I have a DB20-G and I programmed a series of simplex channels (14-22) with various different CTTSS/DCS code to change channel on the fly when I travel with a friend who has the same channels programmed into his radio. I gave each channel a unique name. They are in channel positions 31 to 54 and in channels 55 and 56 I programmed a couple of repeaters. Those programmed into channels 31 to 39 work as they should and anything programmed into channels of 40 and above do not transmit and I get an error tone. Now when I take a channel setup from say channel 44 and put it in channel 32 it works as it should. It appears that anything programmed in channel positions below 40 work and above 40 don't. Any idea what is the cause of the problem. I included a copy of my .dat file if you think that would help.
WROG611
BACKUP db20g .dat
12 answers to this question
