Before doing anything. DO NOT USE the sd card your node is currently running on. Get yourself a blank sd card incase there's any issues, you can just pop your original sd card back in.
Files to download:
pi4.zip nodeupdate.zip template.zip
DON'T FORGET TO PORT FORWARD to the local ip address and port number used.
First use winSCP to log into your current node that's running. Open up iax.conf to get your node password.
/etc/asterisk/iax.conf
Head over to hamvoip.org to download the newest image file.
Make sure you have Win32 Disk Imager installed. Use it to install the new image to the blank sd card.
After it's done installing don't remove the sd card yet. Open it up in file explorer and add the 2 files in pi4.zip to it.
You can now safely remove sd card and add to your Raspberry Pi 4. Let it boot up with ethernet cable installed for a few mins. Log into your router and look for the newest ip address/name. Mine was labeled as alarmpi 192.168.1.192.
Use the ip address and SSH into it with winSCP using the default credentials. There's a few things your gonna wanna change.
Download nodeupdate.zip and copy/paste the files to the correct folders.
/usr/local/etc/rc.updatenodelist
/var/lib/asterisk/rpt_extnodes_gmrs
Next download template.zip and install those files in the correct folder.
/usr/local/etc/asterisk_tpl/
You can now log in with putty and go through the node set up process. Change your hostname to node-XXXXX or whatever you'd like. Add your node number and password when prompted.
After your done with the node setup you can use the menu to change your wifi. Let your node reboot.
Use winSCP to log back into your node and navigate to extensions.conf to add your node number where it says NODE = ${NODE}. It doesn't change during the setup process.
/etc/asterisk/extensions.conf
Go into rpt.conf and look for extnodefile and change it to the following if it isn't already set.
While in winSCP hit the putty icon
When the menu pops up hit 9 to enter command line.
Change your crontab -e to run rc.updatenodelist
You should be able to connect to other nodes at this point.
Don't forget to check out the updated tone list I added in rpt.conf
Setting up Supermon
Log into your node with putty and change directory.
cd /var/www/html/supermon
Once your in that directory your gonna wanna change the admin password
htpasswd -cB .htpasswd admin
Now go to Supermon on your ip address
yournodeip/supermon
Click login on the left and login with admin and your password.
Next we're gonna wanna change some settings. Click Configuration Editor
Go to allmon.ini and hit edit file. Change it to the following info with your node# to your node, set passwd= as your password you just set up.
[node#]
host=127.0.0.1:5038
user=admin
passwd=secret
menu=yes
hideNodeURL=no
[All Nodes]
nodes=node#
menu=yes
[lsNodes]
url="/cgi-bin/lsnodes_web?node=node#"
menu=yes
[myGMRS.com]
url="http://network.mygmrs.com"
menu=yes
Don't forget to hit WRITE edits at the bottom when done.
Next go to global.inc and change all the info to your info. Callsign, Name, Location, Zip
Now go into common.inc and find the section about Allstar Allmon Database, change to the following info
// AllStar allmon database
//$ASTDB_TXT = "/var/log/asterisk/astdb.txt";
$ASTDB_TXT = "/var/lib/asterisk/rpt_extnodes_gmrs";
// AllStar rpt_extnodes file --- not present in DNS mode.
$EXTNODES = "/var/lib/asterisk/rpt_extnodes_gmrs";
// AllStar Echolink database dump
$ECHO_DB = "/tmp/echolink.db.gz";
// Private AllStar nodelist
$PRIVATENODES = "/var/lib/asterisk/rpt_extnodes_gmrs";
WRITE edits when done.
You should now see your node and all your stats.
If you wanna control your node from an external ip address make sure you port forward port 80 to your node's internal ip.
Make sure you keep up with your public ip address if you don't have a static ip. Otherwise you won't be able to connect.
I noticed when people were transmitting I would lose part of the transmission every few seconds, sometimes the whole transmission then I would hear my courtesy tone. I noticed this when I had my phone linked in with DVSwitch while monitoring my radio. I did some playing around in the simpleusb.conf setting and found that if I changed it from log to linear my audio would be fine without issues.
To change the settings log in with putty, on the main menu hit 12 for simpleusb tune menu
After your in the simpleusb menu hit 5 then number 2
When your done making changes hit W then 0. Make sure to restart asterisk when done making changes by selecting option 13 from main menu.
