2024 Report Posted June 1, 2024 All my computers run Ubuntu Linux. Chirp is easy to install on Debian derivatives; Mint, Mate, vanilla Ubuntu, and so on. I've been using Chirp there for a couple of years. You can also see the list of supported devices on the Chirp website, and even download all of the Chirp source code from GitHub to read through. Quote
SteveShannon Posted June 1, 2024 Report Posted June 1, 2024 It was a three year old thread. dosw 1 Quote
