Questions related to VXR-7000 CWID
briancs
My vxr-7000 is up and running seems to work great. I configured the CWID to transmit roughly every 10 minutes and it worked great for about a day. Now it only ids when Someone transmits, it can sit idle for hours with not ID. Does anyone know is this by design or is something else wrong?
Thanks in advance
Brian
3 answers to this question
I have mine programmed to ID every 15 minutes (900 seconds). If I key up the repeater, it will ID right away, and again in 15 minutes. If it isn't used after the second transmission, it won't ID again until it is keyed up by another user. Basically, it will ID every 15 minutes while it's in use (when it has been used after the last ID), but it will not ID if it hasn't been accessed since the last ID.
I thought there was a setting in the software to set it to ID continuously, or to ID when in use (as above). I didn't find anything to change that setting in the software. That doesn't mean there isn't a setting to do this, it just means that if there is, I haven't figured out yet how to change it.