Thanks for the writeup. We've found it very valuable. I'd like to add that in the steps to use WinSCP to copy/place the files rc.updatenodelist and rpt_extnodes_gmrs you might not have mentioned to the users to use F9 and make them executable. Otherwise they won't do anything. When logging onto your node via SSH the default HamVOIP port is 222 and the login is root/root. Also the advice "If you wanna control your node from an external ip address make sure you port forward port 80 to your node's internal ip." won't work for in the majority of cases port 80 is blocked or leads to the router page. Either do a translation like 80 external->50000 internal or add a Listen line in /etc/httpd/conf/httpd.conf to make the web server respond on 50000. Also /etc/asterisk/manager.conf needs
[general]
displaysystemname = yes
enabled = yes
webenabled = yes
port = 5038
;bindaddr = 127.0.0.1   ; Local interface only!
bindaddr = 0.0.0.0    ; Not secure
I just didn't want people to get stuck. Thanks again
-Pres WRJL719/W2PW
A couple of other things. At the step that says "Change your crontab -e to run rc.updatenodelist", because the screenshot runs off the left edge, you can't see that there is an asterisk (shift-8) (never use the numeric keypad) at the beginning of the line. So
/5 * * * * /usr/local/etc/rc.updatenodeist should be
*/5 * * * * /usr/local/etc/rc.updatenodeist
as does the line above it for AutoSky
PS: you can make your PuTTY window look a LOT cleaner by doing the following:
In Putty,
Window...Appearance...Font... change to 18point
Translation... Remote character set make it CP437
Session...Default settings...Save
Also update any saved sessions you may have. Actually, I don't save sessions. What I do is in WinSCP I choose
Options...Preferences...Integration...Applications... and tick all 3 (versus the default middle one) and then WinSCP invokes PuTTY.
One other WinSCP tip: if you can't "see" a file that is there (example: /srv/http/supermon/.htpasswd) then click lower right to show hidden files.
You can edit files in Supermon Configuration Editor, but if it warns you about the file being read-only, go into WinSCP, go to the file such as /etc/asterisk/rpt.conf and hit F9 to change the properties of the file from 0644 to 0666
That's about it for now. 73
-Pres WRJL719/W2PW
So this works great, the only issue I am having is I am getting cron fork which stops updating things in the cron after about 12 hours.  A reboot clears it for another 12 hours or so.  I am not quite sure what may be causing this, I have several other nodes running on the ham side on allstar and dont have any issues.  Anyone know what could be the issue.  Here is some of the logs when it starts.
Oct 10 17:34:02 GMRSRepeater CROND[22904]: pam_unix(crond:session): session closed for user root
Oct 10 17:34:03 GMRSRepeater CROND[2133]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:34:03 GMRSRepeater CROND[7443]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:34:13 GMRSRepeater CROND[7443]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:34:13 GMRSRepeater CROND[2133]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:34:32 GMRSRepeater CROND[6438]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:35:01 GMRSRepeater crond[23030]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:35:01 GMRSRepeater crond[23031]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:35:01 GMRSRepeater crond[23032]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:35:01 GMRSRepeater CROND[23035]: (root) CMD (/usr/local/bin/AUTOSKY/AutoSky)
Oct 10 17:35:01 GMRSRepeater CROND[23033]: (root) CMD (/usr/local/etc/rc.updatenodelist)
Oct 10 17:35:01 GMRSRepeater CROND[23034]: (root) CMD (/usr/local/sbin/supermon/ast_var_update.sh)
Oct 10 17:35:01 GMRSRepeater CROND[23032]: (root) CMDOUT (/usr/local/bin/AUTOSKY/AutoSky: fork: retry: No child processes)
Oct 10 17:35:01 GMRSRepeater CROND[23030]: (root) CMDOUT (/usr/local/etc/rc.updatenodelist: fork: retry: No child processes)
Oct 10 17:35:01 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:02 GMRSRepeater CROND[23032]: (root) CMDOUT (/usr/local/bin/AUTOSKY/AutoSky: fork: retry: No child processes)
Oct 10 17:35:02 GMRSRepeater CROND[23030]: (root) CMDOUT (/usr/local/etc/rc.updatenodelist: fork: retry: No child processes)
Oct 10 17:35:02 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:04 GMRSRepeater CROND[23032]: (root) CMDOUT (/usr/local/bin/AUTOSKY/AutoSky: fork: retry: No child processes)
Oct 10 17:35:04 GMRSRepeater CROND[23030]: (root) CMDOUT (/usr/local/etc/rc.updatenodelist: fork: retry: No child processes)
Oct 10 17:35:04 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:08 GMRSRepeater CROND[23032]: (root) CMDOUT (/usr/local/bin/AUTOSKY/AutoSky: fork: retry: No child processes)
Oct 10 17:35:08 GMRSRepeater CROND[23030]: (root) CMDOUT (/usr/local/etc/rc.updatenodelist: fork: retry: No child processes)
Oct 10 17:35:08 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:16 GMRSRepeater CROND[23032]: (root) CMDOUT (/usr/local/bin/AUTOSKY/AutoSky: fork: Resource temporarily unavailable)
Oct 10 17:35:16 GMRSRepeater CROND[23032]: pam_unix(crond:session): session closed for user root
Oct 10 17:35:16 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:16 GMRSRepeater CROND[23031]: (root) CMDOUT (tail: cannot open '/var/log/pacman.log' for reading: No such file or directory)
