I had originally planed to use an X300NA antenna to put up a repeater AND packet services for VHF ham. Today, I finally got around to unboxing the X300 and assembled. I clamped it to a tripod mount 5' above the ground in the middle of my driveway to check how it swept with the VNA. I also have an antenna that came with the repeater, that I think is a Laird Technologies FG4603 based on the size, color and shape. The specs between the two are below:
X300 - 10' tall, 9.0db gain on UHF, 5/8 wave five element
With the above, I have 22.8W leaving the duplexer, and with the mixture of fittings and coaxial, my coax loss is 0.559db.
Using an SWR power forward calculator, and a EIRP power calculator I calculated the following:
X300: 19.1 W forward power gives 53.40dB EIRP
Laird: 21.28 W forward power gives 47.87dB EIRP
Leaving everything the same, mounting height, coax, everything, and knowing here is a 6.34' top of antenna height advantage and 5.53dB EIRP advantage for the X300 with higher SWR over the other antenna, which one would you choose and why?
tweiss3
SWR: 462.68MHz - 2.525:1, 467.62MHz - 3.125:1, 449.67MHz - 1.461:1, 438.36MHz - 1.237:1
Laird - 3.66' tall, 5.0db gain
SWR: 462.68MHz - 1.730:1, 462.30MHz - 1.698:1, 467.62MHz - 2.150:1
16 answers to this question
