It has been awhile since I've been playing around in GMRS and I have learned a lot of things over the past few months. I believe I am finally ready to try and create a repeater of my own. My location is favorable as im on top of a hill that oversees the township so I want to give it a go. The ideal use of the repeater is to provide a method of local communication within the township. Im located near and in range of the CSRA Columbia network, but I want something small and local, plus its just a fun project to try and accomplish. I have developed a rough plan and got some equipment I have looked at and will start collecting soon based on how this thread goes.
So far I have got 2 Motorola GM300 UHF radios as they were fairly cheap and work well with the repeater interface I got for it. I plan to run theses radios at 25 Watt output. For the repeater interface I chose a Motorola HLN3333B R.I.C.K. as its just plug and play with the GM300's plus it adds the option of remotely shutting down the repeater via DTMF if I desire. I already have covered a power supply so that's good there. I want to get a duplexer andthis one offered on MyGMRS looks good but I want some opinions about it from folk who know a bit more first before committing on buying it. If there are other duplexers out there that I should consider, let me know. The antenna I have planned to get is a Tram 1486, also offered by MyGMRS as a option and i'll have this mounted straight above the set up which is inside of the shop. From floor to antenna base, about how tall should I mount the antenna? And for coax, I am leaning towards using 100ft of LMR400 coax cabling. I herd it would get the job done well and its not too expensive. So far that is everything I have on the list. I'll worry about building antenna mounts and a cabinet for the radios later.
I know i'm not making something that is perfect and i'm not trying to cover an entire county, but I want something that works well for a starter and to go from there. Im hoping to achieve about 20~ miles and I hope im making the right decisions with some of the equipment I have and plan to get. Let me know what you experts think and help guide me in the right direction.
Stripes
Hello Internet!
So far I have got 2 Motorola GM300 UHF radios as they were fairly cheap and work well with the repeater interface I got for it. I plan to run theses radios at 25 Watt output. For the repeater interface I chose a Motorola HLN3333B R.I.C.K. as its just plug and play with the GM300's plus it adds the option of remotely shutting down the repeater via DTMF if I desire. I already have covered a power supply so that's good there. I want to get a duplexer and this one offered on MyGMRS looks good but I want some opinions about it from folk who know a bit more first before committing on buying it. If there are other duplexers out there that I should consider, let me know. The antenna I have planned to get is a Tram 1486, also offered by MyGMRS as a option and i'll have this mounted straight above the set up which is inside of the shop. From floor to antenna base, about how tall should I mount the antenna? And for coax, I am leaning towards using 100ft of LMR400 coax cabling. I herd it would get the job done well and its not too expensive. So far that is everything I have on the list. I'll worry about building antenna mounts and a cabinet for the radios later.
Looking forward to learning more!
19 answers to this question