Oct 10 17:35:17 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:19 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:20 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:22 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:23 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:25 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:25 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:26 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:26 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:28 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:28 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:32 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:32 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:35:35 GMRSRepeater CROND[14727]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:35:40 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:35:55 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/bin/checkupdates: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:56 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/bin/checkupdates: fork: retry: Resource temporarily unavailable)
Oct 10 17:35:58 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/bin/checkupdates: fork: retry: No child processes)
Oct 10 17:36:01 GMRSRepeater crond[23302]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:36:01 GMRSRepeater CROND[23302]: (CRON) CAN'T FORK (child_process): Resource temporarily unavailable
Oct 10 17:36:01 GMRSRepeater CROND[23302]: pam_unix(crond:session): session closed for user root
Oct 10 17:36:02 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:36:03 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:05 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:36:06 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:36:08 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:36:12 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: Resource temporarily unavailable)
Oct 10 17:36:20 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:36:20 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:21 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:23 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:27 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:35 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:36:35 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:36 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:38 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:42 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:50 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:36:50 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:51 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:53 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:36:57 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:01 GMRSRepeater crond[270]: (CRON) CAN'T FORK (do_command): Resource temporarily unavailable
Oct 10 17:37:05 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:37:05 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/weather.sh: fork: retry: No child processes)
Oct 10 17:37:06 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/weather.sh: fork: retry: No child processes)
Oct 10 17:37:08 GMRSRepeater CROND[13030]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:37:08 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/weather.sh: fork: retry: No child processes)
Oct 10 17:37:12 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/weather.sh: fork: retry: No child processes)
Oct 10 17:37:20 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/weather.sh: fork: Resource temporarily unavailable)
Oct 10 17:37:20 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:21 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:23 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:27 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:35 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:37:35 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:36 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:38 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:42 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: retry: No child processes)
Oct 10 17:37:50 GMRSRepeater CROND[23031]: (root) CMDOUT (/usr/local/sbin/supermon/ast_var_update.sh: fork: Resource temporarily unavailable)
Oct 10 17:37:51 GMRSRepeater CROND[7163]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:37:52 GMRSRepeater CROND[23031]: (root) CMDOUT (Updated Variables Node 24222)
Oct 10 17:38:01 GMRSRepeater crond[23612]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:38:01 GMRSRepeater CROND[23612]: (CRON) CAN'T FORK (child_process): Resource temporarily unavailable
Oct 10 17:38:01 GMRSRepeater CROND[23612]: pam_unix(crond:session): session closed for user root
Oct 10 17:39:01 GMRSRepeater crond[23692]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:39:01 GMRSRepeater CROND[23692]: (CRON) CAN'T FORK (child_process): Resource temporarily unavailable
Oct 10 17:39:01 GMRSRepeater CROND[23692]: pam_unix(crond:session): session closed for user root
Oct 10 17:39:05 GMRSRepeater CROND[5705]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:40:01 GMRSRepeater crond[270]: (CRON) CAN'T FORK (do_command): Resource temporarily unavailable
Oct 10 17:40:01 GMRSRepeater crond[23763]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:40:01 GMRSRepeater CROND[23763]: (CRON) CAN'T FORK (child_process): Resource temporarily unavailable
Oct 10 17:40:01 GMRSRepeater CROND[23763]: pam_unix(crond:session): session closed for user root
Oct 10 17:40:03 GMRSRepeater CROND[18984]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:40:32 GMRSRepeater CROND[22855]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:40:33 GMRSRepeater CROND[8539]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:40:43 GMRSRepeater CROND[8539]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:40:53 GMRSRepeater CROND[8539]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:01 GMRSRepeater crond[23940]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:41:01 GMRSRepeater CROND[23940]: (CRON) CAN'T FORK (child_process): Resource temporarily unavailable
Oct 10 17:41:01 GMRSRepeater CROND[23940]: pam_unix(crond:session): session closed for user root
Oct 10 17:41:03 GMRSRepeater CROND[8539]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:03 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:06 GMRSRepeater CROND[5949]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:13 GMRSRepeater CROND[22855]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:14 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:21 GMRSRepeater CROND[23098]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:24 GMRSRepeater CROND[22033]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:24 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:34 GMRSRepeater CROND[22855]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:34 GMRSRepeater CROND[22033]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:34 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:44 GMRSRepeater CROND[22855]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:44 GMRSRepeater CROND[22033]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:45 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:55 GMRSRepeater CROND[22033]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:41:55 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:01 GMRSRepeater crond[24194]: pam_unix(crond:session): session opened for user root by (uid=0)
Oct 10 17:42:01 GMRSRepeater CROND[24194]: (CRON) CAN'T FORK (child_process): Resource temporarily unavailable
Oct 10 17:42:01 GMRSRepeater CROND[24194]: pam_unix(crond:session): session closed for user root
Oct 10 17:42:05 GMRSRepeater CROND[18173]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:06 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:16 GMRSRepeater CROND[18173]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:16 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:26 GMRSRepeater CROND[22033]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:26 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:36 GMRSRepeater CROND[17060]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:37 GMRSRepeater CROND[22033]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:37 GMRSRepeater CROND[6894]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:37 GMRSRepeater CROND[18173]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:37 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:37 GMRSRepeater CROND[24474]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:47 GMRSRepeater CROND[20665]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:47 GMRSRepeater CROND[18173]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:47 GMRSRepeater CROND[10834]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:47 GMRSRepeater CROND[24474]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Oct 10 17:42:47 GMRSRepeater CROND[6894]: (root) CMDOUT (/usr/bin/grep: /tmp/rpt_extnodes-temp: No such file or directory)
Thanks for the response.  I thought this may be the case as when I looked it up I was reading this but didn't know what was causing it.  I have a rasp pi 3b and a sd card that is 32 gig if I remember right and I installed the hamvoip image and did what was said above.  So I guess I'm not sure what the fix will be or if anyone else has had this happen who has tried this way on hamvoip but I am looking for the cure.
Thanks
Thanks
A memory leak like that will eventually cause a stack overflow no matter how much memory you have.  The stackoverflow forum link I posted has some suggestions for how you can see what processes are being forked and never exit or killed.  Then you (or a programmer if you’re not) will have to figure out why those calls aren’t exiting freeing up their memory.  Things to look for are incursion (when a function calls itself), or calling cron from within a loop.  Since cron seems to be at the heart of this issue that’s what I would start with.  Cron is a scheduler.  It only needs to be called once for each scheduled task or fork. It  typically shouldn’t be called over and over with the same parameters unless you kill it before calling it.  (Which would be sloppy coding!)
So, check and see which processes are running.  If you have a whole bunch of some dig into why.
Good luck,
Steve
Thanks
Unless you are running a swap file on the SD card, its size is not really relevant. The R-Pi 3B has 1GB of RAM. Log-in and try running something like top
top - 11:40:50 up  7:40,  1 user,  load average: 0.87, 0.93, 0.92
Tasks: 122 total,   1 running, 121 sleeping,   0 stopped,   0 zombie
%Cpu(s):  3.1 us,  6.1 sy,  0.0 ni, 90.7 id,  0.0 wa,  0.0 hi,  0.1 si,  0.0 st
MiB Mem :    972.8 total,    660.6 free,    113.2 used,    198.9 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.    789.6 avail M
Note the Mem and Swap lines (this is on a running Pi-Star system). You could then look at the list of processes to see what is using memory.
Just out of curiosity, has anyone tried running this on proxmox virtual server?  I have node numbers now and am awaiting interface for vertex 7000, I have a pi4, but I also run various versions of pi on my proxmox server and was thinking to try and virtualize it.
OK, I just ran top and got this.  I dont really know much about this stuff.  I got hamvoip originally about 2 years ago and have been pretty good with it all of course there are step by step instructions which I have pretty much memorized after doing enough of it.  If you want to message me off list that is fine to.  Also I may have the pi 3B + I forget what the differences are.  image.thumb.png.26d0122002f8e3bda3bf257ddbebd6d0.png
Are you sure you haven’t changed anything in the code?
In particular look at the post immediately above your first post where WRLJ719 talks about the call to rc.updatenodelist. Also, his post appears to have a misspelling “rc.updatenodeist” rather than “rc.updatenodelist”.  Nothing makes a person more aware of spelling than programming.
It looks like cron is spawning new instances of “rc.updatenodelist” which runs and then goes to sleep, over and over and over, each time eating up valuable resources until there are none left.  I suspect either rc.updatenodelist needs to exit gracefully, rather than sleeping, or something needs to be fixed in crontab. I doubt it needs to run very frequently anyway, but it should exit each time.
That link to the stackoverflow question that I pasted above has other suggestions for diagnosis.
You probably do have the 3b+ but that shouldn’t matter.
So, look at where you were when you followed this instruction:
Change your crontab -e to run rc.updatenodelist”
and make sure you did it correctly and that you included the asterisk as pointed out by WRLJ719.
Based upon https://github.com/dl9rdz/asterisk-apprpt/blob/master/allstar/rc.updatenodelist this script, once started, loops continuously (lines 20-22)
retries=0
while [ 1 ]
do
and has a two hour sleep before rechecking things... (lines 74-104)
                if [ $retries -gt 50 ]
       	        then
               	        sleep 7200 # doze for 2 hrs to lighten network load
               	else
                       	sleep 10
		fi
		break
	fi
      else
	$RM -f /tmp/rpt_extnodes-temp
	if [ $verbose -ne 0 ]
	then
        	echo "Problem retrieving node list from $i.$TOPDOMAIN, trying another server";
		downloads=0
		retries=$((retries+1))
	fi
	if [ $verbose -eq 0 ]
	then
		then
		else
			sleep 30
		fi
	else
		sleep 5
	fi
	break
      fi
    done
 done
Based upon this -- I have to wonder why a repetitive cron job is being used? At least, one that doesn't check to see if a copy of the script is already running (and either force kills that copy before starting a new one, or just exit without starting a copy).
NOTE: the 2 hour sleep appears to be tied to the retry count. That could mean you have a network problem preventing you from retrieving the list(s). Edit the script to turn ON "verbose" and restart -- then after a while check the system log files for any messages.
20 hours ago, Sshannon said:
Nope the only changes I made were what is listed above to get things working.  I did notice the mispell when I originally put it on so that was not an issue either.
The crontab for the updatenodelist, I commented out and everything has been fine so far.  My other nodes (ham radio) have the same line but things are fine but then again they are not changed to what what I reference right above for extnodefile = /var/lib/asterisk/rpt_extnodes_gmrs in the rpt.conf file.   So I guess the updatendelist will just have to update once in a while then instead of often, not sure how to make that happen to keep things happy though.  In the crontab I had it set to run every 5 minutes (now I have it commented out)  this shows what my crontab looks like currently and so far things have been running except the nodelist isnt up to date.image.thumb.png.b3e60a7240c0f6168099ca4ea07f2087.png
2 hours ago, fpcaptain said:
That seems like the best or at least only thing to do to keep from chewing through memory.
Do any instances of rc.updatenodelist run at all? Are there any sleeping?  I think I read somewhere that a module called “dial” might call it once.
Is it possible there’s a problem in the extnodefile itself?
OK.  I can run it manually once in the bash shell if I have my computer.  I wonder if setting it to run once a day as a cron if it would still be an issue.  What I have now done to assit with not always having the computer with me but my phone and supermon, I made a Favorite command up that allows me to go to favorites and click node list update (I named it) and then execute and it updates it.  What I did was create like an A1 command in rpt.conf where the 81 time command is so I could do it via supermon or over the air if I wanted.  I also went into /etc/rc.local and made that look like this
#!/bin/bash
# rc.local file
# Starts Allstar
echo -1> /proc/sys/kernel/sched_rt_runtime_us
/usr/local/etc/rc.allstar
/usr/local/bin/AUTOSKY/AutoSky.ON
exit 0
So now when the pi reboots, it automatically loads the mygmrs node list.  Dont ask me how I figured this out, it just came to me and it works.  Thanks again for the help!
Nice.  Yes, you probably could run it once a day as a cron.  If the pi is never restarted and if rc.updatenodelist just runs and sleeps then eventually you’ll have the same problem, but it may take nearly two years!
The real question I have is if rc.updatenoelist runs to completion and breaks out of its loop or if it continues running.  If it exits eventually then it shouldn’t be gobbling up memory and you could run it as a cron more frequently.  It was only because you had like 544 instances running and sleeping that you had problems (that’s what I think anyway).
From what I saw -- it runs continuously with a two hour sleep IF the "retry" count reached 50. There is a "break" statement near the bottom, but I didn't try to match it up with any indented loops (assuming there is an indented/sub-loop within the "forever"  {while [1]} loop).
7 hours ago, m4f1050 said:
Can this be installed on the PI 3 setup of myGMRS net?  I found a .tar file with AutoSky 6?  I tried to set it up, but I ge ta "cp" error that can't find the "OFILE value" file.
Did you read the HOWTO file?
Quote
Set your County
Find your county URL and update in the /usr/local/bin/AUTOSKY/AutoSky.ini file.
Visit https://alerts.weather.gov/ and select your state and county. Click on the ATOM link at the left of the entries and copy the URL. Paste the URL into the $OFILE line. It will look like this:
OFILE="https://alerts.weather.gov/cap/wwaatmget.php?x=PAC017&y=0"
The URL will be different after the /cap/ for your particular county.
EDIT:  I can't install "pacman" on raspbian, it installs the game instead....
pi-star@pi-star-3b(ro):~$ sudo apt search pacman
Sorting... Done
Full Text Search... Done
childsplay/oldstable 3.3-2 all
  Suite of educational games for young children
gtkboard/oldstable 0.11pre0+cvs.2003.11.02-9 armhf
  many board games in one program
hannah/oldstable 1.0-3 armhf
  pacman-like game, child oriented
hannah-data/oldstable 1.0-3 all
  pacman-like game, child oriented - data files
njam/oldstable 1.25-10 armhf
  pacman-like game with multiplayer support
njam-data/oldstable 1.25-10 all
  pacman-like game with multiplayer support -- data files
pacapt/oldstable 2.3.13-1 all
  Arch's pacman-like package manager for some Unices
pacman/oldstable 10-17.2 armhf
  Chase Monsters in a Labyrinth
pacman4console/oldstable 1.3-1 armhf
  ncurses-based pacman game
xscreensaver-data-extra/oldstable 5.42+dfsg1-1 armhf
  Extra screen saver modules for screensaver frontends
pi-star@pi-star-3b(rw):~$
Is "pacapt" the package you want?
Sorting... Done
Disregard, I was trying to install it on the wrong sdcard.
I do have an issue....  (not AutoSky related, AutoSky is working)  I can't connect to any node.  I did notice the rc.updatenodelist just sits there until it times out.
Also, on rpt.conf, there is a 1999 = radio@127.0.0.1/1999,NONE     <-- is this needed?  I removed it...
Here is what I get on supermon allnodes:
  Private Node 21211 => Node not in database   lsNodes
  Node   Node Information Received Link Direction Connected Mode
  Could not login to Asterisk Manager.
* I just realized, when I downloaded the image, it's version 1.7, does it need to be version 1.6?
I noticed a folder changed, /var/www/hml/supermon is now /srv/http/supermon
EDIT:
I figured out my problem....  password had a & in it...   I still have a problem...   ?
I am still getting "node not in database" error...   I pointed to the _gmrs file but it's not giving me a list when I click on LsNodes
8 hours ago, m4f1050 said:
I have the same issue with node not in database, I have added the info in the /etc/asterisk/local/privatenodes.txt but something must still be missing
EDIT:
Is your rc.updatenodelist timing out also?  I have a lot of these processes running at the same time, does not look normal, the version on the image on myGMRS exits and doesn’t hang…
EDIT:
I don't use asterisk with HAM so I added an "exit 0" after it queries the rpt_extnodes_gmrs and moved on....  Still need to figure out how to show in the database on supermon...
